Old 09-06-2018, 07:59 PM #1
SAS T4R's Avatar
SAS T4R SAS T4R is offline
SAS T4R is on a distinguished road
SAS T4R's Avatar
3rd Gen Dying Issue... Stumped
Hey guys,
1999 4Runner
3.4L
Auto
195k miles
locker
immobilizer
So I have a stock 99 3rd gen that will sometime die immediately after starting, and other times fire right up. The hard start doesn't matter if I hold the starter cranking or not. The truck has the antitheft ignition, so after it doesn't start I have to turn it all the way off and wait a sec, then try again.
Stranger issue, the truck will run pretty well after it starts, except sometimes it'll wanna die if not moving, usually while in drive at a stop light or something. It will just start idling low for 2 seconds or so, then just die. NO CEL. Will usually fire right back up. Truck seems to have full power when on the throttle.
Idle is normal for the most part. Will idle in the driveway in park at 700 rpm and not skip a beat for days. No CEL. No smoke. No Rust
Here is what I've done so far:
Replaced entire throttle body (2 different ones) This includes IAC, throttle position sensor, etc.
Replaced entire intake
Plugs, coil packs, wires (2 different sets)
fuel filter
2 different mass air flow sensors
oil change
searched high and low for a vaccumm leak, couldn't detect one.
and no change whatsoever.
I'm really at a loss right now and have reached my patience ceiling. Help would be sincerely appreciated. And if you come over and help me i'll feed you beer and pizza.
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
SAS T4R is offline   Reply With QuoteReply With Quote
Old 09-06-2018, 08:23 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
fuel pump?
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 09-06-2018, 08:44 PM #3
SAS T4R's Avatar
SAS T4R's Avatar
Originally Posted by jgue467 View Post
fuel pump?
That's my last guess. I just really don't want to drop that tank unless I'm sure.
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Old 09-06-2018, 08:52 PM #4
clearock clearock is offline
clearock is on a distinguished road
Iac? Just saw u posted that as changed I dont c the MAF listed unless i am failing to c that listed also
clearock is offline   Reply With QuoteReply With Quote
Old 09-06-2018, 08:58 PM #5
how did u search 4 the vac leak? did u try spraying TB/carb cleaner around the intake etc while it was running? use a smoke machine? or...
Old 09-06-2018, 09:13 PM #6
SAS T4R's Avatar
SAS T4R's Avatar
Tried using propane around all of the lines to see if it would change idle or anything. I don't have a smoke machine though.
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Old 09-06-2018, 11:04 PM #7
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about
Take a fuel pressure reading and go from there.
How old is the battery? How are those terminal connections?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 09-06-2018, 11:25 PM #8
twitchee2's Avatar
twitchee2 twitchee2 is offline
twitchee2 is on a distinguished road
twitchee2's Avatar
What voltage is the alternator putting out?
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
twitchee2 is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 01:58 AM #9
SedonaT4R SedonaT4R is offline
SedonaT4R is on a distinguished road
Mass air flow sensor....
SedonaT4R is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 10:04 AM #10
mysunroofworks mysunroofworks is offline
mysunroofworks is on a distinguished road
fuel pump?
Just replaced my fuel pump for the 2nd time in 300,000 miles, very similar to what you were experiencing. New pump, no hard starts, no foot on the gas starts, no dying issues at stop or while off the gas on the highway (scary!). Hope that helps!
mysunroofworks is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 11:12 AM #11
AntleredRuin AntleredRuin is online now
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
It does sound fuel related.
Any hard starts that don't want to restart afterwards? If so, bang on the fuel tank and if it starts then, you'll know it's the pump.
Can you floor it fine without any coughing or stalling?
Any difference between if its started from cold (overnight) or when it's warm?
AntleredRuin is online now   Reply With QuoteReply With Quote
Old 09-07-2018, 12:09 PM #12
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough
JayRolla's Avatar
I also feel its fuel pump. I literally had to bang mine about 10 times the last few months to get her going. I'm about to get a new daily driver and park the 4runner so riding out the pump till I get new car or have time to replace it.
JayRolla is offline   Reply With QuoteReply With Quote
Old 09-07-2018, 12:24 PM #13
SAS T4R's Avatar
SAS T4R's Avatar
Battery is newer, terminals are clean
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Old 09-07-2018, 12:25 PM #14
SAS T4R's Avatar
SAS T4R's Avatar
Will update post. Have tried 2 different mafs too
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Old 09-07-2018, 12:26 PM #15
SAS T4R's Avatar
SAS T4R's Avatar
Alternator is putting out proper voltage when tested with a meter.
07 Sport T4R
06 SAS T4R
15 Taco TRD
11 Taco TRD
Cooling issue, completely stumped... mountainbiker42 3rd gen T4Rs 19 08-10-2016 03:06 PM
( Video ) Temperature issue, I am stumped! Please help awthorn 3rd gen T4Rs 10 07-30-2014 11:50 AM
4wd Issue Has Me Stumped! gornish_hick 3rd gen T4Rs 10 09-19-2012 10:43 PM
Electrical issue has me stumped fitzi6_7 Classic T4Rs 10 02-10-2011 08:56 AM
Stumped Toyota Service Department with this issue- can you help? krs1040 3rd gen T4Rs 17 12-16-2008 11:02 PM
