Old 05-17-2018, 02:03 PM #1
2old2soon 2old2soon is offline
2old2soon is on a distinguished road
How to shut off engine from inside engine compartment?
I've been working my way thru my checklist of DIY maintenance items, and next up is going to be flushing out the power steering system on my '99 Highlander. I just finished watching Tim and Sean's excellent video on doing a semi-complete teardown, including cleaning the mesh filter in the PS reservoir.
Here's the YouTube video: https://www.youtube.com/watch?v=5k61KXRK8bM
Since I'd be doing this alone (no helper), an issue I see is that of keeping the reservoir filled with new fluid -- while the 4Runner is pumping the old fluid into a container. The problem, for me, is keeping up with how fast the fluid needs to be added, and then when done, turning off the engine. If I were to quit pouring new fluid, then have to step away and make my way to the ignition key, I know there would be five or seven seconds where the pump would empty the reservoir and the pump would not have any lubrication. As Tim says, this is not good.
Tim discusses this at the 16:00 minute mark.
My question: is there a way to shut off an engine from inside the engine compartment? A kill switch to connect somewhere that I could just flip while standing in the same position as Tim in the video?
I searched Google for 'kill switch', but all those results deal with theft issues and keeping a vehicle from starting the first place. I'm looking for a switch that will shut off a running engine.
2old2soon is offline   Reply With QuoteReply With Quote
Old 05-17-2018, 02:38 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Easiest way I can think of is to unplug your MAF sensor when it's running. Should stop measuring airflow and cut fuel to the engine, causing it to stall.
I take no responsibility for any complications that may arise! It will most definitely throw a check engine light if you do it. It also might be really hard to get it to start again.
326WHP 347TQ
Old 05-17-2018, 04:53 PM #3
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I'm pretty sure it will idle just fine (not perfectly) with the MAF disconnected.
JohnMc is offline   Reply With QuoteReply With Quote
Old 05-17-2018, 05:24 PM #4
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
EFI fuse
EFI relay
Fuel Pump Relay
Good Luck to ya!
SaulG is offline   Reply With QuoteReply With Quote
Old 05-17-2018, 06:58 PM #5
Real Name: Jerod
Real Name: Jerod
It most definitely dies and will not run. Ask me how I know lol!
326WHP 347TQ
Old 05-18-2018, 09:29 AM #6
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
Get a friend to sit in that thing ready to shut it off!
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 05-18-2018, 10:59 AM #7
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
I've read that if you have the key in, battery on, but engine off, you can do the flush just fine.
Just jack the front up with tires off the ground so you can easily turn the wheel from side to side, and it'll force old fluid out as you're turning the steering wheel, but not in between turns, so a whole lot slower than with the engine running.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 05-18-2018, 12:36 PM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Somebody on our YouTube channel claimed the same thing. However, when I tried to use this technique to remove air out of the system after replacing the steering rack, it didn't work so well. We had to run the engine and turn the wheels back and forth to get the air out. But, maybe it does work to move the fluid sufficiently to renew the fluid. It just didn't make much sense to me that turning the steering rack back and forth without the pump running would sufficiently move the fluid through the system.
Old 05-18-2018, 02:04 PM #9
Here's the item I just ordered from Amazon:
UPEOR Auto Battery Disconnect Knife Blade Switch Side Post Side Terminal Car Battery Cut Off Shut Off
Won't leave it on the 4Runner permanently, only when needed.
How to shut off engine from inside engine compartment?-kill-switch-jpeg
Old 05-18-2018, 02:41 PM #10
I_bRAD I_bRAD is offline
I_bRAD is on a distinguished road
Can't say for certain it will cause harm on a 4runner, but generally speaking, disconnecting the battery while the car is running is poor form on modern cars.
@SaulG 's suggestions are cheaper and safer.
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
I_bRAD is offline   Reply With QuoteReply With Quote
Old 05-18-2018, 02:47 PM #11
I've never tried it on a 4Runner, but some other cars I've had will just go into limp mode and keep on running. I'll certainly defer to you on this though.
And I'll second the battery disconnect not being a great idea. The alternator is working with the engine running, if you disconnect the battery it can certainly keep the car powered up. But the battery acts to greatly stabilize the voltage in the system, if it's disconnected the alternator could produce some fairly wide voltage swings. Which could damage electronics.
Old 05-18-2018, 02:52 PM #12
I bRAD - Thanks for posting your comment, and keeping me from doing something... stupid.
Never Disconnect the Battery with the Engine Running
Old 05-18-2018, 03:19 PM #13
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You've got to have somebody that can turn the vehicle on and off a few times for you. It's pretty simple request for anyone. Hell, grab the post man as he walking by. Better yet, ask the hot MILF across the street for help. Same with bleeding brakes. Why buy a power bleeder when all you need is a helper for 10 minutes. I've had my girlfriend help me many times with different stuff, even filming when Sean isn't available.
@StreetCreeper aka Woody lives in Modesto. Maybe he can help you out.
Old 05-18-2018, 05:21 PM #14
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I used the no engine start technique described in post #3 here:
DIY: Power Steering Flush
It works just as described. I can't explain it, but it does. Great if you are solo.
And as far as brake flushes go, I built a pressure bleeder for less than $10, also using some parts on hand.
Here is the DIY on that:
https://www.yotatech.com/forums/f2/3...e-flush-77409/
See my post #21 from 2010. Used it many times since.
With slight changes, and the addition of an empty paint can and some charcoal briquettes, it turns into a smoke machine for air leaks.
Not saying you're wrong @mtbtim , just a different strokes, different folks thing. Also my GF works her tail off with a 20-mile commute and I usually do my car stuff during the week. I won't wait for the weekend unless I have to. The MILF across the street is a *****.
My Backyard Frame Swap
Old 05-18-2018, 09:10 PM #15
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
I’m still out road-tripping for the next week, but if you need an extra hand still when I return — I’d be happy. 😎
"Variety is for your mind, not your body " —OS
StreetCreeper is offline   Reply With QuoteReply With Quote
Loud 'clunk' when engine was shut off? westwind77 5th gen T4Rs 0 05-10-2018 09:57 PM
Is it normal for your engine to move inside the compartment? gumbii 3rd gen T4Rs 17 01-25-2015 09:45 PM
when shut down the engine.......start boiling the coolant! mimorepa Maintenance/Detailing 2 05-02-2011 01:45 PM
FJ vs 4R Engine Compartment redcbs 5th gen T4Rs 5 03-06-2010 04:14 PM
Engine Compartment Same as FJ? liqourish 4th Gen T4Rs 12 08-14-2009 09:35 AM
