Originally Posted by FrankieJoe14
No check engine light at all.
How do you test the resistance? Just put a meter on the pins? If it was bad wouldn't it throw a code?
The maf can be working but still out of spec and and not throwing a code.
The engine response often means the air/fuel mixture is not being properly enriched or is going lean.
if you have a obd-II* scanner (you can buy one for around $30 and download torque app)check the data at idle of Long term fuel trim (banks 1 and 2),Sort Term fuel trim
MAF sensor input
AIT sensor input (Also need actual outside air temperature when you take this reading. will give you a better picture.
ohm test maf sensor
