Old 02-25-2020, 03:29 PM #1
SR5_4Runner SR5_4Runner is offline
SR5_4Runner is on a distinguished road
Starting problem in cold weather - does not crank then fires up just fine
Hi all. First post. I’ve done some searching but nothing seems to exactly match the issue so hopefully someone has seen this before and can offer advice.
First, background info:
1999 SR5 with 4WD and automatic transmission (207k miles). Mostly stock with aftermarket stereo head unit, Webasto sunroof and exterior light bar (added in early 2000s). Only other issue is minor; Toyota remote fob operates the locks but I’ve been unable to successfully program a second fob.
Vehicle runs and drives great and most of the time there are no starting issues. However, when the weather gets ‘cold’ (sub 40 F) it can become difficult to start.
Symptoms are I turn the key to start and all the usual warning lights illuminate on the instrument cluster, but the engine does not crank. Keep holding the key on start for many seconds and eventually the starter spins and the engine immediately fires up just fine. After that if I turn off the engine and restart the engine usually starts up fine.
If the car sits for a few days in cold weather this starting problem repeats. Local indy shop (specializing in Toyota) has looked at it and so far is unable to pin down the issue. But since it was cheapish to do we replaced the starter circuit relay last fall but based on ongoing issue that gamble didn’t payoff.
Battery is newish (under two years), high capacity, and tests fine. When this issue happens everything else electrical is working fine without engine running.
Most of the time the CEL is off. But a couple of times CEL has illuminated after this starting issue occurred. Codes were for cam/crank position sensor, but shop has thoroughly tested and these seem ok. Plus after a drive cycle the CEL goes out and stays off even after multiple reoccurrences of this cold start problem.
And the icing on the cake is that even in cold weather this starting issue is not happening all the time. Sometimes it starts several mornings in a row, and then one morning it just decides to act up. Cold weather seems to be the only common factor as no starting issues rest of year.
So... has anyone encountered this problem before and if so how was it resolved?
Thanks!
SR5_4Runner is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 05:00 PM #2
Starter contacts + plunger. The worn components sometimes make good contact and sometimes don't. Replace 'em, you'll be all good.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-25-2020, 11:22 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
As Charlie said, Amazon.com: Victory Lap ND-34SOL Solenoid Repair Kit: Automotive
Old 02-26-2020, 09:15 AM #4
phattyduck and jgue467 - Thanks for suggestion and link to kit. Will put this on the list for next fall.
Old 02-26-2020, 09:23 AM #5
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
This should be a pretty clear case of worn starter contacts. I'm surprised the shop didn't think to check the starter contacts. If it were me, I'd be a little leery of that shop moving forward....
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
engine , fine , issue , starting , weather
Cold start fires right up, let it sit for an hour and it will just crank Supermoney 3rd gen T4Rs 10 01-26-2018 01:28 AM
Cold weather starting issues 99ToyoRunner 3rd gen T4Rs 1 01-07-2015 01:10 PM
How long to wait after starting engine in cold weather? keylay31 General Discussions 138 08-31-2009 03:57 PM
Starting in Cold Weather (part II) alaskaman 4th Gen T4Rs 4 01-07-2009 01:35 PM
