Old 05-16-2018, 12:41 PM #1
alphyn's Avatar
alphyn alphyn is offline
alphyn will become famous soon enough
alphyn's Avatar
CA Smog: TRD Supercharger CARB Stickers Here AGAIN (3rd Gen)
Numerous threads abound on the Interwebs how difficult and annoying it is to get CARB stickers for first and second gen superchargers for our 20+ year old 4runners. Also, how inconsistent some of the CA Smog test procedures are and what some shops require.
For those of you outside of California or are unfamiliar with the CA smog process, California Air Resource Board (CARB) requires all aftermarket add-ons to be tested and approved for CA emissions. An executive order declares parts are legal. Aftermarket parts manufacturers will provide a sticker to be placed inside your engine compartment identifying the executive order parts fall under. Smog techs will look up the executive order and verify your aftermarket parts are covered as part of the Smog inspection process.
Executive Order for 5VZ-FE TRD superchargers covers several vehicles and both first and second gen S/C's. More on this later.
Penalties for Smog shops is quite high for incorrectly passing vehicles. Penalty is $3,000 and suspension of license for 1-year, so many shops do not want to risk being out of compliance and would rather refer you to a Smog Referee (read more here) than put their shop at risk. Recently, Smog shops have been much stricter needing to see a sticker. Bringing in the executive order alone just doesn't work anymore - at least in the handful of shops I went to in Sacramento.
Requesting a replacement sticker from Toyota is becoming more and more difficult. I've seen mixed results from other threads where dealerships were able to source replacement stickers while others weren't. I called my local dealership and was informed that TRD no longer supplies stickers and I should reference the executive order (Ha! Thanks...). Parts numbers may have been updated and the parts associate at the dealership might have been looking for the wrong part number or had bad info. Who knows?
Backed into an administrative corner (and not wanting to go through the annoyance of finding a Smog Ref), I decided to create my own CARB stickers. Here were the source files I created:
Photoshop: Dropbox - TRD Sticker.psd - Simplify your life
PDF: Dropbox - TRD Sticker.pdf - Simplify your life
Actual sticker size / dimensions are 2.375" x 2.375" with rounded corners and are an exact replica of the original TRD stickers referencing executive order D-425-13. I had stickers printed on vinyl decal material. Sticker easily passed visual inspection by smog tech.
Note: yeah, it really bugs me I didn't put the sticker on straight arrrrgh.
TRD has issued various stickers over the years referencing different executive orders and coming in multiple color combinations (some white on black, others black on white). I chose to replicate the D-425-13 sticker because that was the last sticker Toyota used prior to updating parts numbers for their first and second gen superchargers. I brought in my TRD installation instructions with original parts numbers in case the tech wanted to match up part numbers to what was on my 4runner. Also, it references a later executive order that includes verbiage for a 7th injector and ECU which was not referenced in D-425-4. I had the URD 7th injector kit installed (not CA legal) and was hoping it would pass a visual inspection since it aligned with what the executive order read (it did).
9/10/2019 Update: I was away this summer and was not tending my inbox like a responsible member should. I had quite a few requests for stickers pending. Please PM me or respond to this thread by 9/20/2019 if you are interested in a sticker. I will make another run to the printers if demand is there.
1999 4runner Highlander (Manual)
1993 Nissan 300zx Twin Turbo
Last edited by alphyn; 09-10-2019 at 08:22 PM. Reason: More stickers available if interested.
alphyn is offline   Reply With QuoteReply With Quote
Old 05-16-2018, 01:53 PM #2
nchacon1984's Avatar
nchacon1984 nchacon1984 is offline
Real Name: Nelson
nchacon1984 is on a distinguished road
Real Name: Nelson
nice...hoping to go S/C this winter. How much are you looking at getting per sticker?
nchacon1984 is offline   Reply With QuoteReply With Quote
Old 05-17-2018, 09:58 AM #3
alphyn's Avatar
alphyn's Avatar
$12 with free shipping.
Old 05-17-2018, 10:29 AM #4
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
I have a copy of the CARB sticker for 3RZ supercharged trucks... boy that'd be nice to convert into sticker form. Not nearly as in demand though... still may pursue that for myself.
Good work man, looks nice.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 05-17-2018, 10:32 AM #5
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
I am so glad I moved away from California...
(of course I fear it is following me know...)
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 05-17-2018, 12:47 PM #6
ElysianComrade's Avatar
ElysianComrade ElysianComrade is offline
ElysianComrade is on a distinguished road
Very nice, I'd be interested in picking one up! Did not know URD 7th wasn't legal.. heh
ElysianComrade is offline   Reply With QuoteReply With Quote
Old 05-17-2018, 02:52 PM #7
alphyn's Avatar
alphyn's Avatar
Thank you!
Let me know if you want me to photoshop something and post files. It's fairly easy to find a print shop which can do custom sized vinyl decals.
Old 05-17-2018, 05:22 PM #8
Moderator
Real Name: James
Moderator
Real Name: James
Originally Posted by alphyn View Post
Thank you!
I hope you're serious because I would LOVE that! They are extremely similar in design so hopefully some text should be all you need to change.
4 Cyl carb stickers are simply unobtainable... I managed to get in touch with one of the TRD Engineers, and with his help, the TRD gods bestowed me with the 4 Cyl CARB sticker (well, a scanned copy of it). I photographed it and kept it inside the glovebox.
Back in 2014, someone broke into my truck and stole everything from the glovebox - including my service records and owner's manual! The scanned CARB sticker? Gone forever
Thankfully I kept that photo.... it's the only reason I've managed to get the truck smogged since.
I could seriously kiss your feet if you could help with a file!
Old 05-17-2018, 09:24 PM #9
alphyn's Avatar
alphyn's Avatar
Dude - WTF. Lower than low stealing service records and owner's manual.
Here you go:
PDF: https://www.dropbox.com/s/yo2nfbir8t...icker.pdf?dl=0
Photoshop: https://www.dropbox.com/s/aqfa5sbyg2...icker.psd?dl=0
Belt Routing
PDF: https://www.dropbox.com/s/dvngrbdyvc...uting.pdf?dl=0
Photoshop: https://www.dropbox.com/s/ikkf6zouyd...uting.psd?dl=0
Any local print shop should have the ability to print photoshop or PDF files. Only prob is having to do a minimum order volume. Then you end up with extra stickers like me.
Old 05-19-2018, 04:08 PM #10
Moderator
Real Name: James
Moderator
Real Name: James
Positive rep for you my friend. Fantastic. Now to find a sticker/vinyl shop who'll make them. I'll post back with completed pictures.
Thank you again!
Old 05-20-2018, 12:22 AM #11
alphyn's Avatar
alphyn's Avatar
Thank you again!
Thank you for making me a reputable person!
I updated the routing pic a bit and made the belts darker and moved down the title. Links to files above have been updated, too.
Old 05-20-2018, 11:09 AM #12
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Really great work man!
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 09-24-2018, 06:39 PM #13
gmiyahira gmiyahira is offline
gmiyahira is on a distinguished road
alphyn I'm need of one of your CARB stickers. Can you get into contact with me at [email protected]?
gmiyahira is offline   Reply With QuoteReply With Quote
Old 10-10-2018, 05:23 PM #14
zanes71's Avatar
zanes71 zanes71 is offline
Real Name: Zane
zanes71 is on a distinguished road
zanes71's Avatar
Real Name: Zane
Also wondering if you have anymore. If not I'll get my own printed! Got turned away from 2 smog shops because I don't have a sticker. Got it smogged fine 2 years ago and they didnt even throw it on a dyno
1999 Supercharged Highlander Build
1971 BMW 2002 Touring
zanes71 is offline   Reply With QuoteReply With Quote
Old 10-11-2018, 02:06 PM #15
Oorgle Oorgle is offline
Oorgle is on a distinguished road
carb stickers are not hard to get. just go to the parts dept at the toyo dealer and order one. its $7 and takes maybe a week to show up. I just did this a few months ago. it was a peice of cake.
also, you don't want to get busted with a fake sticker
Oorgle is offline   Reply With QuoteReply With Quote
3rd gen , smog test , supercharger
2nd gen carb/weber marv-aruba Problems & Warranty Issues 0 10-28-2013 04:36 PM
Manifolds/cat with no CARB #, Ca only ktom3001 4th Gen T4Rs 7 10-20-2013 02:44 PM
WTB: 22R Stock CARB got_rwd? Want to Buy/Trade 0 04-30-2013 04:26 PM
TRD 3.4L supercharger engine stickers 24runners Classifieds - buy & sell (no commercial ads please) 2 11-18-2005 05:37 PM
can you carb the 3.0 engine? duanedeidre 4th Gen T4Rs 0 11-04-2003 06:31 PM
