05-15-2018, 07:20 PM
Detroit Truetrac Limited Slip
Anyone running a Truetrac limited slip in their 3rd Gen? If so, tell us about it.
05-18-2018, 08:52 AM
I don't think so, I've asked this before with no answer. I'm going to install trutrac one day, I just replaced my pinion bearings 18months ago, I'm thinking end of this year when it's time to change the fluid. I've talked with some buddies of mine who have run trutrac, and they say it was great, no stupid ratcheting like the gorilla lockers, with no durability issues.
05-18-2018, 09:08 AM
Daily driver or not? I had always heard full time lockers are bad on snow/ ice and tested that out on some of the slippery stuff last winter. I quickly turned the locker off and went about my business in regular 4x4 and left the transfer case open.
I have a Spartan in my '87 4Runner and really like it; but I do not drive it on the street much. YMMV
05-18-2018, 09:26 AM
Front or rear? There are a few on here running them. A quick search gets:
Detroit truetrac
Anyone running a Tru-Trac in the rear?
TruTrac, in front IFS
There are more to go along with these threads. The alternative search described in the stickies works best for me on this forum.
http://www.toyota-4runner.org/3rd-ge...n-section.html
They can be a nice option depending on what you use your rig for. I have had them on a couple different rigs - one in the rear and 2 in the front.
Not sure what a gorilla locker is. Once again, truetracs are a great option depending on what you use the rig for. If you lift a tire you do have to fake the truetrac in to locking by riding the brake a little - the threads talk a little more about it.
Most times the best way to get an answer is to post on an existing thread about the topic. Forum is a great resource with lots of topics already covered.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
05-18-2018, 10:10 AM
I've been using a detroit truetrac in the rear of my 97 for a little over a year now. I love it.
When driving on normal roads, you wont even know it's in there.
Only thing you have to be careful of is giving it gas through a corner when its raining or snowing, it can get a little wild.
Other than that, you won't hear it at all and never even know it's in there.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
05-18-2018, 11:32 AM
Real Name: C8H18 Mike
Same thing with my Aussie Locker-locked rear end, if it encounters "traction loss" it locks.
You can learn to live with this or replace tires more often if you insist on doing corner burnouts
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
05-18-2018, 11:34 AM
Real Name: Charlie
Real Name: Charlie
I run Front and rear Truetracs.
I wasn't sure about the front one for a while, if you alignment is out it really antagonises it, plus you get slight "power correction" when steering under power.
Rear is absolute magic. I run a V8 and used to have real traction problems, even on the road, much better now.
I had to recover a stuck van from a muddy field (lol) all 4 wheels were spinning as if locked.
05-18-2018, 11:58 AM
Real Name: Jerod
Real Name: Jerod
Had one installed last month, so far so good. Haven't really put it to the test yet since all the snow melted. Next year!
05-18-2018, 01:40 PM
My plan is to go dual truetracs maybe around the end of the year. I don't do big rocks, so occasionally lifting a tire isnt a concern when a light brake tap (either manually or through TRAC operation) will keep things moving.
Mine: 2002 SR5, Lifted, Armored, and Accessorized on 33s. Build Thread
Hers: 2016 Quicksand TRDP, Lifted 2" on ~32s.
05-18-2018, 02:31 PM
This^
Occasionally a bit of brake modulation is needed with a Truetrac in heavier offroad cases, but 90% of the time it just works with none needed.
05-18-2018, 07:42 PM
I have a trutrac in the front with the factory E-locker in the rear. When I need that little extra going up a ledge it has proven to be helpful. I got a killer deal on mine as I needed to regear and found a used complete front with 4.88's.
Todd:
1997 4runner limited - crawling/camping
http://www.toyota-4runner.org/3rd-ge...ner-build.html
05-19-2018, 10:41 PM
Real Name: Bill
Real Name: Bill
I have been eyeing the LSD truetrac by Detroit. I daily my car so a lsd would be better than a "lunchbox" ratcheting locker.
Does anybody know if it matters if the lsd would work with a 2wd rear diff. Says it fits a 8" diff but not sure if the 2wd is 8".
Hope you guys can help! Thanks!!
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
05-19-2018, 10:51 PM
Yes, your 2WD is considered an 8" Toyota
Sent from my Pixel XL using Tapatalk
05-19-2018, 10:56 PM
Real Name: Bill
Real Name: Bill
Sweet!!! Thank you!!
Not doing a 4wd swap yet so this is the next best thing for me. Been looking at ARB but between the locker, compressor and work it's too costly.
My 4Runner build:
05-20-2018, 12:53 AM
Real Name: Bill
Real Name: Bill
My 4Runner build:
