Old 07-13-2019, 05:47 PM #106
Taylor20's Avatar
Taylor20 Taylor20 is offline
Taylor20 will become famous soon enough Taylor20 will become famous soon enough
Taylor20's Avatar
Installed the 01-04 Tacoma TRD front swaybar with Sonoran Steel endlink brackets. So far road manners are night and day comparing to no bar at all.
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
Taylor20 is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 01:02 PM #107
Taylor20's Avatar
Taylor20's Avatar
My “Forever” 4Runner, 02 Stellar Blue Sport
ULR’s installed along with custom fabbed UCA’s
ULR’s from @eimkeith and very easy to install. I’m a rookie to welding so they may not look phenomenal but the heat penetration is good. I struggle with being in weird positions and nozzle angle, but that means room for improvement.
UCA’s are built using MetalCloak Duroflex joint’s part# 7320, Trail Gear threaded bung inserts, and DOM tubing. The mount body side needs a little massaging so the joint does not bind. These links are beefy, and probably overkill to be honest.
I need to get some 1/2 grade 8 bolts for the links as that is the bolt hole size for the joint. Also a washer to fill space between each joint and mount. Aside from those small things, I can now adjust pinion angle, not worry about bending an upper link or having the link mount fold over.
02 Sport
4xI - AED - Savage
Old 07-14-2019, 03:30 PM #108
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
UCA’s are built using MetalCloak Duroflex joint’s part# 7316, Trail Gear threaded bung inserts, and DOM tubing. The mount body side needs a little massaging so the joint does not bind. These links are beefy, and probably overkill to be honest.
I need to get some 9/16 grade 8 bolts for the links as that is the bolt hole size for the joint. Also a washer to fill space between each joint and mount. Aside from those small things, I can now adjust pinion angle, not worry about bending an upper link or having the link mount fold over.
Those joints are impressive, no? quality stuff.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 10:02 PM #109
Taylor20's Avatar
Taylor20's Avatar
Info given on the website shows them to be impressive. They are definitely beefy though. Time will tell though.
02 Sport
4xI - AED - Savage
Old 07-27-2019, 11:21 PM #110
Taylor20's Avatar
Taylor20's Avatar
I dropped off Bella at my local fabricators shop for a new front bumper. He nailed it, exactly how I wanted the design. This week it will be clear coated, and reinstalled with the winch.
I’ll have more pictures once it is all back together.
02 Sport
4xI - AED - Savage
Old 07-28-2019, 09:00 AM #111
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
That looks great.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 11:00 PM #112
Taylor20's Avatar
Taylor20's Avatar
Bumper has been clear coated, and everything installed.
Light bar is a 27” dual function from Apex Overland.
I’m still using the Warn VR8000 winch but I replaced the original solenoid pack with a SuperWinch contactor unit
I also replaced the Custom Splice brand synthetic rope with a 80’ 3/8” rope from C4RS, along with their hawse fairlead and finished it off with a Factor55 Prolink.
I am very pleased with how it all turned out.
One issue I did run into was the wiring diagrams differed from what my Warn remote has and what online sources gave. Also the SW contactor wiring differed on a couple sites. Trial and error solved the problem and thankfully without burning up anything.
02 Sport
4xI - AED - Savage
Old 09-05-2019, 11:01 AM #113
Taylor20's Avatar
Taylor20's Avatar
ATR 2019 was a phenomenal weekend. I highly recommend it. Filled with awesome trails, amazing people, and beautiful rigs.
02 Sport
4xI - AED - Savage
Old 09-05-2019, 07:11 PM #114
thezentree's Avatar
thezentree's Avatar
Man that looks like such a good time. I wanted to go so bad but that was e-locker/regear weekend for me.
Old 09-06-2019, 08:21 AM #115
Taylor20's Avatar
Taylor20's Avatar
Make plans next year! It is a phenomenal event. 72,000 acres and over 300 miles of trail from a gravel road to guaranteed body damage. Vendor booths, giveaways including a CVT tent, Dometic fridges (yes, multiple), skids plates, bumpers, sliders, etc. You'll make a bunch of new friends too.
02 Sport
4xI - AED - Savage
Old 09-06-2019, 08:51 PM #116
thezentree's Avatar
thezentree's Avatar
I'm gonna have to make a point to. Were the trails crowded?
Old 09-09-2019, 08:23 AM #117
Taylor20's Avatar
Taylor20's Avatar
Not at all this year. I went out with a friend and we ran into maybe 7 rigs on each trail. A handfull more SxS's, but they just pass right on by.
Now group rides might get a little crowded, and while I highly recommend doing a group ride for a first timer, it isn't necessary.
02 Sport
4xI - AED - Savage
Old 09-20-2019, 07:25 PM #118
senor perfecto senor perfecto is offline
senor perfecto is on a distinguished road
Aftermarket hood? Or is that factory?
senor perfecto is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 09:01 AM #119
Taylor20's Avatar
Taylor20's Avatar
OEM Sport hood
02 Sport
4xI - AED - Savage
Old 11-29-2019, 05:43 PM #120
Taylor20's Avatar
Taylor20's Avatar
Glamour shots time...
02 Sport
4xI - AED - Savage
PDX, OR: AOB "LED Light Bar" and "Rear Lights" Switches - Blue pbcolt For Sale: T4R Items 4 03-26-2018 06:45 PM
Noshirt's Stellar Blue Metallic '02 Sport Build Noshirtganshirt 3rd gen T4Rs 277 02-13-2018 01:37 PM
Matt... Stellar Blue Sport Hood in Virginia SURF RUNNER 3rd gen T4Rs 18 09-16-2017 11:29 AM
FS: 2002 Stellar Blue Sport Edition 4WD - NORTHERN NEW JERSEY LSHURST For Sale: Vehicles 22 11-08-2016 09:15 PM
