ULR’s installed along with custom fabbed UCA’s
ULR’s from
eimkeith
and very easy to install. I’m a rookie to welding so they may not look phenomenal but the heat penetration is good. I struggle with being in weird positions and nozzle angle, but that means room for improvement.
UCA’s are built using MetalCloak Duroflex joint’s part# 7320, Trail Gear threaded bung inserts, and DOM tubing. The mount body side needs a little massaging so the joint does not bind. These links are beefy, and probably overkill to be honest.
I need to get some 1/2 grade 8 bolts for the links as that is the bolt hole size for the joint. Also a washer to fill space between each joint and mount. Aside from those small things, I can now adjust pinion angle, not worry about bending an upper link or having the link mount fold over.
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
