Old 07-13-2021, 03:23 PM #1
RidingDirty RidingDirty is offline
RidingDirty is on a distinguished road
Rear shocks - Tokico or Gen 4 Bilstein 5160?
Hey I'm can't make a final decision with my rear shocks. I'm looking at either Tokico Blacks or Gen 4 Bilstein 5160s (25-227611) to match my Dobinsons 210V rear coils. I know that in order to fit the Tokicos I will need to drill out a larger hole at the top shock mount (11/16" to 15/16" diameter). But if I drill out a larger hole for the Tokicos will that mean I will have trouble using other shocks in the future? Like if I want to switch to the 5160s sometime later, won't the top mount have too much play due to the oversized hole? Or do the bushings and retainers keep the shock from shifting at the top? I know this is probably a simple concept, but for some reason it is causing me a lot of confusion. Thank you.
RidingDirty is offline   Reply With QuoteReply With Quote
Old 07-13-2021, 04:24 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I cannot get enough of my Tokico+210v combo. Highly recommend. My ONLY gripe is they ride a tad bouncy without weight, but nothing a couple sandbags couldn't fix (if you have a rear steel bumper, then perfect). People also always mentioned something about drilling out a hole for Tokicos but they popped right in for me with no issue, not sure why but I definitely didn't need to drill a thing
Old 07-13-2021, 05:37 PM #3
RomanSchnobrich's Avatar
RomanSchnobrich RomanSchnobrich is offline
Real Name: Roman Schnobrich
RomanSchnobrich will become famous soon enough
I also enjoy the ride my black Tokicos provide, and didn't have to enlarge the mounting hole. There's a big thread on it somewhere on this forum; most folks don't drill out the hole (if I recall correctly) and never have any issues.
2000 SR5 Midtravel Cookie Cutter Build
https://www.instagram.com/roamin.creative/
RomanSchnobrich is offline   Reply With QuoteReply With Quote
Old 07-13-2021, 05:46 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I think you have to drill out the hole if you use the metal centering washer that came with the FJ80's (the metal washer that goes between the bottom of the rear shock mount and the bushing) or you just reuse the 4Runner stuff.
Old 07-13-2021, 08:11 PM #5
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Hell I'm not even using one with my Tokicos at all, only the retaining washers at each end, didn't have enough room! Iirc this was another very common thing; not having enough threads to start the top nut when using the centering washer
If you think about it it's not really crucial anyways, if they served any serious purpose or perhaps helped protect the bushings then two would be required - one for each - instead of having one of them covered at both ends by washers and the other being pressed directly against the body from one side
Old 07-13-2021, 09:40 PM #6
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
Love my 210v/4G 5160 combo!
I do, however, have about an extra 350 lbs. of constant weight on top and in back, so it may be a bit less forgiving if you're running stock weights.
Will soak up even little bumps on the road and won't over-articulate on tight corner transitions. Off-road they act like they were designed to work as a set!
'00 'Get Lost' Build
IG: get_lost_fiffa
Fiffa is offline   Reply With QuoteReply With Quote
hole , mount , rear , shocks , top
LC Shocks: Tokico vs Bilstein Devbot 3rd gen T4Rs 12 09-16-2022 12:13 PM
FS: New Bilstein 5160 Shocks - San Jose, CA brah808 For Sale: Suspension/Wheels/Tires 5 03-06-2019 10:52 AM
FS: 5th gen TRD PRO Bilstein 5160 rear shocks - Los Angeles, CA Sr5SuShi For Sale: Suspension/Wheels/Tires 6 06-10-2018 08:03 PM
OME 881 coils with tokico struts, top plate spacers and rear tokico shocks SIKHILUXSURF For Sale: Suspension/Wheels/Tires 3 10-03-2011 03:08 PM
