Old 07-07-2018, 11:33 PM #1
PowrPly's Avatar
PowrPly PowrPly is offline
PowrPly is on a distinguished road
PowrPly's Avatar
Can I use 881's with KYB Gas-A-Just struts?
Don't shout me down! I've been digging on this site and others for an hour now and can't find the answer to my question. By my measurement, I'd have to compress the 881 about 3.25" to expose enough thread on the strut to get the strut plate on. That doesn't make any sense to me. Why did I buy this tall coil just to compress the tar out of it?
I bought the coils from Travis at Wheeler's Offroad and told him I'd be using KYB's. He recommended the 881's.
Current set up:
2002 Sport Edition (288,000 miles and all mine!!)
Front: Monroe Quick Strut - Fender to ground - 35.5"
Rear: KYB Gas-A-Just with Raybestos Coils - Fender to ground - 34.5"
The KYB's are new last fall; one of the rear Monroe's snapped off during a grouse hunt.
So, do I...
A) Assemble and install, it will work just fine.
B) Get different springs
C) Get different struts
Thank you!
Can I use 881's with KYB Gas-A-Just struts?-kyb-jpg
PowrPly is offline   Reply With QuoteReply With Quote
Old 07-08-2018, 01:24 AM #2
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
It'll work well when you assemble it. The spring is longer than the shock so that it has some preload once it's assembled, that preload is what's going to give you a higher ride height.
Overall the assembly will be the same length as it was with the stock springs on it, but the new coils will not compress as far with the weight of the 4runner on them, so the shocks will end up being about 1.5" further out in their stroke at ride height, giving you 3" of lift.
Sent from my Z981 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 07-08-2018, 09:36 AM #3
PowrPly's Avatar
PowrPly's Avatar
Thank you!
Ok, one more question for you. Can you tell me the order of assembly for the bushings and washers on the strut? I marked the photo with my guess. The close up of the strut plate shows why I’m guessing I don’t need the smaller bushing and the other washer.
Thanks again!
Can I use 881's with KYB Gas-A-Just struts?-67ce5ffe-c82b-48df-8c90-628ab9bcada2-jpg  Can I use 881's with KYB Gas-A-Just struts?-4af57331-2124-4cd0-bade-a7e2ee355173-jpeg
Old 04-16-2021, 07:09 PM #4
BobsonDugnut BobsonDugnut is offline
BobsonDugnut is on a distinguished road
Hi PowrPly
Did you end up getting the 881's installed with your KYB struts? I've tried looking all over the web for this combo's ride quality.
I'm about to do the same and wanted to check how the ride quality is.
Thanks in advance!
BobsonDugnut is offline   Reply With QuoteReply With Quote
Replacing Original Struts, Springs with "Quick Struts" azcat90 3rd gen T4Rs 4 06-13-2014 06:06 PM
Where can i buy 883 struts Park 3rd gen T4Rs 8 05-13-2014 04:34 PM
struts for 2.7 same for 4wd and 2wd? iowajosh 3rd gen T4Rs 5 09-05-2011 07:44 PM
