Old 08-21-2018, 10:53 PM #1
BikeDestroyer BikeDestroyer is offline
BikeDestroyer is on a distinguished road
Bilstein 6112 & OME906/Bilstein 5100
So after lots of research trying to find the lift that fit my needs I settled on the Bilstein 6122 & OME 906/Bilstein 5100. This gives me a 2” lift and will support the weight of my armor and camping equipment. I use the vehicle to camp in the not so well traveled areas and don’t do any hard core wheeling. I kept my airbags in the back for when I am heavily loaded. If I find that they are not needed I may take them out. Pics are a before & after. I am running 265/75r16 tires. I still don’t have the front bumper installed so the front end will come down a little once that’s installed.
Bilstein 6112 & OME906/Bilstein 5100-b6758c9f-c49e-4c70-9011-daacce381353-jpg
BikeDestroyer is offline   Reply With QuoteReply With Quote
Old 08-22-2018, 01:01 AM #2
Hidjet Hidjet is offline
Hidjet is on a distinguished road
Nice!
What settings did you go for on the front?
I'm piecing together that same setup to refresh my stock suspension. A little maintenance and upkeep tho is slowing my progress.
Hidjet is offline   Reply With QuoteReply With Quote
Old 08-22-2018, 01:21 AM #3
YOTAGUY93's Avatar
YOTAGUY93 YOTAGUY93 is offline
YOTAGUY93 is on a distinguished road
YOTAGUY93's Avatar
looks good man
what perch did you run them in?
i'm at 9/8 i believe so 2.3 lift in the front reason being is i figure the spring will lower a bit under the weight of the bumper once i get it on.
please upload pics with the bumper when its on i'm curious to see if it lowers it or not
00' Toyota 4runner Limited 4x4-Adventure/Camping Rig
17' Toyota Camry XSE- DD
98' Toyota Corolla- SOLD
87' Toyota Tercel- SOLD
YOTAGUY93 is offline   Reply With QuoteReply With Quote
Old 08-22-2018, 08:21 AM #4
atcpup's Avatar
atcpup atcpup is offline
atcpup is on a distinguished road
atcpup's Avatar
That's exactly my settings with Bilstein 6112s and 5100s with 906s outback
addicted off road rear bumper and SRQ fab front plate with 10k winch
atcpup is offline   Reply With QuoteReply With Quote
Old 08-22-2018, 08:25 AM #5
looks good man
I'm at 8/7 right now. The front is about 1/4" higher than the rear. I'm looking for about 1/4"-1/2" rake in the end. Once it all settles I may have to make adjustments. The good thing is that the adjustment ability is there if needed.
Old 08-22-2018, 09:51 AM #6
YOTAGUY93's Avatar
YOTAGUY93's Avatar
That looks clean
Old 05-08-2019, 12:34 AM #7
Laith604 Laith604 is offline
Laith604 is on a distinguished road
Hey there, looking at 6112s and 5160s. Slightly different than your set up but wondering how you're liking the set up? On road/off road feel?
Not seeing too much 3rd gen feedback on this since the 6112s haven't been out super long.
Laith604 is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 11:06 PM #8
bigcap76's Avatar
bigcap76 bigcap76 is offline
Real Name: Chris
bigcap76 is on a distinguished road
bigcap76's Avatar
Real Name: Chris
Hey I installed OME 2906 rear springs with Bilstein 5160s in the rear. It gave me 2"s of lift but settled about 1/4" after 2 days. Then I installed Bilstein 6112's in the front with the 600lb springs. I wanted about 2" of lift so according to their chart I use the 8th circlip setting for the driver side and the 7th cirlclip setting for the passenger. I gained 3 inches of lift and now my front sits 1/2 inch higher than the rear. I hope it settles at least a 1/2 inch to level. I'm just confused how I got 3 inches of lift. It claims the max lift is 2.3". I guess I might have to re-do it or add a a bumper and winch.
bigcap76 is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 12:46 AM #9
bizmo21 bizmo21 is offline
bizmo21 is on a distinguished road
Are these a huge improvement on pavement compared to OME 881 paired with 4runner Bilstein 5100's? Debating between the two set-ups. I'd run the 6112's for the full 2.3" lift. And I'm pretty sure I'll be going with OME 890's + 4th gen Bilstein 5100s for the rear. Thanks in advance.
bizmo21 is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 09:16 AM #10
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's pretty likely that your front springs had sagged causing your front end to be lower than stock configuration.
Bilstein 6112's have a much larger piston similar to the 2.5" coilovers which has greater dampening performance compared to 5100's
Old 09-03-2019, 06:54 PM #11
AL B. AL B. is offline
AL B. is on a distinguished road
Same setup minus the 906’s. I had them on for about a week and it looked too socal brodozer for me. I replaced with 890’s and it was much better. May even throw on some trim packers. I love the ride.
• 2001 LTD 4WD • Bilstein 6112’s up front • Tundra Bilstein 5100 + OME 890 in the rear ig: socal4runna
AL B. is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 05:27 AM #12
bigcap76's Avatar
Real Name: Chris
bigcap76's Avatar
Real Name: Chris
[QUOTE=Bad Luck;3349230]It's pretty likely that your front springs had sagged causing your front end to be lower than stock configuration.
My front was at 20" center of hub to top of fender before lift and after it was at 23". That was on circlip setting 8/7 which is suppose to produce 1.97", I lowered each side down two notches to 6/5 and that actually gave me 2.25" of lift which I'm happy with.
Old 09-05-2019, 08:47 AM #13
Real Name: Patrick
Real Name: Patrick
After reading about quite a few people having problems like this I'm almost convinced that Bilstein based the lift heights off a 99 tall which would have been around 21" hub to fender measurement.
Ordered a lift! Bilstein 6112/5100 combo Murfe 5th gen T4Rs 50 09-10-2019 09:44 PM
Bilstein 5100 vs 6112 ClemsonYota 5th gen T4Rs 98 06-18-2019 06:19 PM
WTB Bilstein 5100 or 6112 5th gen front SF Bay area 2016SR5 For Sale: Suspension/Wheels/Tires 5 07-12-2018 12:06 PM
Bilstein 5100 to 6112 Vrrooom 5th gen T4Rs 12 02-21-2016 12:33 AM
Bilstein 6112 vs Bilstein 5100 TotalAutomotiveLV General Discussions 1 06-02-2015 05:35 PM
