Old 08-02-2018, 07:55 AM #1
PhdNPrerunners's Avatar
PhdNPrerunners PhdNPrerunners is offline
Real Name: Justin
PhdNPrerunners is on a distinguished road
Real Name: Justin
Replacing Head Gasket on High Mileage Motor
Hey guys I am considering picking up another 4runner as a project and wanted to get some opinions on if I should replace the head gasket or try to find a low mileage used motor? The 4runner I am looking at has 316k miles and the current owner said that it has a head gasket leak but never over heats. I'm afraid it might be a waste of money just to replace the head gaskets on a such a high mileage motor. Do you guys think I should replace the head gaskets on the current engine? Thanks
PhdNPrerunners is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 08:40 AM #2
Toyotayoda's Avatar
Toyotayoda Toyotayoda is offline
Toyotayoda is on a distinguished road
Toyotayoda's Avatar
I've seen a few instances on the 5vz, where coolant leaks externally from the head gasket. It's not a terribly complicated repair, and would give you a great reason to replace the valve stem seals and make sure the valve clearances are still correct, any good machine shop can do it reasonably if you don't feel confident enough to do it yourself.
Toyotayoda is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 09:31 AM #3
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
I'd repair your motor. When you buy a used one you have no idea what you're getting yourself into.
Silver Supra is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 09:49 AM #4
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
The OP is thinking about picking one up that he does not really know the history to either except that it has 316k miles. This means it was probably decently cared for to get that milage, but it is still nearing the end of its life. Totally depends on what your long term plans are. If your going to sell it just fix the head gasket as it will be less work and money. If you are going to keep it do a compression check and find out how good the rings and valves are. If I was going to keep it I would throw another engine in there, its more time and effort but a better chance of long term usage.
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 10:05 AM #5
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
I'd rebuild, but know, you'll end up doing more than expected.
I have a rebuilder 3.4 if you're interested. Should be pulling it out soon to put the one I'm rebuilding in. Claimed to be 60K mile motor but i opened the VCs and it was full of sludge so i would definitely rebuild. Would just have to figure out a way to get it to the woodlands.
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 10:11 AM #6
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
A JDM engine is like... $800?
Old 08-02-2018, 10:31 AM #7
Joelzy's Avatar
Joelzy's Avatar
true, but if possible, pop the valve covers off and have a look before buying. the JDM replacement that was in my runner when i bought it had the worst sludge i've ever seen.
–02 bmw 540i6
–19 Highlander SE
Old 08-02-2018, 10:38 AM #8
T4R2014's Avatar
T4R2014's Avatar
Definitely. It's still a used engine.
Old 08-02-2018, 10:46 AM #9
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The one he is currently buying has a known problem, and a fairly large job at that. He still gets to wrestle with the exhaust manifold.
I'd lean the other way and look for a used engine. An engine swap is easier than a head gasket.
326WHP 347TQ
Old 08-02-2018, 11:14 AM #10
Real Name: Justin
Real Name: Justin
Thanks for all the input guys! The guy I am purchasing it from has owned the 4runner most of it's life and he said he was keeping up with the maintenance on it. I find it a little weird that it doesn't overheat with a bad head gasket.
It does sound like replacing the engine is a better option than just fixing the head gaskets, especially since I plan on keeping it for a while and driving it a lot.
Old 08-02-2018, 11:46 AM #11
Real Name: Jerod
Real Name: Jerod
Everyone says they kept on maintenance if there's someone willing to buy. The guy I bought mine from said the same thing. Took a look at it and noticed the fluids were bad. When I got the oil changed guy said the oil in it was the blackest he had ever seen. Plus the transmission fluid was burnt, and the entire suspension was causing the tires to go bad.
You won't really know for sure all the things that are wrong until you own it.
326WHP 347TQ
Old 08-02-2018, 12:05 PM #12
Coward's Avatar
Coward Coward is offline
Coward is on a distinguished road
Coward's Avatar
Perhaps it needed the head gasket recall and it was never done? Mine leaked externally before I had it done at 120,000 miles. Now I did rebuild my heads after I managed to burn a valve at 360,000 mile mark. Best thing that ever happened. It runs like a new truck now. If the oil looks good, there is no sludge, and the compression check is fine I would have the head work done.
PS- If any of you guys have high miles and pinging issues. I highly recommend getting the carbon buildup cleaned out. Not talking Sea-Foam here. Has anyone tried walnut blasting? Seems way easier than pulling the heads.
96' 4x4 5spd-SS1.2
Coward is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 12:25 PM #13
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
We did a head gasket in a 4runner my brother picked up, although this was a clearly abused 4runner, it taught us a lesson. 70 miles after the head gasket was done the bottom end went. I'll never make that mistake again.
Sent from my Z981 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 12:50 PM #14
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I would at least pull the plugs on both banks and remove the valve cover on the passenger side to get a visual check on just how healthy this engine is.
If you have access to a leak down tester and a portable compressor, that would be even better.....
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-02-2018, 01:20 PM #15
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
If owner says it has a problem but the details are scare I wouldn't assume for sure that the issue is as simple as the head gaskets. It could be any number of things with those miles. Like LittleCaesar said a leak down test should give you a better idea. If you are like me and don't have access to one a shop should be able to do this fairly cheap.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
help replacing head gasket sidjitsu 4th Gen T4Rs 6 07-22-2015 04:38 PM
Replacing head gasket - need parts help iBison 4th Gen T4Rs 10 06-03-2015 02:10 PM
New motor? Which Motor? Gasket Repair? Draayer 3rd gen T4Rs 13 03-09-2013 04:51 AM
Replacing head gasket help.. howie1996 New Members 1 12-31-2010 04:22 PM
replacing head gasket, any suggestions? saydarlingsay Classic T4Rs 2 09-20-2007 06:56 AM
