06-10-2018, 11:30 AM
Real Name: Justin
Real Name: Justin
Upholstery seat pad restoration
I was talking with a Upholstery guy the other day about redoing my seats and was up in the air about replacing the foam.. Welp figured I'd share the love but there is a way to restore the foam padding without replacing it. U take a steamer and press it into the foam shooting the steam into the foam. Then allow the moisture to dry, I got to witness this and I was blown away... Figured it could save someone some $$$$
Here is a visual for anyone curious
https://youtu.be/5rndD6tzZPo
06-10-2018, 11:47 AM
Well that process might make it 'perky' again, for a while. Maybe.
But in my experience, new skin + new superior multi-stage foam is where its at. Better than new shocks at providing a supple, initially soft yet with underlying firmness for solid support. If you can afford 'to do it right', I highly recommend new foams. See how much your guy can get you into that and have him show you a before/after he may have around his shop. Luck.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
06-10-2018, 01:35 PM
Real Name: Justin
Real Name: Justin
He did mention that ... Talked about shaving the bolster down and adding it those area and then do the steam job on the center portion of the seat. I figured try the steam job out on the passenger seat and the mutli stage on the driver.
06-10-2018, 03:43 PM
Real Name: Instagram: briansd_97r
ABSOLUTELY REPLACE THE FOAM .... and yes with FACTORY OEM Toyota foam.
Trust me, I've done it. Only for the drivers side but it was 100% worth it and felt like a brand new seat.
Do it! And btw I don't think non-Toyota foam is equal and I don't think foam is just foam.
But with all that said I do see that the price of Toyota foam seems to have gone up recently. I think it was around $110 a piece when I bought them a few years ago. $s matter so if you find the aftermarket foam to be good let us know how it turns out.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
06-11-2018, 12:17 PM
Yes I only did the driver's seat, both top and bottom cushions
06-11-2018, 12:35 PM
Real Name: C8H18 Mike
Listen to Brian, your a$$ will thank you
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
06-12-2018, 11:00 PM
Anyone happen to have had a tear in the seat bottom/pan? I have an 01 SR5 with what appear to be Limited seats.. maybe not, but they are perforated leather. I'm wanting to replace the bottom skin with a factory piece if I can but my searched online have not been successful. Seems like there are just out of stock everywhere.
I'd go the junkyard/pick n pull route, but with only 96k miles on this 01, I'm betting I wouldn't find a used skin in decent shape.
Anyone in this particular thread have any input as to where I might be able to source and OEM skin?
06-12-2018, 11:23 PM
Did the 01-s ship with perforated leather?
My Acura TL. Yes.
06-12-2018, 11:54 PM
The '01 Limited that I had briefly didn't have perforated cow skins, it looked identical to the cow skins in my '99 Limited.
06-13-2018, 01:01 AM
Ebay seller hotrod leather sells bottoms and has you videos on how to replace.
hotrodupholstery-com
2018 4runner Limited Magnetic Grey 3rd Row N-Fab Nerf Bars: Needs TRD Grey w/ KOs; tint;
1996 4runner Limited Sand Dune: Needs lots
06-13-2018, 09:27 PM
Real Name: Justin
Real Name: Justin
OEM skins no but I am considering doing a different approach with my leather. I am looking to replicate this color and texture.
06-15-2018, 05:46 AM
Real Name: Robert');DROP TABLE Students;
Are those foam part numbers the same for cloth seats? I can't imagine they'd be different, but you never know..
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
05-12-2024, 06:56 PM
I purchased synthetic seat replacement covers from hotrodupholstery for both front seats in Jul-2022. It was quite a fun learning experience getting them on and they turned out great, just as so many have said. Fast forward to almost 1.5 years later and I have cracking on the driver seat side nearest the door. I only drive the 4Runner 3 days a week and weight 145 lbs. I've emailed Ed Wolfman's twice now on his icloud account from his website with no reply. Tried calling the number and voicemail box is full. I left comments on his YT installation videos on my concern, asking him to contact me, but comments keep getting removed. Feeling quite bummed that this didn't last much longer after spending $600+ to get them. Anyone else have this issue?
05-13-2024, 07:54 AM
Does this really surprise you? Synthetic leather = Vinyl. It's the material they used for seating in the 1989 Chevy S10 for selling in fleets to Roto-Rooter. He would likely give you the run-around even if he did answer you.
05-14-2024, 11:48 AM
I have had the same experience. The cost and labor of replacing the seat covers again, even with me doing the work is daunting.
