Originally Posted by phattyduck
You probably have a damaged flex circuit board on the back of your gauge cluster. When mine when bad, the reverse light would flash with the left turn signal and I would get a CEL for the gear position indicator. Sounds kinda similar (otherwise unrelated systems interacting - they only come close on the gauge cluster).
Thanks, Charlie. is that a swap of the whole instrument cluster? That's where I was leaning after having a buddy over & spending 3-4 hours wiggling, unplugging, retesting & such...
I can't just pull the flex circuit off, can I? Only question/issue I'd have if I have to replace the cluster is the Odometer - I'm guessing I'd just have to find the chip, unsolder & resolder...
it's an 02 SR5 - I believe the 00 cluster is slightly different - do you know if an 01 is the same? Just trying to see if I can find one at a junkyard rather than paying full to have someone else have pulled it...
thanks again!
