Old 06-26-2018, 12:46 PM #1
hyken's Avatar
hyken hyken is offline
hyken is on a distinguished road
hyken's Avatar
Undercarriage Refresh
I've got a long road to hoe with this one, but I'm hopefully starting a whole front-end undercarriage refresh as it's all rusted to hell. I've got stuff leaking, broken, whining, grinding, and wobbling all over the place, so it's long overdue. If anything it just speaks to how much abuse and neglect these trucks can take - they're perfect for poor people like me.
That said, here's a list of things that need servicing:
• Wheel bearings
• CV joints and spindle (basically the whole knuckle on the passenger side)
• Steering rack
• Tie rod ends
• All bushings
• LBJ
• UBJ
• All brake components
• Both differentials
• Transfer case
• Of course suspension and top mounts
•And don't forget all the rusted hardware that will be impossible to get off, much less use again.
To start, I'm going to replace the wheel bearings because my passenger one is throwing grease, noise, and EATING that tire. While I'm in there, I'm going to replace that CV, seals, rotor, and caliper as well. Anything else I should do while I'm in there?
As I said, this is a long road ahead, but I'm too emotionally attached to this truck to just let it go.
1999 SR5 4wd all stock!
Broke as a trail horse.
hyken is offline   Reply With QuoteReply With Quote
Old 06-26-2018, 02:15 PM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
• Wheel bearings
• Steering rack
• Tie rod ends
• All bushings
• LBJ
• UBJ
• Transfer case
One item to check is the needle bearing in the diff on the driver's side. That's a known weak point and given how trashed the rest is may well be suspect. I just replaced mine with a solid bushing from East Coast Gear Supply and the return to smoothness is clear. It can be changed with the diff in place once the CV is out.
https://eastcoastgearsupply.com/i-14...e-bearing.html
The passenger side has a beefy ball bearing and should not be an issue.
My Backyard Frame Swap
Old 06-26-2018, 03:49 PM #3
hyken's Avatar
hyken's Avatar
@TheDurk I will definitely be replacing that as well (even at $60, yikes!). I'm wondering just how far into the diff I should replace. It seems like everything from the hub into the clamshell needs to be replaced... is that reasonable, too much, or not far enough. Looks like gear oils been leaking around the clamshell too... I'm thinking axle seals at the least?
Old 06-26-2018, 07:34 PM #4
TheDurk's Avatar
TheDurk's Avatar
Seals and that one bearing should do it. If you mean it is leaking at the clamshell junction itself, that is something else. That would mean pulling the diff, which is a PIA. Timmy the Toolman has a video.
Old 06-27-2018, 08:38 AM #5
hyken's Avatar
hyken's Avatar
@TheDurk I don't think it's the clamshell itself, so it must be either the seals or - I've been reading about this - the breather tube can get clogged or pulled off the top of the diff. Any experience with this or how to fix it without removing the whole diff?
Old 06-27-2018, 09:44 AM #6
TheDurk's Avatar
TheDurk's Avatar
Sorry, no. Sometimes it can be the power steering system leaking on to the diff. Very different smells and colors if you get some on a paper towel.
Old 06-27-2018, 01:21 PM #7
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Baby powder is amazing.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 08-15-2018, 08:42 PM #8
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
I'm about to buy this. Do I need the install and/or removal tool they are selling with it?
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 08-16-2018, 11:20 AM #9
beefsix beefsix is offline
beefsix is on a distinguished road
thanks for making this thread, been looking for one like it as im planning to do about the same thing. no rust, but all bushings could use a refresh and everything down there could use some service.
beefsix is offline   Reply With QuoteReply With Quote
Old 08-16-2018, 04:32 PM #10
TheDurk's Avatar
TheDurk's Avatar
You need SOMETHING. I have a blind slide puller that worked great.
This one:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Very useful piece of equipment.
To install, I used an inverted socket.
If you don't have a puller, you'll have to invent something similar to their tool.
bearing , bushings , cv joint , steering , wobble
Suspension refresh on 05 SR5 ThatSickRip 4th Gen T4Rs 7 12-21-2017 09:06 PM
5th Mid-Life Refresh Wakeborder556 5th gen T4Rs 27 07-20-2012 03:01 PM
04 4th gen with 07 or newer refresh??? Hair2burn 4th Gen T4Rs 8 02-27-2012 11:50 AM
mid-life refresh halfmonkey 5th gen T4Rs 53 09-22-2011 05:28 PM
A/C Refresh gizmopt2002 4th Gen T4Rs 10 06-21-2007 06:28 PM
