Originally Posted by mtbtim
I'm just as confused as you are. The only coolant line connections are to the throttle body. There's no coolant flowing through the supercharger. It's the same when you don't have a supercharger and you're pulling your plenums. There's no coolant flowing through the plenums.
Are you sure the coolant wasn't just pouring out of the throttle body as you tilted the supercharger? Or one of the coolant lines was jostled and started draining out more coolant?
I guess it's possible. I would have thought I would have noticed a bunch of coolant down in the lower intake when I pulled it off. I was super paranoid about crap getting into the valve intake, so I think I would have noticed if a bunch of coolant was pooling there. Hell, maybe the coolant poured in a perfect stream straight into one of the exposed intake ports without splashing or spraying anywhere.
The more I think about it, the more unlikely it seems. You must be right, it must have all come from the swapped TB hoses. Still boggles my mind that enough coolant could go from there to the cylinder to hydrolock it on the very first crank.
