Old 07-29-2018, 03:58 PM #1
Texas_4Runner Texas_4Runner is offline
Texas_4Runner is on a distinguished road
Rust issue
My friend just bought this 99 4runner and didn’t catch this spot.
I’ve never had rust like this on a vehicle. What are your thoughts?
How bad is this? Is this even fixable?
Rust issue-d2b7bb38-0c6e-45d7-a93d-a3cd86cca349-jpg
2008 V8 LTD
Texas_4Runner is offline   Reply With QuoteReply With Quote
Old 07-29-2018, 04:47 PM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Stick a fork in it.
If you don't do preventative rust regiment, this is what happens.
Frame is probably thin in a bunch of spots besides the obvious big holes, I'd scrap it.
Sent from my SM-N920V using Tapatalk
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 07-29-2018, 05:03 PM #3
theriddler's Avatar
theriddler theriddler is offline
theriddler is on a distinguished road
theriddler's Avatar
Wow that's scary...i patched a frame once on a 4runner but it wasn't nearly that bad. It was a pain in the butt for the small section i welded in so i'd say that frame is beyond repair and wouldn't be worth the trouble. Sorry about that. I'm never buying a rust bucket again, I'm fixing one myself right now and i'm about over it
2002 4Runner Sport Edition-285/75R16 Duratracs, OME suspension, TRD wheels, Shrockworks front/rear bumpers, White Knuckle sliders, etc.
theriddler is offline   Reply With QuoteReply With Quote
Old 07-29-2018, 05:20 PM #4
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Yeah mine had lots of rust too, nothing too deep but widespread so it's fully repairable. The body and frame are still in good shape. A PITA to fix though, I can think of better things to do with my life. But otherwise a good truck.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 07-29-2018, 08:59 PM #5
nissanh nissanh is offline
There are patch kits made of thick metal for sale on ebay. Simply place it and weld. Do rust prevention from day-1.
Old 07-29-2018, 10:18 PM #6
Moonbandit Moonbandit is offline
Moonbandit is on a distinguished road
Don't scrap it.
Get it patched - I've seen much worse from that area.
Cut that stuff out asap and grind/wirewheel the rust off before any welding. Otherwise it is just a visual bandaid. Then do some rust treatment with por15
Just poke all the other areas of the frame just to make sure it is not a widespread problem.
It won't be a beauty queen but it is likely that a good welded patch will outlive your truck.
Moonbandit is offline   Reply With QuoteReply With Quote
Old 07-29-2018, 10:22 PM #7
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Wait until that breaks off while you're driving. (Hint: You can brake, slowly, but DO NOT accelerate!) BTDT. As to the fix, see the link in my sig below. I did it, but I don't recommend it. I wouldn't do it on a newly bought truck. I have 19 years of bonding with mine and I'm retired, so I had the time and the motivation. Patient is doing fine, by the way..
Yours actually looks much worse than mine did. It rusted from the inside out, so I was taken by surprise.
My Backyard Frame Swap
Old 07-30-2018, 01:20 AM #8
Originally Posted by Moonbandit View Post
Don't scrap it.
What about this spot? I’m no expert but I’m not sure you can patch this. Or am I wrong?
Rust issue-9098d359-03c5-47ce-9eea-e7bc3459b0f4-jpg
2008 V8 LTD
Old 07-30-2018, 01:47 AM #9
theriddler's Avatar
theriddler's Avatar
It's amazes me how the rear link can hold up to that kind of rust and not have already broken off, that being said it can be fixed like anything else. I wouldn't drive it until the frame is repaired and don't coat it with anything either...that will just make welding a patch harder.
It's up to how much work your friend is willing to put into it, I have dealt with the personally have for that reason my next 4runner is coming from a road salt free state. Rust is an ongoing problem with broken bolts, replacing parts, crap in your eyes when working on it, etc. It is deceiving on these how the bodies are rust free and the frame is gone, pretty much opposite of the every other brand on the road.
Old 07-30-2018, 07:59 AM #10
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
I bought a 2000 just for parts, the whole frame fully fully repaired, still not worth being a keeper. Runs great too. Photo at purchase and present chopped condition. Here's a weld patch at the drivers side LCA bracket, there are other patches also.They just let it go too far and I didn't feel it was worth all the work to fully restore it, and I'm talking just rust repairs. It's a shame cause it was a beautifully truck, awesome color, trim package and 5 speed. Just plain NEGLECTED, totally preventable.
I guess anything can be repaired if you're willing to put in the work, can swap out frame too. Weigh your best options.
Old 07-30-2018, 08:54 AM #11
feta feta is offline
feta is on a distinguished road
well
Didn't catch the spot? More like didn't look under truck. Hard lesson to learn.
We all know that is the part that hold the rear axle in place. It will never be right again, the truck is compromised. What other parts are compromised that your buddy can not see?
I had the drivers side break off when I was driving years ago. Got rid of it, decided it wasn't worth my life if I were in an accident.
Maybe younger me might have fixed it, but I like to think the current version of me is a little more wise.
feta is offline   Reply With QuoteReply With Quote
Old 07-30-2018, 09:25 AM #12
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
I'm going to give you some insight on the other end of the spectrum. This rust spot is a well known issue with 3rd gens as the heat from the muffler (without any sort of shield plating) causes advanced rust corrosion on and forward of the rear right LCA bracket. Seeing your picture, I can tell you that a good majority of the frames in the midwest/rust belt have at least this much of a hole in their frames, and it doesn't have a large structural impact on your rear axle support/placement.
What I am saying is this- I cannot stand scrapping or giving up on any vehicle that can easily and safely be fixed. There is a reason why some Toyota dealers (for enough money) fix these frames professionally; they wouldn't touch the frame is they thought the entire frame was bad. Please check your pinch welds/cross members/other low hanging frame locations before making the decision, but I highly doubt you will find any other spots showing structural corrosion.
Heck, my rust hole was easily twice as long and eating through the entire bracket and I fixed it. To each his own.
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 07-30-2018, 02:22 PM #13
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
Originally Posted by apohl17 View Post
, I can tell you that a good majority of the frames in the midwest/rust belt have at least this much of a hole in their frames.
Nope not close
Arnezie is offline   Reply With QuoteReply With Quote
Old 07-30-2018, 03:25 PM #14
I say it isn't worth scrapping. Pain in the ass it is though. Probably looking at 700-1000$
I wouldn't drive it if the control arm is about to break off FYI. Very dangerous. Like super scary dangerous.
You're not going to race the thing.
It won't break off if properly welded.
But some folks are anal about their 4runners and only want the best of the best. Who doesn't?
All depends on one's level of tolerance.
That being said - you can't have mickey mouse welds.
The blue 4runner's welded patch looked mediocre though hard to tell. Shame it went to the crapper.
Old 07-30-2018, 09:38 PM #15
A2toHgt A2toHgt is offline
A2toHgt is on a distinguished road
This is some astonishingly bad advice. The trailing arm locates your rear axle- If it breaks while driving, this is a profoundly dangerous situation! There's another thread from today about how a jury awarded millions of dollars to the family of a young woman who died in an accident due to the suspension failing from rust. The peanut gallery is trying to poke holes in the family's story, but the article mentions 60 (!) reports to NHTSA about this issue and 7 rollover crashes. In other words, this is not an isolated incident.
If I were in your shoes, I would get this fixed ASAP. My car had this same issue- Luckily I found out before it failed. The good news is, it can definitely be fixed.
A2toHgt is offline   Reply With QuoteReply With Quote
What to do with our '98 SR5 (rust issue) marcumac General Discussions 15 04-10-2015 08:27 AM
Radiator Rust Issue muddyRUN 3rd gen T4Rs 1 09-24-2014 08:38 AM
Rust issue mordad_2000 3rd gen T4Rs 2 04-09-2014 03:01 PM
Is frame rust an issue in Alberta? Tony1M 5th gen T4Rs 14 03-29-2012 04:53 PM
4 Runner Rust Issue Razor128mh Problems & Warranty Issues 5 11-02-2011 09:40 PM
