01-12-2019, 09:44 AM
#46
Real Name: Leon
Real Name: Leon
Can I get some feedback from those who installed this kit:
- Did you like having the printed instructions sent with the kit, or would you have preferred to have the instructions e-mailed to you? (I'm old school and prefer to stare at paper instructions, but I also would be happy to save some trees by not sending out 9 sheets of paper with each kit);
- Did you set the opening height at near-stock position, fully open, or somewhere in between?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
01-12-2019, 09:47 AM
#47
Official Vendor
Official Vendor
I'd consider a downloadable .pdf so folks can print it on their own if they like?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
01-12-2019, 01:32 PM
#48
Real Name: Mark
Real Name: Mark
@ 4Runner4Leon
, Have question for you about strut force.
Would you say the strut force is appropriate for hood structure?
What's the chance of bending hood when you close it what I'm getting at.
I've played around with straighting one of these hoods, front to hinge.
It doesn't take much to bend the web sub structure, less if adhesive is broke
loose in a place or two.
01-12-2019, 05:07 PM
#49
Real Name: Leon
Real Name: Leon
Originally Posted by 96RedRunner
@ 4Runner4Leon
Excellent question, and indeed these hoods are EXTREMELY flimsy and easy to bend, so extra caution is required when adding struts to them. I've scoured junkyards to see how manufacturers utilize hood struts, I saw probably a dozen different approaches - dual struts, single struts, front to back struts, back to front struts, criss-cross struts, long struts, short struts, etc. What works on a Bimmer may be a dismal failure on the 4Runner, because the Bimmer had a much stronger reinforcement between the hinges and the hood.
But trial and error, math, geometry, and physics, prevailed in the end. This kit that I put together provides a good balance between tactile feel, opening force, opening height, and ability to stay opened until you close it, all without jeopardizing the hood integrity.
01-12-2019, 05:24 PM
#50
Real Name: Rich
Real Name: Rich
I set mine about an inch before I got resistance, used my hood prop tool to hold it open,,,the upper hoses hose clamp made for a great center point to the hood latch so both sides open at the same time,,I used stainless rivnuts and allen head bolts in 5mm instead of the pop rivets for the hood mounts,,,sits flush and tight.,,the relay on the passenger side I kept in place with the pivot supplied and drilled a hole in it's bracket to hold the washer hose...looks perfect...I also drilled a small hole next to the prop rod spot in the hood and hooked a lanyard to it so I have something to grab when I close the hood.,,it's just a standard key ring. Really like this kit and appreciate leon for putting this together,,,,works great.,,thanks for all your help getting my account setup....oh and I didn't realize there was directions in the box...forgot to look.,,didn't need them as it's an easy install.
Bought this 99 in 01 and haven't let it go since! Valve dropped at 195k so I rebuilt it with reman heads, new rings and one new piston...tough to find the correct numbered one but I did...still had the original hatch...I soaped it and did a light hatch to help the new rings seat...that was in 2015...since then I did a basic lift and put some VTX 18x9 inch wheels with 0 offset...Ive grounded the rear locker, ran a diff extension into the gas cap, did the hood piston mod...GM Alternator...13WL brakes..30 year ASE Master Tech with more tools than sense, so I quit everything and work at home now.
01-13-2019, 12:09 AM
#51
Real Name: Kelly
Real Name: Kelly
Order placed! Hoping it clears my fuse block tray thingy. 🤞🏽
2002 4Runner Sport Edition, Sunfire Red Pearl, 4X4
Build Thread
01-13-2019, 10:37 AM
#52
Real Name: Leon
Real Name: Leon
Originally Posted by WWRD99
I set mine about an inch before I got resistance, used my hood prop tool to hold it open,,,the upper hoses hose clamp made for a great center point to the hood latch so both sides open at the same time,,I used stainless rivnuts and allen head bolts in 5mm instead of the pop rivets for the hood mounts,,,sits flush and tight.,,the relay on the passenger side I kept in place with the pivot supplied and drilled a hole in it's bracket to hold the washer hose...looks perfect...I also drilled a small hole next to the prop rod spot in the hood and hooked a lanyard to it so I have something to grab when I close the hood.,,it's just a standard key ring type....I'd post pics of it but I don't know how yet!! Really like this kit and appreciate leon for putting this together,,,,works great.,,thanks for all your help getting my account setup....oh and I didn't realize there was directions in the box...forgot to look.,,didn't need them as it's an easy install.
Rich, thanks for the feedback, and glad that we got your access resolved, I look forward to your contributions to the forum!
Your customizing sounds very clever, please do share pictures if you figure out how to do it (or email to me, I can upload them). I debated using rivnuts vs rivets, but went with rivets in the end because they have way more than enough strength for this application, and because more people have access to a rivet gun than a rivnut tool. But I did use rivnuts when installing my prototype, because the bracket had large mounting holes in it.
Too bad you didn't see the instructions, I think I'll zip-tie them to the struts in the future, so they don't accidentally stay stuck inside the box. Glad you figured it out though, and that it all worked out.
01-13-2019, 10:38 AM
#53
Real Name: Leon
Real Name: Leon
Kelly, I got your order, thanks! I'll email you regarding some of the potential obstructions on your truck.
01-15-2019, 05:56 PM
#54
Real Name: Leon
Real Name: Leon
@ Mtns_Yo
and
@ octanejunkie
, your tracking info has been sent to you and your kits are going out tonight!
01-15-2019, 06:04 PM
#55
Real Name: Colin
Real Name: Colin
Looks great. Definitely interested! Waiting to hear from another T4R enthusiast in town to see he he wants one too.
01-15-2019, 06:09 PM
#56
Real Name: Leon
Real Name: Leon
Sounds good! Might as well take advantage of the shipping discount for multiple kits going to same address .
01-20-2019, 08:50 PM
#57
Installed the kit today. Great instructions, easy to follow. I really like the pictures. I installed mine so the hood still has about a inch to go before hitting the maximum height.
01-23-2019, 08:13 PM
#58
Emailed instructions are fine, I set the height to fully open position and it never stretched the hose, maybe mine was a bit longer? I was also able to reuse the same hole the hose clamp was attached to without the strut putting pressure on the hose and finally, I did re-attach the buzzer to it's original hole using the new strut bolt as you suggested and it worked like a charm. Great product! My only complaint is I now have to get on my tippy toes to be able to grab and close the hood (kidding). The difference is night and day! Now my other half wants one for her 2011 RAV4 LTD, I told her I'd pass that on and see what you have to say about it. I know Redlinetuning makes one for 06-12 RAV4 but I'd rather get it from you if you have a set.
00 T4R LTD V6 4WD 275K e-locker
11 RAV4 LTD V6 4WD 100K
01-24-2019, 01:01 AM
#59
Real Name: Leon
Real Name: Leon
Thanks for the feedback! I spent a ton of time on the instructions and pictures, so it's good to hear that they came in handy .
Great feedback, thanks! I think I'll update the instructions to suggest using the passenger side bracket as an attachment place for the washer hose, for those that have it. I'm also pondering adding a bracket to the kit to hold the washer hose, for those of us with the pre-99 models, without the bracket.
Thanks, that's a great vote of confidence . I'm not ready to leave my swim lane yet (3rd Gens), though I'm currently working on a strut design for a Taco, seeing how similar they are to our Runners.. One step at a time .
01-27-2019, 01:45 AM
#60
May I purchase one and come over to your place for your expert installation?
