09-06-2022, 03:54 PM
SC or Xterra?
I've got a '99 4Runner with 220k miles and am becoming increasingly frustrated by the lack of power when towing relatively lightweight campers (1,000-1,500 lbs.) through the Colorado mountains. For what it's worth, I didn't buy the truck with the intent to tow - it's a hobby my family picked up and don't seem keen to stop anytime soon.
The two options I'm debating are putting on a supercharger and selling the truck for an Xterra.
While the S/C is of course the less expensive option ($3,795 new or cheaper used), I can get a 2010+ Xterra with lower miles for $12-15k locally (and sell my truck for ~$7k).
Knowing this forum is obviously biased, maybe the better question to ask is, why wouldn't I upgrade to a 10+ year newer, more powerful, and similarly equipped truck for an additional $2-5k over the cost of an SC?
09-06-2022, 04:13 PM
Real Name: Patrick
Real Name: Patrick
There's a double edged sword with newer vehicles as there are a lot more vehicle systems and modules. The downside is there are (obviously) a lot more systems/modules that could fail. The upside is newer vehicles are much better about setting a code that will aid in narrowing down what is wrong. I personally find 99/00 4Runners the ideal amount of vehicle systems and technology. I have a friend with a 2010 Frontier (essentially an xterra truck as far as powertrain and engine bay go) and it's a tight squeeze to work on anything in the engine bay.
If you're considering an xterra I would highly recommend test driving a couple if you can find some locally to test drive before spending too much effort into finding an xterra to buy. I thought I wanted a Hummer H3 Alpha once upon a time until I drove one. The interior is horrendous and the ride is pretty bad as well.
09-06-2022, 04:22 PM
Appreciate your perspective - all valid points.
I've driven four Xterra's and have enjoyed the less harsh suspension compared to my truck with a 2" lift. I'd love to see how it tows but am guessing it's smoother - I need to find someone in the area with a SC 3rd gen to see how that feels as well.
09-06-2022, 05:04 PM
Real Name: Patrick
Real Name: Patrick
You're welcome. Test driving a supercharged 3rd gen would be ideal. I'm not sure what elevation you are at, but higher altitudes limit hp/torque gains from supercharging. You can change supercharger pulley/injector/fuel management/etc to get more out of the supercharger, but that's obviously additional money/effort/complexity.
An alterative route to supercharging would be regearing front and rear differentials. I'm assuming you are running a larger than stock size. Combine that with additional weight and a regear may be just as beneficial as a supercharger.
09-06-2022, 06:55 PM
Is yours a manual or auto? The auto feels incredibly sluggish compared to the manual, I’d also consider a 4.0 manual Tacoma.
09-06-2022, 08:11 PM
3rd option would be gears. A set of 4.30 gears would go a long way, assuming you don't already have them.
Mine was a pig before I updgraded to the Elocker wtih 4.30s. Now it pulls pretty well, even on the hills. I have yet to tow a trailer further than 30 miles, but I hardly noticed the 2200lb enclosed that was full of DJ equipment last time I towed.
The 4Runner Show
09-06-2022, 08:29 PM
Real Name: Jerod
Real Name: Jerod
Did Nissan fix the rod knock problems with the older Xterras? Not very many of them left.
09-06-2022, 08:46 PM
If you go for the Xterra, made sure it is after 2010. Problems galore in the previous years. I would start with regearing and see if it helps.
Honestly though, find a first gen Sequoia or even GX 470with the 2uz for better pulling power.
09-06-2022, 08:59 PM
Real Name: Devan
Real Name: Devan
I don't know about you guys, but I'd rather walk than be caught in an XTerra
The first gens weren't bad looking, but second gens... sheesh
09-07-2022, 11:18 AM
Mine's an auto and yes, it is insanely sluggish.
I'm running stock gears with 265/75R16 tires (31.6"). Trying to hold any sort of consistent speed while climbing is painful - the tranny shifts endlessly. How much would re-gearing help with that?
Yup - SMOD (strawberry milkshake of death) affected the pre-2010/2011 models. I should have mentioned the pricing I shared was for 2011+.
Beauty (or lack thereof) is in the eye of the beholder
09-07-2022, 11:58 AM
Real Name: Mark
Real Name: Mark
Check out the Exterra forums for model year your looking at see what people are having issues with. The shorter wheel base changes things when towing trailers also look for towing threads.
Exterra has theater seating in rear seat way less headroom be sure to sit in rear seat, for short people or children it fine sucks for others.
09-07-2022, 12:14 PM
If you like to drive a manual I’d consider a manual swap, it’s like a whole different vehicle and the drivability in the mountains is significantly improved
09-07-2022, 12:19 PM
Real Name: Blair
Real Name: Blair
I drive with OD Off and fly (relatively speaking) up hills with 4.30 gears and hundreds of pounds of gear. I have nothing to say about a Nissan. I like some Datsuns but it stops there.
09-07-2022, 01:17 PM
Real Name: Mark
Real Name: Mark
Here's a little tid bit about main body structure Yota vs Nissan:
Both are held together by spotwelds more spotwelds make a better box for us to ride in.
Toyota puts their vehicles together with 13-18% more spotwelds than Nissan.
Nissan chooses to save a few dollars in production costs with fewer spotwelds.
Just sayin.
09-07-2022, 01:28 PM
Real Name: 3 Bears
Real Name: 3 Bears
i like toyotas....if I needed the extra power and space I would look at a sequoia.
next would be a tundra.
I think regearing would be better than a super charger, but have to admit, I have not had a super charged 4runner so cant say for sure which is better.
.i have pulled about 2300 pounds behind my 4runner, and up hills too.
I admit it does not like hills with that weight. I also have tundra brakes to stop it, which is another item if your thinking of pulling weight up and down hills you might want to do the tundra brakes too.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
