09-28-2014, 08:35 AM
Real Name: Robert
Real Name: Robert
Clicking sound while decelerating?
Lately I've been hearing a clicking sound at low speeds while decelerating. I only hear it when I'm slowing down, either while on the brakes or just coasting. Typically I hear it when slowing down for stop signs, red lights, or making a turn. If I get back on the gas even the slightest bit, the clicking sound stops, and returns as soon as I let off the gas again. I only hear it at slow speeds. The speed of the clicking is proportional to the speed of the vehicle. The sound is like a click or very small pop.
Bad u-joint(s) most likely? '99 Limited 4x4, 260,000 miles.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
09-28-2014, 09:45 AM
Check your CV's. Most likely dry and worn out.
18 Audi A6 3.0T - APR Tuned, RS6 Interior 19 Audi A6 3.0T
09-28-2014, 10:32 AM
Real Name: Robert
Real Name: Robert
Wouldn't the CVs make noise under all conditions, instead when I'm slowing down only?
09-28-2014, 01:31 PM
Not necessarily. Put it in 4 high and see what it does.
09-28-2014, 06:39 PM
Real Name: Robert
Real Name: Robert
I'll give it a try tomorrow morning. When I roll my windows down, it sounds like it is coming somewhere from the middle to rear of the vehicle.
09-30-2014, 10:28 PM
Real Name: Robert
Real Name: Robert
Forgot to update the thread. Sound is still present in 4wd. Greasing the driveshaft helped reduce the clicking, but it is still there.
09-30-2014, 11:06 PM
I have the same noise, on the same situation, and still looking for some answer! I ride with this noise for now 20 000 miles (Off-road, long distance...), no problem but still curious what it is so Anybody have an answer for this?
09-30-2014, 11:11 PM
Real Name: Bryan
Real Name: Bryan
The u-joints on the driveshaft need to get replaced, that's why greasing the driveshaft helped with the noise.
2000 Toyota 4Runner Base 2wd - Sold
1999 4Runner SR5 4x4 - Tundra Brake Upgrade- 2nd Gen Supercharger - 7th Injector - 32'' BFG KM2 Mud Terrains - ELocker - 4xinnvations Front Bumper
01-08-2016, 12:02 AM
I have this problem too so I'm wondering if you had to replace the U-joints or did you resolve this some other way?
07-12-2017, 11:19 AM
I'm having this same sound on my 01 4Runner SR5 2WD. It has 295K miles on it and I just had both U joints replaced and the sound is now a little worse. You'd swear I was driving the Wheel of Fortune! The sound happens when coming to a stop whether in Drive or Neutral starting at 20 mph and slower. It's loud enough to be embarrassing. Anyone figured out what the problem is?
07-12-2017, 11:43 AM
I have the same issue with my 01 2WD Sport. Greased the u-joints and no change.
Can it be the rear wheel bearings?
07-12-2017, 12:05 PM
That thought crossed my mind. Gonna bring it back to the shop because after the u joints were replaced I now get a vibration that starts at 20 and gets so bad I can't go above 75. Drive shaft out of balance? They said it can only go on one way but something is clearly wrong. I'll see if they can lube the rear while they are at it.
07-12-2017, 12:20 PM
Real Name: Scramble
Real Name: Scramble
Wheel bearings make a constant whine, metal on metal spinning.
My guess is u-joints for everyone in this thread. If greasing didnt help then they need to be replaced with OEM not auto part store junk.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
07-12-2017, 12:23 PM
If you didn't mark your shaft at the spline then yes it could be out of balance. The spline will go back in at any rotation, but they are balanced for a certain position. See if there are any paint marks that may help you to line it up (mine still has some from either the factory or a previous owner repair).
- 2000 4x4 Highlander SC
07-12-2017, 12:39 PM
Thanks for the responses. I'll check for marks when I get a chance. As far as the ujoint brand, I went with AutoZone Duralast. Used them before but definitely not the best. How are Moog ujoints?
