07-21-2018, 11:29 PM
#31
Back in Jersey with the luxury of a garage, oh the glory.
Put in new inner tie rod ends, mine were shot, they had a ton of play and dropped immediately rather than holding themselves up. That was a really easy job
Also replaced my rear sway bar links, they were pretty beat up. Here is a pic of the one that was in better condition - it’s got 3 washers on it, is that normal? When I replaced them I only used 2 washers.
Anyway, the truck drives better, but the noise is still there!
Tomorrow I will take another look at the front LCA cam bolts although I swear I’ve checked them twice and have had it aligned at least once since this noise started.
It also seems like I might have been able to recreate the sound today when I was jacking up the rear axle on one side to do the sway bar links. I might play with that some more to see if I can pin it down.
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
07-22-2018, 12:25 AM
#32
Real Name: Gary Blake
Have you checked your propeller shaft grease situation?
Slip Yoke Binding Fix
Lots of information about slip yoke binding and causing strange hard to pin down noises, mtbtim has a good video about greasing.
Gary
2000 SR5 4 Runner, 3.4, 5spd, 4WD
Shrockworks front & rear bumpers & sliders, Warn VR10,000S, Optima Yellow Top, Icon Uniball UCA
Toytec Ultimate Lift Kit (Soon to be replaced by Icon)
Method 305 NV Racing Wheels
07-22-2018, 09:55 AM
#33
When I have a noise that can't be solved I just keep turning up the radio until it overpowers the offending sound
TT
1998 4Runner 3.4 Auto
07-22-2018, 02:52 PM
#34
The picture you posted here is correct. Two washers on the bottom, one on the top. The top washer on the lower side centers the link rod and keeps it from rubbing on the frame mount.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
07-22-2018, 10:55 PM
#35
Front end clunking sound/bind feel while turning and going over bumps
What an eventful day!
Figured out the cause of the sound...turns out it was...wait for it...a loose rear upper control arm nut! So it all comes full circle and my very first hunch was correct. The nut connecting the driver’s side to the axle was hand tight.
Flash back to my first post in the thread I mistakenly said I had checked and tightened the rear UCA. I misspoke, it was actually the LCA. I somehow missed this one bolt, I think it was hard for me to get to until I jacked it up today and removed my spare so I could sit up.
I can’t believe I’ve been chasing this down for months... the good news is that in the process I’ve put on a lot of new parts and checked and rechecked tons of fasteners.
Also in OTHER good news, I hooked up my Baja squadron sports in my bumper
And in the BEST news - today I also did the gray wire mod with the intent to troubleshoot my e-locker. Once I put the back wheels in the air, pressed the e-locker button, and pushed the wheels by hand it engaged fine for the first time ever in the 1.5 yrs since I’ve owned it.
Took it around the block testing the e-locker and it seemed to work great. So I’m stoked on that too!
We’ll consider this thread solved...unless the dreaded clunk comes back.
07-23-2018, 06:17 PM
#36
Congratz! I'll re-check all mine over the weekend and go from there! Thanks for not giving up and giving periodic updates after each mod and troubleshooting step. Much appreciated!
00 T4R LTD V6 4WD 275K e-locker
11 RAV4 LTD V6 4WD 100K
07-23-2018, 08:59 PM
#37
Real Name: Just call me the Grease Monkey
You owe us all a beer
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
07-24-2018, 09:49 PM
#38
Touché
Meet me up at Vermont Overland Rally end of Sept - beers on me all night!
Thanks for all the help and support everyone, hopefully this thread helps someone in the future.
08-17-2018, 02:33 PM
#39
The front end of my 96 started making some creaky noises about a month ago, Ive only had it for a couple months and the previous owner had recently installed 99 springs and bilsteins. Also looked to have new sway bar end links and new steering rack. The noise gradually worsened. I replaced the lower ball joints and tie rod end links which were in bad shape. This did nothing to improve the creaking and groaning. Finally a couple days ago I started spraying everything down with grease. Barely any improvement. Finally I realized that something must be loose. I went under it this morning and sway bar link was not tight at all both sides. Also the lower shock bolt was way loose both sides. Tightened it all up and now much less noise. Still a little creaky when I brake from slow. The top shock bolt is also very loose but has quite a few threads showing. I'm guessing this is normal. Any idea of how to tighten it while its attached? the small shaft out the top is pretty fixed to the big nut and they turn together. can't get enough leverage to turn the nut while holding the shaft still.
Think it could be causing some noise?
08-23-2018, 04:54 PM
#40
The top shock bolt, front or rear? Either way, no it would not be normal for that to be loose. Don’t know if it’s causing the noise, but if it’s in the front then I believe tightening it would require you to pull the shock/spring assembly, use a spring compressor to compress the spring a bit, then tighten the nut.
That top nut is what holds the shock/spring assembly together, so I suppose if it’s not tight enough it could allow for movement.
07-06-2020, 03:15 AM
#41
Well, I've read a bunch of posts on this noise, but yours was the only one with a video that sounded like mine. I have a 4th Gen, not a third, but that popping sound is exactly what I get at about that same speed and situation (a bit of twisting/flexing the rig). I guess I'll check all the nuts & bolts around my suspension to see if that's the deal. Thanks for posting all this! Also, 4th Gens don't have rear UCAs, but I'll check all the connections anyway.
4Runner Noob
2007 SR5 V6
07-06-2020, 01:50 PM
#42
4th gens have generally the same rear suspension design. There are 2 upper arms back there...
07-07-2020, 10:08 PM
#43
[QUOTE=JohnOfTheJungle;3036730]What an eventful day!
I'm happy for you, but bummed for me. I have the exact same pop/crack sound that was in your video. I checked my rear UCA and all was torqued to spec. I guess I'm just starting off on the same journey, but with what'll be a different solution I guess.
4Runner Noob
2007 SR5 V6
07-08-2020, 08:46 AM
#44
Real Name: Devan
Real Name: Devan
Can't wait to try this, this weekend. Been trying to get to the bottom of it in my truck for ages now.
07-12-2020, 07:20 PM
#45
I was having a jarring metal on metal clanging clunking when turning + going over bumps (basically suspension articulation) on the road. I could have sworn it was something in the front end and was worried my LBJ or tie road was going to break off.
Turns out it was a loose rear upper control arm mounting bolt to the frame! Turned it 1-2 turns to get it to 100 lb/ft, no more clunk!
I am constantly doing things to the runner. I had recently replaced a boot on the tie rod, put on 2nd gen sway bar links, and last year redid all my bushings in the front end.
3-4 months ago I had also loosened up and re-tightened the rear upper and lower control arms to relieve any potential binding.
I guess I didn’t tighten one of the bolts up all the way.
Just a little lesson for me that it’s really hard to tell where sounds and vibes are actually coming from and also super happy my front wheels aren’t going to fall off and I don’t need imminently need a new rack.
I have the same problem.... Anyone else have a different solution that fixed it?
