Old 05-07-2018, 12:12 PM #16
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by Yukon4Runner View Post
Ok, thank you all for the input.
The way I’m reading it is as follows:
To replace the tailgate on my 2001, if I find a ‘99+ replacement, I’ll only need to swap the lock cylinder so my key will work.
If I find a ‘96-‘98 tailgate, I’ll need to replace the lock cylinder and the wiring as it is incompatible.
Yes. They use the same part for the Back Door ECU, the orange one. '99 lists 85930-35060, but that is listed as replaced by 85930-35061, which is the listing for 2001. So it should all be plug and play electrically. (2001 and 2002 are clones, so it's all covered.)
Toyota Part No.: 85930-35060
RELAY ASSY, POWER WINDOW
Toyota 85930-35060 RELAY ASSY, POWER WINDOW
Part Description Relay Assy, Power Window, NO.1
W(KEY LESS ENTRY)
Replaced By 85930-35061
Manufacturer Toyota. This genuine Toyota part is guaranteed by Toyota's factory warranty.
My Backyard Frame Swap
Old 05-08-2018, 12:38 PM #17
Yukon4Runner's Avatar
Yukon4Runner Yukon4Runner is offline
Yukon4Runner is on a distinguished road
Thanks again to everyone for the info.
I’ve found a 2002 tailgate in mint condition at a good price; of course it’s in a different color.
Anyone have any idea how much I should expect to pay to have it painted?
2016 TEP KDSS
2001 SR5 195k
The petting zoo closes at 2:00, the goat roast follows at 3:00
Yukon4Runner is offline   Reply With QuoteReply With Quote
Old 05-08-2018, 02:56 PM #18
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
That depends on how good of a paint job you want and who does it. You'll get the best deal no matter where you go if you completely disassemble (remove seals, emblems, bezel, etc) the door yourself
Sent from my Pixel XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-12-2018, 12:54 PM #19
Replacing Tailgate: Quick Question-85863010-a5d7-45ff-8844-83643dab1835-jpeg
2016 TEP KDSS
2001 SR5 195k
Old 12-28-2019, 02:00 AM #20
cklin424's Avatar
cklin424 cklin424 is offline
cklin424 is on a distinguished road
cklin424's Avatar
Hello all,
I’m getting ready to replace the tailgate on my 2001 SR5.
Before I start poking around the local scrapyards, I wanted to make sure that a tailgate from any 3rd gen (1996-2002) would be compatible.
Thanks in advance.
I just replaced the hatch on my 2001 SR5 with a donor hatch from a 2000 SR5. I had to swap the lock cylinder and the ECU and now the keyless entry and the rear window work.
However, I have been unsuccessful in getting the rear defrost or wiper to work. I pulled back the rubber boot at the top of the hatch two of the wires in that loom had cracked casing but the wire itself was intact. I covered the exposed wire with tape to see if the exposed wire was causing my issue but no luck there.
Is this a wire harness compatibility issue or should I start looking at other components? Did you have any issues replacing your liftgate?
cklin424 is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 08:19 PM #21
Stickfigure808 Stickfigure808 is offline
Real Name: Ivan
Stickfigure808 is on a distinguished road
Real Name: Ivan
I know this post is old.. but I just bought my dream 98runner and the back window won't roll down due to the hatch being from a different year... Wires don't match at all..
Is there any way to make the window compatible or should I try and get a key made for the hatch and see if that works ?
*First pic is of wires that aren't connected from the body
*Second pic is lose wires coming from the hatch.
I'm shouting out for help before taking it to a shop.. Thanks!!
Replacing Tailgate: Quick Question-img_20200527_112033454~2-jpg  Replacing Tailgate: Quick Question-img_20200527_112041711~2-jpg
Stickfigure808 is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 12:03 PM #22
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
^ I would see if you could locate a hatch harness for your year. Much easier than diagnosing and fixing this wiring mess. Removing and reinstalling the wiring harness is not as difficult as it seems. I have done it, and I consider myself a rookie.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 08-28-2020, 03:21 PM #23
MrWalkway MrWalkway is offline
MrWalkway is on a distinguished road
This might be a dead thread but im swapping out my tailgates as well. Putting a 2000 tailgate on a 98' I swapped out the group of wires from the 98' that goes from the control module into the two grey and white female sockets in the headliner.
While plugged in the plate lights and the locking mechanism using the key fob works.
Do I have to swap all the internals? including the 98 window motor, rear wiper motor, the whole works for it to be fully compatible?
MrWalkway is offline   Reply With QuoteReply With Quote
Old 08-28-2020, 03:55 PM #24
Pictured here is the 2000 tailgate on the 98' limited 4runner. The grouping of wires that is hanging are the old wires i took out of the 98. These wires run from the control module, up the tailgate and into the rear headliner. The only real difference between the 98 and the 2000 groupings of wires is that the 2000' is that the white male end that goes into the rear headliner is smaller than the female adapter on the 98
Maybe there is bigger difference I am over looking, Do I have to swap out all the internals of the hatch for it to work or just the wiring?
Replacing Tailgate: Quick Question-118002764_4740858029265305_1596164221833815082_o-jpg
Old 01-27-2021, 05:42 PM #25
toyorgy toyorgy is offline
toyorgy is on a distinguished road
I need to replace the tailgate of my 2002 before I sell it. From what I hear, only another 2002 would be a bolt on with no other issues because the wiring is different in other years.
toyorgy is offline   Reply With QuoteReply With Quote
ARB fridge:quick question hoping for a quick answer familymopar 5th gen T4Rs 5 09-04-2016 01:33 PM
Quick question tundra fabtech dirt logic question Diggo 3rd gen T4Rs 3 06-09-2016 02:33 PM
Quick-question-quick answer needed chetJ 5th gen T4Rs 9 11-23-2012 12:35 AM
replacing both tailgate glass support channels on 1995 need alittle info.. 4for4runner Classic T4Rs 1 03-12-2012 08:48 AM
Quick Question about Replacing Belts Arctic 4x4 Classic T4Rs 6 08-26-2010 06:58 PM
