07-17-2018, 11:38 AM
P0171 code
I got this code recently “bank 1 system to lean”
I cleaned the maf, code went away and the. Returned. I replaced an AF SENSOR years ago when I got this code and I’m thinking it’s either that sensor again.
Can someone tell me which sensor this would be, I just want to make sure it’s the right one?
07-17-2018, 12:22 PM
Real Name: Austin
Real Name: Austin
My dad recently got the same code is in his 01. It ended up being that his gas cap wasn’t on tight enough.
1997 4runner, OVER 360K miles, Bilstein 5100 and FJ80 suspension, Polaris light bar, custom full length roof rack, plus some interior mods
I've had more 3rd gens than I can count at this point
07-17-2018, 12:27 PM
Check all the vacuum hoses, too.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
07-17-2018, 12:33 PM
Is this a cali emissions truck, or federal emissions truck?
"Bender" Silver 99 Limited with e-locker.
07-17-2018, 12:55 PM
No offence, but this doesn't make any sense. P0171 means that the engine is either getting too much air or not enough fuel. A loose gas cap would throw an Evap code, not a Lean code. If you cleared the code then it might not necessarily come back right away. How long ago did this happen?
As far as the OP's question, P0171 in my experience is not usually a sensor issue but it's possible.
The most common issue is a cracked/broken intake or vacuum hose AFTER the MAF sensor - this sensor reads the incoming air and tells the ECM how much fuel to spray from the injectors, so if there is a leak after the MAF then there is unmetered air getting into the combustion chamber - too much air/not enough fuel.
Now, since there is only the single code for bank 1, there are a couple different things. Either both banks are lean, but the data list parameters haven't quite hit the limit to throw the code for bank 2 - OR the lean condition really is limited to bank 1 after which point I would check the intake manifold gasket for bank 1 to make sure it hasn't torn.
These aren't the only options but just food for thought, obviously check for any exhaust leaks close to the O2 sensors.
Good luck!
07-17-2018, 01:46 PM
Forgot to mention....TERRIBLE GAS MILEAGE
07-17-2018, 01:59 PM
I have been chasing this code since October and have done almost everything to try and get rid of it. I have changed out the upstream o2 sensor and replaced the MAF with a denso one. I have checked all vacuum lines and they are good to go. I also have cleaned everything thoroughly to ensure no grime in places it shouldn't be. Only thing left for me to do is change out the downstream o2 sensor. Mine is supercharged
2000 millennium silver limited, TRD 1st gen supercharger, Toytec/eibach 3"springs, Tundra 5100's,LC 8 wraps w/ bilstein 5125's, 285/70/17 toyo mt's on FN FX Pro in matte bronze
2015 Harley FXDB 103, cams, thrashin supply pipe, vance and hines tuner, LED lights all around
1st gen, 4 inch lift, 35/12.50/15 goodyear MT/R, GONE
My build http://www.toyota-4runner.org/3rd-ge...ml#post2828875
07-17-2018, 02:07 PM
I was getting this one for awhile as well. The first time I cleaned the MAF sensor, it came back. I had forgotten to clean the other two small wires inside the sensor. Once I did that, it has stayed off for quite awhile.
07-17-2018, 03:03 PM
He has an A/F sensor, so Cali.
My Backyard Frame Swap
07-17-2018, 03:06 PM
Good luck!
Doing good until the bold. Our 3G 4Runners only have Bank 1 exhausts, so only the single lean code. There is no Bank 2 lean code. 4th gens have dual exhaust and a Bank 2 lean code.
P0171s are indeed usually MAF issues or leaks. But after ruling those out, I did clear mine with a new A/F sensor one time. Sometimes cleaning is not enough and you need a new MAF. I hate P0171s.
07-17-2018, 03:28 PM
official vendor
official vendor
Here are possible issues.
Diagnostic Codes
P0171
Confirmed Fix
225 - Mass Air Flow (MAF) Sensor
9 - Engine Air Filter, Mass Air Flow (MAF) Sensor
4 - Oxygen (O2) Sensor(s)
2 - Fuel Pump
1 - Front Oxygen (O2) Sensor
1 - Vacuum Leak
1 - Fuel Injector(s), Mass Air Flow (MAF) Sensor
1 - Cruise Control Vacuum Line
1 - Intake Manifold, Mass Air Flow (MAF) Sensor
1 - Mass Air Flow (MAF) Sensor, Throttle Body Cleaning Procedure
1 - Mass Air Flow (MAF) Sensor, Mass Air Flow (MAF) Sensor O-Ring
1 - Exhaust Pipe, Mass Air Flow (MAF) Sensor
1 - Air Intake Tube
1 - Air Fuel Ratio (AFR) Sensor
1 - Engine Vacuum
1 - Oxygen (O2) Sensor, Bank 1 Sensor 2
07-17-2018, 04:21 PM
i had this code on my 2007silverado classic and it ended up being a vacuum leak in the break booster. Replaced it and have not thrown a code since.
Id run a smoke test if you could. That's how we found the vacuum leak in my brake booster that plus a nice hiss when they engine was turned off coming from the booster.
07-17-2018, 04:22 PM
Diagnostic Codes
P0171
Confirmed Fix
2 - Fuel Pump
1 - Vacuum Leak
1 - Air Intake Tube
1 - Engine Vacuum
I wish I could get something like this for a P0172 code. where did you find this information?
07-17-2018, 04:37 PM
Fair enough! In my defense, I don't actually own a 3rd gen yet LOL, so I was not aware of the single exhaust. I was just going off my experience as a Lexus master tech for the last 5 years. So there is only one cat and one sensor? Unlike the 3MZ engine which as 2 cats, one off each exhaust bank.
It very well could be a bad A/F sensor, just wouldn't be the first thing I would replace. Trust me, I hate P0171s as well! It's either really simple or very complicated.
07-17-2018, 04:45 PM
Good point! I had a car I was working on in the shop once but it had both banks lean codes. All the data list numbers looked way off, all hoses were perfect, but the red flag was the brake pedal was very stiff due to a bad brake booster leaking air back into the engine.
