Old 05-09-2018, 02:05 PM #1
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
Panhard correction kit install
I bought the pck kit a while back and figured I’d get it out in for now while I’m working on hatching parts for my leaf spring swap so I don’t run the chance or wearing out anything since the rear end isn’t squared up after my toy tech spring and king shock install.
Well this is what I have. I posted pics in Keith’s fs thread but figured this post would get more attention.
The driver side bracket fit perfect the passenger side drop bracket did not locate on the stock bracket well at all. Also, what are the two washers for that came with the kit? I’m pretty sure the bracket is tweeked and I just need to basically beat the pck bracket on to make it work and make the bolt holes line up.
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 05-09-2018, 04:22 PM #2
squishmitten's Avatar
squishmitten squishmitten is offline
squishmitten is on a distinguished road
Odd that you're having that issue, I have the same kit and everything lined up no problem.
Instagram: korean__kevin (two underscores)
Squishmiten's 02 Sport Edition Build
squishmitten is offline   Reply With QuoteReply With Quote
Old 05-09-2018, 04:40 PM #3
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
It's not a critical tolerance fit, so I say get it as close as possible, get the bolt through it, and weld it on. Alternatively, you can contact Keith and see what he says
The washers go inside the passenger side adapter, IIRC, to center the panhard inside the adapter; I installed one on each side.
+1
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-09-2018, 05:34 PM #4
I think I’m having issues because the truck was hit and that bracket looks tweaked.
The other side fits perfect.
I’ll get it to fit just was curious if anyone could tell what I had going on with the pictures I posted.
The washers inside make sense, the passenger side bracket is a little wider inside than stock.
Old 05-09-2018, 05:49 PM #5
Are you sure a panhard correction kit is what your truck really needs lol
Sent from my Pixel XL using Tapatalk
Old 05-09-2018, 06:43 PM #6
Well it’s lifted so I assume it needs it since the rear end isn’t centered since it’s been lifted.
I am only assuming the weird fitment is related to that bracket / perch possibly being tweaked from an accident as I see bondo on that back quarter panel. There is no visible issues with the frame rails that I can tell but really I don’t know.
Old 05-09-2018, 06:46 PM #7
Basically I have the pck and want to put it on but long term solution for me is leaf springs and removing that bracket and crossmember anyways. But that could be a year or so down the road if not longer
Old 05-09-2018, 06:48 PM #8
Also, I assume that perch is tweaked just because it looks odd, can someone take a picture of what there passenger side panhard bar bracket looks like from the wheel well?
Old 05-09-2018, 06:57 PM #9
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
Just walked out there to start work
Panhard correction kit install-thumbnail-11-jpg  Panhard correction kit install-thumbnail-4-jpg
Wedgy is offline   Reply With QuoteReply With Quote
Old 05-09-2018, 07:51 PM #10
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
You can see the twist in it in your first photo. Just get out a BFH and see if you can get it aligned with the bracket holes. It's your truck and not the PCK. @eimkeith PCK kit is a super easy install and the fit was perfect on mine and everybody else's. I'm sure you'll get it sorted.
Worse case if you plan on using the lower holes you could just put the bar in one of the lower holes and weld it with the first holes still off centered. Just make sure the bar fits than tack away. If your going leaf eventually that'll be fine till then. Most likely a lot longer. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 05-09-2018, 08:02 PM #11
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Looks like it is bent forward and twisted a little.
I'd say a good sized hammer and a grinder with a flapwheel will straighten and smooth it right out.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 05-09-2018, 08:31 PM #12
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
That factory upper mount is MANGLED.
the good news is - you can correct it with the PCK drop bracket if you don't distort it (the PCK bracket), and keep the axis between the holes parallel to the centerline of the frame (does that make sense?)
Judging by the photos, your rear panhard bar bolt hole in the upper mount may be in the correct location - I can't imagine what kind of rear suspension bind you must have had up to now, getting this resolved should make a night and day difference!
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 05-09-2018, 09:16 PM #13
Yeah, I have no clue haha. It has always seemed to drive ok. Maybe I just thought t was ok for 200k miles and just assumed.
I’ll get it sorted out I’m sure pretty easily when I have some time get out there later this week I hope.
Old 05-09-2018, 09:18 PM #14
I never even mentioned it being a pck problem. I assumed it was my truck all along.
Old 05-09-2018, 09:22 PM #15
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
oh man - you're going to love the difference. (or my name isn't Orville Redinbahker {someone help me with the spelling})
keith
eimkeith.com
FS: eimkeith PCK® (Panhard Correction Kits) for 3rd gen $93.50, 4th/5th Gen $98.20 eimkeith For Sale: Suspension/Wheels/Tires 357 06-03-2022 03:52 PM
Panhard correction bracket or bar to fix bumpsteer with mild lift? JohnOfTheJungle 3rd gen T4Rs 38 02-13-2018 01:17 AM
Panhard bar drop vs adj panhard bar Swimmerboy2112 3rd gen T4Rs 30 01-15-2018 04:29 PM
odometer correction? repo General Discussions 2 02-05-2015 07:54 PM
