Old 04-29-2018, 09:19 PM #1
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
vsc abs light solved.
Idk if anyone remembers me having the issue when I put it into reverse I would get a abs light with vsc lights also. Also the right reverse light would dim when I hit the brake.
Turns out it was the ground bolt for all the rear right lights. It was not super tight and had a very weak ground. So the when I was in reverse it worked but when I hit the brake the added amps from the other bulbs it failed.
I must have never tightened it after using it for a ground. So a place to check if your having issues when you go into reverse is check the grounding on both light housings.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
The mystery of the flashing 4WD light. (SOLVED) samwhich 5th gen T4Rs 5 01-03-2018 05:46 PM
65+ MPH Vibration Solved? iwishiwasbigger 5th gen T4Rs 14 10-09-2017 11:54 PM
Who's solved a Harmonic Vib? Fuzzy Fingers 4th Gen T4Rs 10 01-23-2014 01:34 PM
CK Eng Light and VSC TRAC lights are off and solved I hope jow 4th Gen T4Rs 2 01-08-2014 02:37 PM
My Clunk Solved! UTEP 3rd gen T4Rs 6 10-28-2013 06:02 PM
