06-07-2018, 11:27 AM
Rear Shock Mount Rusted Out
The steel where the left rear shock mounts is totally rusted out and the top of the shock is flopping around. I was investigating an ABS light and the wheel speed sensor wire on that wheel is severed. Had noted some rear end noise so this all makes sense.
Have had my T4R on rust life support for some time....welded the frame twice and the left rear axle strut bracket needs attention (those of you with rust issues know exactly where I am talking about) - had that on the list of things to do. I could drop the fuel tank, weld the bracket (can do it myself) and try to do something with the shock mount on that side but would need to fabricate something and go way back to get to "good" metal. The other side is probably just as bad. Is there anybody out there selling a pre-fabricated mount that I could weld in?
It's like your dog that is getting old and, at some point, needs to be put down but it breaks your heart. Kind of depressed.....
Buckaroo
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
06-07-2018, 11:29 AM
Pretty sure Toyota sells that piece of steel that you can weld in.
@ kolelt
did it I think.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 300k+ Miles
1987 Toyota Supra N/A - Stock, 2nd Owner
06-07-2018, 11:42 AM
@ kolelt
did it I think.
thx...sent him a PM.....Buckaroo
2004 Honda Accord
06-07-2018, 12:20 PM
@ kolelt
did it I think.
Yeah, he did. I found him the part numbers for the weld-in pieces. Let me know if you don't hear from him and I'll look it up again.
My Backyard Frame Swap
06-07-2018, 01:36 PM
Real Name: Scramble
Real Name: Scramble
I love the dog analogy, I've used it before. The big difference is that you can keep fixing the 4runner. My 3RZ is & has been a family member for 19 years. When I did my e-locker axle housing swap I tackled those mounts, cross members & frame rails. Get those mounts from Camelback & weld them in.
Mine only had surface rust, I wire wheeled, encapsulated & top coated.
Edit: I also drilled a second drain hole in the top of the shock mount. The one gets clogged with mud & dirt easily.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
06-07-2018, 02:05 PM
Frame swap or fix it. At this point we need to accept the nature of the beast. Unless it was oil coated its whole life, it will rust from the inside out.
06-07-2018, 08:03 PM
Have not heard yet from
@ kolelt
....if you have time, could you provide P/N's for both right and left side?
thx,
Buckaroo
2004 Honda Accord
06-07-2018, 08:21 PM
In the spirit of teaching a man to fish:
www.toyodiy.com
You can make an account to view diagrams. Search PN's, cross-reference 'til your heart's content, etc.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-07-2018, 10:19 PM
@ kolelt
did it I think.
Sure did. Thanks for the mention.
koltlt 97 sr5 build thread
Page13 has a lot of photos of it. It’s not as bad as it looks.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
06-07-2018, 10:21 PM
Again, thanks
@ TheDurk
for the help. I don’t recall the part #.
06-07-2018, 10:36 PM
Real Name: Scramble
Real Name: Scramble
Originally Posted by kolelt
Again, thanks
@ TheDurk
It's in the thread I linked above.
bracket sub-assy, rear spring, rear rh
51301-35030
bracket sub-assy, rear spring, rear lh
51302-35040
____________
06-10-2018, 10:08 AM
Thanks for all the info....as always, great input. This will be a mid-summer project. Thanks for the install pics
@ kolelt
....they make all the difference.
Buckaroo
2004 Honda Accord
09-05-2019, 04:23 PM
rear shock towers
Did you find where to buy the towers, I am struggling to find
09-05-2019, 05:14 PM
Real Name: Patrick
Real Name: Patrick
Search google for whichever part number you need:
51301-35030
51302-35040
I like Mcgeorge toyota for parts: Toyota Parts | Toyota Online Parts | Genuine Toyota Parts | Toyota Parts Online
