This post is great! Just wired mines up. Works like a charm. I choose to not wire the magnet switch and it works perfectly fine like what was said ^^^. Very pleased. Hardest part was putting the plastic panel back on
I'll
add for programming the model use the Brown wire to the white/black(ground)on the b18 plug to input the programming commands. You can do that by just pushing it in the socket where the wire is crimped Steps are as follows
1)Switch module to the on position (the only switch on the module)
2)Plug in module
3) Pulse the trigger wire 15 times to ground. Choosing option 15 (brown from module to white/black on b18 plug, brown on from the module is the "trigger" wire for programming commands) the modules red LED will blink repeating how many times you grounded it (counter those blinks to verify you did indeed hit it 15 times)
4)Within 3 seconds of step 3s repeat blinks ground the brown wire 2 more times. The module will then blink twice repeating your work.
5)Wait another 3 secs the module will flash fast once after entering timer setting mode automatically. Here you input nothing. After another 3 secs it will flash fast twice here you input nothing finally after another 3 secs the module flashes fast 3 times after the 3 times flashing fast you ground the trigger wire as many times as you want seconds of output i.e. window roll up command time. In this case you would ground brown 5 times for 5 seconds. The module will flash 5 times repeating to you what you chose.
6) once all steps are complete the LED with flash fast for 3 seconds indicating programming complete. Turn switch to off and your done. Test the fob for operation
Heres the link where you can download the actual manual if you don't understand my gibberish
Universal Trigger Module - PAC
