Old 08-11-2018, 06:45 PM #1
Rebel_way Rebel_way is offline
Rebel_way is on a distinguished road
Dashboard lights/headlights/taillights stay on after key is out.
HI there.
I got a problem fighting some gremlins in my 4runner 98. I turn of the engine and pull out the key, but some of the dashboard lights stay on and headlights stay on and sometimes tailing lights stay on. Tryed pulling out different relays, disconnecting ignition switch the only thing helps is disconnecting the battery.
Any ideas?
Rebel_way is offline   Reply With QuoteReply With Quote
Old 08-11-2018, 06:51 PM #2
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Does it have a remote start in it? If so, unplug the main ignition harness on that and see what happens. I've been installing for close to 20 years, I've seen some crazy stuff happen when old systems fail.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 08-11-2018, 08:09 PM #3
Thanks for reply.
No it doesn't have remote start. It had alarm but was deleted long time ago because it was misbehaving. It started out of nowhere. I thought that the ignition lock cylinder might be a problem because it was sticking and didn't want to turn so I replaced it but the lights problem is still there but now at least it starts good.
Old 08-15-2018, 03:22 AM #4
problem solved.
Started pulling fuses from a fuse box one by one to see if anything would go off. After some time I came up to alternators 7.5a fuse and pulled it out.
headlights and dashboard turned off. Opened a fuse box and wire harness and traced wires from the fuse? some time after i came upor broken insolation in some of the wires I was following and fixed it. Everything went back to normal.
Old 10-31-2018, 06:10 PM #5
BCs300z BCs300z is offline
BCs300z is on a distinguished road
Originally Posted by Rebel_way View Post
problem solved.
I am working on a 2K 4runner for a friend and having this EXACT same problem. Except, the only relief is by pulling the "GAUGE" or "ECU-IG" fuse. Either one will de-power the truck. I have traced, replaced, and swapped many things and nothing seems to fix. I have tried unplugging just about everything in the circuit(s) and still, power remains if I reinsert the fuse. Any thoughts?
BC
BCs300z is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 02:33 AM #6
kukablack kukablack is offline
kukablack is on a distinguished road
I have 2014 4runner with exact issue. Going to open fuse box and see if any wire issue going on.
kukablack is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 03:03 AM #7
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
BC
Have a good look at anywhere that wire harness pass through a door or the rear tailgate. You know, all the bendy points. I just found 3 completely broken wires going into my tailgate.
Also, take a look under the driver's door sill cover. Sometimes previous owners run some jake-leg wiring setups under there.
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 07:07 PM #8
Ezroller Ezroller is offline
Ezroller is on a distinguished road
BC
I'm having the exact same issue. Solutions anyone?
Ezroller is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 07:43 PM #9
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Mine stay on until the driver's door is opened.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
How do I get fog lights to stay on with high beam-using for Offroad lights Brian Keeler 3rd gen T4Rs 5 08-11-2011 03:40 PM
2006 HeadLights and TailLights AlexJet 4th Gen T4Rs 13 04-09-2008 07:59 PM
headlights stay on after switch is turned off chass2001 3rd gen T4Rs 0 12-28-2007 04:23 PM
06/07 Black JDM Headlights & Taillights? sinisterj Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-29-2007 11:24 PM
Japanese Headlights and Taillights. j0mama Engines / Suspension / Wheels / Tires / Audio / Accessories 81 08-18-2005 06:46 PM
