06-09-2018, 08:28 PM
Overheating Uphill...
I have a 2000 4Runner Limited and just recently this behavior started. Going uphill the temp rises, I never let it overheat, I would pull over and let it cool off. It is fine driving on local/hwy roads.
Radiator is about a year old, thermostat was changed at about 170k (currently at 203K). I have a trans cooler to prevent the dreaded pink milkshake. There is no leaks, oil looks fine, fan clutch seems fine, no smoking and no loss of coolant (toyota red).
The thing that I find odd is when I turn it off to let it cool down, when I start it up I get the CEL. The code says the TPS is failing.
My question is, can the TPS cause overheating going uphill? I searched the forums and could not find anything regarding the TPS and overheating.
I may try changing the thermostat but wanted to ask for advice prior..
Thank you in advance.
06-09-2018, 09:03 PM
What does the temp rise to?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
06-09-2018, 09:12 PM
I didn't wait to see how high it would rise but it was about a half cm below red.
06-09-2018, 10:41 PM
I'd get a second opinion on coolant temp- Torque Pro, add-on meter/sender,
IR temp reader, something.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
06-09-2018, 11:09 PM
Second opinion from odb scanner read 248 for the coolant.
Sent from my Pixel 2 XL using Tapatalk
06-10-2018, 02:10 AM
Real Name: Keith
Real Name: Keith
Conventional wisdom:
If overheating while driving(not stopped): Poor flow. Causes: Clogged radiator, clogged somewhere else(less likely), underperforming water pump.
Clogged rad can be caused by mixing 2 incompatible coolants, like orange DexCool and any normal coolant. Happened to me once.
T-stat--- maybe. Replace T-stat with actual Toyota unit.
06-10-2018, 09:06 AM
Originally Posted by lossgenius
I have a 2000 4Runner Limited and just recently this behavior started. Going uphill the temp rises,... thermostat was changed at about 170k (currently at 203K). I have a trans cooler...
It should not get to 248 going uphill or under Any condition for that matter. How much of a hill are we talking about, yet it doesn't really matter, I've climbed many mountains, all at under 200 for both engine and tranny.
So are you by-passed? If so, I highly recommend Against that, trans cooling system was designed to run through engine radiator, extra cooling is fine but not 'Minus' cooling.
T-stat: was it installed with jiggle valve down to 6? They can stick partly Open (or closed depending on how you think of it!), causing over heating or over cooling.
Have you removed the forward skidpan and looked Up between the A/C condensor and radiator? When I off-road where tall grass exists, it manages to clog up the space between the two. Use some kind of thin, long tool to get it out.
Luck.
06-11-2018, 03:38 PM
If you see the needle move from the center position, you are already well on your way to overheating (I've seen engine temps up to 210*F and the needle never moved). With a good running cooling system, it should be nearly rock solid around 187-193*F.
Make sure the thermostat is OEM and the jiggle valve is at 6 o'clock (upside down from the way they are normally installed). There may be other cooling system problems, since overheating is otherwise very rare (air blockage, weak fan clutch, bad water pump, etc.).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-11-2018, 06:22 PM
Real Name: Jerod
Real Name: Jerod
248 means your coolant isn't flowing, that's way too hot for a stock engine to ever get.
Are there any clues, such as after getting up to temp the top hose is hot but lower is cold?
I suspect either stuck thermostat or failed water pump. Try running it without a thermostat and see if that fixes it. Was a common issue for older 4Runners.
06-11-2018, 06:34 PM
I suggest another look at the fan clutch.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
06-11-2018, 08:58 PM
How old is the radiator? If it is more than 10 years, replace it. I had the same issue going uphill in Sierra's and found out the radiator core was clogged with sediments.
If you plan to replace the fan clutch, stay with AISIN or OEM, else expect to hear loud wind noise at all times.
06-11-2018, 10:49 PM
I would say so. The only thing TPS does is meter 'tip-in' for extra fuel when you press on the gas. Basically same job as an accelerator pump on an old carb. But TPS can go in reverse too when you lift. That's all it does, MAF takes care of the rest of basic fuel curve.
So TPS adjusts fuel mixture to be more rich or lean based on what your foot is doing.
Overheating under load... the cooling system is the obvious culprit, and gotcha number one is usually ignition timing, but fuel mixture can absolutely overheat your motor under load.
If your TPS is intermittent it could overheat your motor. Take a look at your plugs should show you if you are running rich or lean.
Just a guess. Others here may be able to comment if overheating from rich or lean might throw other codes too like the o2 sensor stuff. But maybe it does not throw a code because it's expecting it to be rich or lean based on what the TPS is telling it.
Good luck.
06-12-2018, 11:43 AM
Damn.
I had my AT TEMP light go off once. 1998 Automatic transmission with tranny cooler bypass in 2nd gear, 4HI and OD was on - going up a very steep gravel road. I was driving like for for maybe 4-5mins straight crawling, and the light went off.
Thankfully I was at the top of the hill right when I got the light so I shut the engine off, popped the hood and let it cool off for 10 mins.
The coolant and transmission fluid was fresh 2 months prior.
I think I'm going to put a new radiator in and use the radiator + cooler and also add a transmission temperature gauge.
06-12-2018, 05:45 PM
First off I would like to say thank you to all of you that shared your knowledge/suggestions... The culprit was the thermostat.. Thanks again for everything....
I will look into purchasing one of these.
T-stat was the culprit.. it was a OEM installed by the dealership.. I purchased a new OEM one and installed it..
I am bypassed, have been for over a year.. I will look into adding the radiator back into the flow.
This was the culprit.. the thermostat was stuck.. I replaced it and it seems to be back to normal. I ran it up the mountain that I noticed it on and the needle stood below half.. Temp didn't exceed 189
Thermostat was the culprit.. the jiggle was at 6 o'clock and it was a OEM.. Replaced with a new OEM and everything is back normal..
Top hose is hard to squeeze when it was that hot.. stuck thermostat was the culprit.. replaced and back to normal
Good luck.
I will look into this still as it did throw that code.. thanks
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
