Real Name: Chris
Real Name: Chris
If you play in your tie rods or ball joints, yeah replace them now before they fail on the road. Very common issue and when they fail it's not pretty. Generally takes out CV axles, can damage the diff, can damage the control arms, sway bar links, torn brake lines and ABS sensor wiring. It's an old truck, you changed the geometry after many years, expect things to wear out a lot faster now. Use OEM Toyota parts. Costs a little more but they last a whole lot longer than aftermarket.
