Old 08-10-2018, 06:57 PM #1
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
"Easy ROute" Antenna Cable for Tacoma Whip Mod
My electric radio antenna died. Tried replacing the mast and no luck. Opened the motor and the gears were shot.
Decided to do the “Tacoma Whip Mod” and reviewed lots of the great posts on T4R.org. One (or more) recommended tying a line to the end of the old antenna wire when pulling it out through the passenger fender well. I did this and unfortunately, the antenna wire (very small in diameter) snapped and fell into the passenger side fender. Took out the glove box and using a light at the hole in the fender/inside the fender, I could see where the antenna wire came in. It is just about the passenger side right-hand plastic “foot kick” under the glove box. Fished a line through the hole (from inside the cab to the outside of the fender well hole) and fished the end of the new antenna back through into the cab.
Instead of trying to route the antenna wire where it used to be (which is a ROYAL PITA) I simply routed it where it would get to the radio as easy as possible and without getting in the way of the servo motors for the ventilation system and the airbag system. I DID TRY routing in through the same passage the original antenna wire was and after cussing like a sailor for an hour, I said “to hell with it” and took the easy route. I thought reception might be bad but, it is much better than the old electric antenna. Now, I have the whip mod and I am VERY PLEASED.
THE LESSON I LEARNED: It is NOT NECESSARY to follow the old path of the original antenna wire. Save yourself the headache of trying and run it in a way that works and does not interfere with stuff behind the glove box.
PARTS:
Antenna Mast - Toyota (86309-0C020)
Antenna Assembly 86300-35090
My cost at the dealer for both parts was $106.08. It actually turned out cheaper than Amazon.com for the same parts and without the wait for delivery.
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 08-10-2018, 07:19 PM #2
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Talking
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 08-10-2018, 07:55 PM #3
Black & Tan 98T4R Black & Tan 98T4R is offline
Real Name: T
Black & Tan 98T4R is on a distinguished road
Real Name: T
So question- I was thinking of doing this, but was concerned about losing radio signal and how it attaches to the old mast point...the Tacoma whip “screws” in or did you change how that fit?
Pics would be helpful ;)
Thanks!
-T
Current project: ‘98 4Runner, stick shift, 4x4, 160k!
@over_the_rivers
Black & Tan 98T4R is offline   Reply With QuoteReply With Quote
Old 08-10-2018, 10:29 PM #4
firemanj92 firemanj92 is offline
firemanj92 is on a distinguished road
Thanks!
It replaces the mount on the motorized mount with a fixed mount.
firemanj92 is offline   Reply With QuoteReply With Quote
Old 08-12-2018, 07:44 PM #5
Thanks!
Sorry I did not take any pics. I was in a hurry to get this done. If you are concerned with the signal, rest assured that is not an issue. I am actually picking up more radio stations (and much further away) than with the electric antenna. Just not having to deal with that thing is also a blessing. The whip antenna is longer than the original auto/electric antennas on the LTD of the 3rd gen T4R.
If you buy the two parts mentioned in the original post, it is easy. The fixed antenna unit comes with a small plastic cap screwed in. Remove it and thread in the whip antenna. The whip antenna even comes with a little "wrench" to tighten it on. So glad I did this. HIGHLY RECOMMENDED!!!!
(Just be careful not to snap off the old antenna wire when pulling it out.....like I did....made it much more frustrating to wire in the new cable!)
What Happened to Tacoma Whip Antenna Mod Write Up kpnavarro Classic T4Rs 12 11-11-2016 12:54 AM
4Runner non-powered antenna same as tacoma whip? DavidH. 3rd gen T4Rs 5 02-13-2015 12:48 PM
power antenna switch or Tacoma whip antenna? hrt4me 3rd gen T4Rs 18 07-08-2013 10:09 PM
2013 4runner "the dip whip" from central California cali*roots New Members 3 07-02-2013 12:21 PM
Non Power Antenna to Tacoma Whip slimatic 3rd gen T4Rs 24 10-23-2010 01:50 PM
