04-26-2018, 01:49 PM
Dome Light Fuse issue
The freaking dome light fuse is driving me nuts. I bought it with this issue and just drive it with no radio or electronic door locks.
I cant figure out where the short is. I am amost positive it is something from a leaking sun roof. But I have no idea for sure
Does anyone have a diagram of the wiring from that fuse?
Ive been searching threads on here and cant really find anything.
04-26-2018, 02:41 PM
here you go
04-26-2018, 03:51 PM
Originally Posted by spartacus
here you go
That doesn't tell the whole story by a long shot. The DOME fuse is key off power for a ton of systems, not just the interior lights, e.g.:
Auto Antenna
Cigarette Lighter and Clock
Combination Meter
Headlight (w/ Daytime Running Light)
Interior Light
Radio and Player.
The usual suspects are add-on circuits like alarms and remote starts and stereo systems.
If those are ruled out, I can troubleshoot, but the OP needs to give THE YEAR. (pet peeve)
My Backyard Frame Swap
04-26-2018, 04:03 PM
Auto Antenna
Combination Meter
Interior Light
Radio and Player.
I agree. I've been reading your posts and learning from them for a long while now and strongly urge the op
@ TurtleAdventure
. to read your post and follow the directions.
04-26-2018, 04:24 PM
Auto Antenna
Combination Meter
Interior Light
Radio and Player.
I noticed it must control a lot.
It is a 98 SR5 3.4 with after market radio.
I am going to take the radio out and then test the amps on the fuse spot. But the radio looks old so I am guessing it worked at some point. The auto antenna is busted off. The ceiling has water stains and so the dome light wires could be all messed up and shorted.
I am just going to have to look one by one at these areas and see if I can figure out the where the issue is.
04-26-2018, 04:32 PM
That's a good way to start. I always begin by pulling the radio on these. These things often involve physical damage or corrosion that can be found with the old Mark I eyeball. Troubleshooting it analytically can be an awful lot of work, but you always get there, so that's Plan B.
04-26-2018, 05:42 PM
We have a saying around work: 90% of electrical problems are mechanical.
Like TheDurk says, start with the easy things: Aftermarket parts, radio, clock, then look for mechanical problems - driver's door wiring boot, rear hatch wiring boot, etc.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-25-2020, 11:47 PM
Help me too
I have the same problem on my 4runner 99.
I put the light tester clamp to positive on battery and testing on fuse port... Im still having a bright light.. I don't know where is the short!
By now I disconnected:
Radio (after market)
Cigarette
Clock
Alarm (after market)
2 roof lights
Please help me! It's perturbing.
Toyota 4runner 3er Gen, 99, 4x4 Beige.
10-26-2020, 12:47 AM
Did you ever resolve this? I just had this issue start today. I was installing new LED lights in the dash and was working on the clock and now I don't have a radio or dome lights. Everything else seems to be working though.
10-26-2020, 10:15 AM
Did you have a chance to check the DOME fuse under the hood? It controls dome light + radio. It should be 15 amps.
Give that a shot.
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
03-20-2021, 11:06 PM
Give that a shot.
Interesting. 2 day old 05 4runner owner here. I did find a fuse box diagram and see a 15a fuse for the dome but I didn't see anything for the radio...
A little background: I just bought the car and the previous owner took out his aftermarket stereo and mounted the stock back in, unplugged apparently. I haven't had a chance to check all but it looks like so far: the radio, side mirror controls and dome lights do not work as expected (do the ones in the front count?). I haven't tested some of the other accessories like the cigarette lighter yet.
05-29-2021, 03:29 PM
Any luck on this? I bought mine a few months ago - the dome lights and side mirrors did not work and I don't have anything with a cigarette lighter adapter to test those. Radio wasn't installed so wasn't able to test that but have since installed a new head unit and works as expected.
Looking to get the dome lights and side mirrors working but don't know where to start...
05-30-2021, 12:05 PM
If you have an 05 you should be looking in the 4th gen section, not the 3rd gen section.
