Old 05-18-2020, 06:04 PM #331
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
Originally Posted by infamousRNR View Post
@Joelzy
just love what you've done with your build... this rear swing out with the stock bumper is something I would def consider if there was a kit out there...
- Sean
Thank you sir, If it was easy to make a kit i'd consider it but for now, if anyone needs details i'll provide everything i can to help. More than willing to help someone build some stuff
supdate: had a few minutes and started cleaning up the wheels
popped out the rivets and lightly wirewheeled all the crud off one so far.
Untitled
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 03:01 PM #332
Joelzy's Avatar
Joelzy's Avatar
Got one completely cleaned up and damn what a difference it made. After seeing this i think i might just clear coat them
Untitled
UntitledUntitledUntitled
–02 bmw 540i6
–19 Highlander SE
Old 05-21-2020, 09:29 AM #333
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Do it! Clean aluminum looks best on wheels in my opinion.
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 09:44 AM #334
JZiggy's Avatar
JZiggy's Avatar
Originally Posted by Joelzy View Post
Got the platform about done minus drawers
Hey Joel, do you have a picture of how that little swing-down support engages with respect to the folded down seats? I'm planning out my own platform and want to use a simple design like this but want to figure out how to get that front section just right. Thanks!
Old 05-21-2020, 10:13 AM #335
Joelzy's Avatar
Joelzy's Avatar
hmmm i dont and i took the layflat flap out knowing we wouldnt be camping this season.
I kind of winged it in that i laid the big flap down level and measured to get an idea of how tall the support needed to be. Then realized the seat backs would give a little with the extra weight so i added an inch or so for that. I was hoping that gravity would drop it down automatically but with the carpet and all it needed assistance to drop into place. Also, in the very end, it wasnt quite level and i ended up trimming one side more to get a truly flat surface.
–02 bmw 540i6
–19 Highlander SE
Old 05-21-2020, 11:52 AM #336
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Clear coat on the cleaned up aluminum wheels will be a good look. A 2k clear would be a good option to give it a tougher finish and better chemical resistance. I like the cheaper cost and longer shelf life of 1k aerosols but sucks how quickly it fades/dissolves when it comes in contact with solvents.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 12:45 PM #337
Joelzy's Avatar
Joelzy's Avatar
thanks, i figured regular ole rattlecan clear wouldnt hold up. Poked around and Eastwood has 2k aerosol, thoughts?
Eastwood 2K Aerospray Clear Coat Matte & High-Gloss
–02 bmw 540i6
–19 Highlander SE
Old 05-21-2020, 01:47 PM #338
fourfive's Avatar
fourfive's Avatar
Eastwood & spraymax have good quality 2k aerosols. Both would hold up really well to solvents, brake cleaner etc. I've noticed a pretty significant difference in durability between catalyzed (2k) & uncatalyzed paint especially with solvents. Main downside is once activated, the 2k paint has a shelf life of a few hours before it completely hardens up & becomes unsprayable.
Amazon.com: USC Spray Max 2k High Gloss Clearcoat Aerosol (2 PACK): Automotive
Old 05-21-2020, 01:50 PM #339
Joelzy's Avatar
Joelzy's Avatar
Noice! sold me, thanks man. Reviews are pretty damn good and I'd love to spend 40 bucks on a couple one-time use cans vs finding a powdercoater just for clear and spending a couple hundred.
Related note, these came in early so i have some work to catch up on.
UntitledUntitled
as seen in the other thread, wasn't planning on getting tires now but they were almost 100 bucks off on simpletire at a slightly larger size so i had to pull the trigger.
hoping to get the wheels cleaned up this weekend and tires mounted next week.
update: got the wheels all done and cleared, ready for mounting
Untitled
Used the Spraymax 2K high gloss(thanks @fourfive ) and it went on so well, hopefully it holds up just as well, good stuff so far for sure.
–02 bmw 540i6
–19 Highlander SE
Old 05-27-2020, 09:55 AM #340
Joelzy's Avatar
Joelzy's Avatar
got the tires on and balanced
UntitledUntitled
Untitled
Just a test fit, need to swap my extended studs in as well as wait for new bolts to replace the rivets and centercaps to come in. This was mostly to check clearances on UCA and brakes with the 1/4" spacer. i have plenty of room with the UCA for no spacer but the wheels touch the tundra brakes without a spacer
so i'll have extra UCA clearance, just enough between wheel and brake and with the slightly taller tire, a chance that i'll need to cut more pinch weld.
also got the cupholder i made with my new 3d printer in and it works muuuuch better than factory. Also holds a larger bottle so thats nice
Untitled
–02 bmw 540i6
–19 Highlander SE
Old 05-27-2020, 11:28 PM #341
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Dude, those wheels are sick! Love all the OEM+ mods that your truck has. Keep it up.
rickashay is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 12:36 PM #342
fourfive's Avatar
fourfive's Avatar
Wheels turned out great. Always liked the tread pattern on the dynapro mt. Are those 285/75/16?
Old 05-28-2020, 12:39 PM #343
Now if they had some Aisin manual hubs in the center, they would be perfect!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-28-2020, 05:19 PM #344
Joelzy's Avatar
Joelzy's Avatar
Thank you! thats the idea im going for
Thank you for your help! that clear turned out so damn good and didnt flinch at having the tires mounted. The tires are 295/75/16 which i found to be randomly about a 100 bucks cheaper than the same 285s so i had to try em out for that price. They're about an inch taller than the 285/70/17s but those wheels are also 9"
NOW WE'RE TALKING!! thats on my list but with the kiddos on the way i think im a ways out.
–02 bmw 540i6
–19 Highlander SE
Old 06-01-2020, 01:18 PM #345
Joelzy's Avatar
Joelzy's Avatar
Got the studs swapped out for the longboi Lexus ones. they didn't have to be quite this long but i didnt know how big of a spacer i would need when i ordered them and the enclosed ET style nuts still fit on the new wheels with the spacer so its all good.
these were easier than expected to get out, didnt have the little press so an old nut and a hammer worked fine.
I did run into the small issue of my Tundra brakes once again being in the way.
they were touching in the teeniest amount on the lower cylinder of the caliper and didn't want to run a bigger spacer or different wheel. i considered just tapping the caliper with the grinder but ultimately decided instead to run the die grinder around the inside edge of the wheel(wheels were 40 bucks, brakes were significantly more). Only took off a mil or 2 at most and sure enough the next test fit it cleared completely.
Untitled
Starting to understand why you dont see many of these old wheels
still waiting on the bolts to replace the rivets and center caps to come in.
attempted to 3D print a centercap but it did not turn out unfortunately. Need to look into the cause but everything ended up off kilter
Screen Shot 2020-06-01 at 11.21.20 AMUntitledUntitled
update:
got the bolts in from fastenal for the wheels to replace the rivets.
pretty happy with the outcome but would have definitely waited and mounted tires after next time, quite a pain to hug the tires to reach the other side.
UntitledUntitled
Untitled
–02 bmw 540i6
–19 Highlander SE
spark plug rethread , stripped spark plug , time sert , time-sert , timesert
