Old 08-26-2021, 09:06 PM #301
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Progress has been slow lately, bumper is almost ready to be painted. I’ve been splurging on more parts/tools though lol..
I’ve been learning quite a bit while building this bumper. It’s not perfect but I’m happy with how it’s coming out.. Looks a bit better now than in this picture..
These flex head ratcheting wrenches have been on my list for a while and I could have used them countless times..
M12 right angle die grinder, if your thinking about it do it. I should’ve gotten this when it came out..
Last but not least here are a few parts I’ve started collecting for the dual battery/fridge drawer/sleeping/storage platform. Too much to list lol.. Also have some square aluminum tubing that’s not pictured that will be the frame.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 06:07 PM #302
TW44LR's Avatar
TW44LR TW44LR is offline
TW44LR will become famous soon enough
TW44LR's Avatar
Use the m12 die-grinder a lot huh? I’ve been teetering back and forth on it but so far haven’t found a “need” for it but when do you feel like you use it most?
TW44LR is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 07:29 PM #303
T4topher's Avatar
T4topher's Avatar
I just got it yesterday so I’ve only gone through about 2-3 battery charges. Anything your going to use a flap disc for you can use this instead basically. Less noise, easier to control, can get in tighter areas/corners, less risk of hurting yourself (I’ve had several grinder/hand incidents over the past year).. Just makes the overall grinding experience more enjoyable if that makes any sense lol.. I got some cheapo roloc style discs/adapter and they work great, I’ve heard the 3m stuff works the best but it’s $$$.
Old 08-28-2021, 12:54 AM #304
TW44LR's Avatar
TW44LR's Avatar
Makes a lot of sense thanks for the info, now I just need to rationalize more money spent on tools haha.
Old 08-28-2021, 04:46 PM #305
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
Bumper looks nice and now I have to consider you a bad influence,
am always a sucker for useful tools
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 06:25 PM #306
T4topher's Avatar
T4topher's Avatar
Thank you. Haha oops
Bumper is finally ready for paint this weekend, have to clean all the surface rust off with some metal etch or vinegar if that doesn’t work.. Then I’ll dry it and wipe it down with acetone. Pretty happy with how it came out although it took me way too much time..
Also got a new fan clutch cause why not and a new gasket for between the cat and the muffler..
Old 09-17-2021, 12:25 AM #307
T4topher's Avatar
T4topher's Avatar
Update:
-Fan clutch installed
-Exhaust gasket installed
-Marlin crawler shifter seat installed in rear tcase
-Heavy duty shifter springs in front and rear tcases (x3)
-Painted eimkeith bumper
-Back up lights on bumper installed
-Opt offroad rear control arms installed
-Adjusted upper control arms to zero out rear pinion/driveshaft angle
-Flex tested to make sure upper control arm axle brackets didn’t hit frame
-Tomwoods F/R driveshafts fully installed
-Took MC shifter base apart to inspect leak, after talking to MC I’m going to try and switch gear oil (used Lucas 85/140 they insisted I use redline 75/90)
-Ordered stock length rear duro bumps because I noticed I have a lot of shock shaft left at full bump.
Old 09-17-2021, 11:30 AM #308
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Why'd you end up zeroing out the pinion angle? Were you get vibrations with a 1-2 degree variance? Just asking as a zeroed out pinion angle won't allow the u-joints to act as proper bearings and can wear quicker. I have always used a 1-2 degree variance to allow proper movement and lubrication within the joints.
Just curious as to your reasoning. I've also never ran a dual case setup and don't know how much that messed with your geometry.
Either way your rig is looking good.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 12:11 PM #309
T4topher's Avatar
T4topher's Avatar
Welp I didn’t think about the u joint not getting properly greased from no movement lol.. I will probably do as your saying and readjust it a little to be within that 1-2 spec. My pinion angle after the dual cases was about 7-8 off so it definitely needed some adjustment though (any speed above 45 had some vibrations). Appreciate the input and compliment!
Old 09-17-2021, 02:29 PM #310
TW44LR's Avatar
TW44LR's Avatar
Damn it’s lookin sexy as hell
Old 09-27-2021, 12:31 PM #311
T4topher's Avatar
T4topher's Avatar
Driveshaft is sitting at a 1.5 degree difference from the pinion now, thank you @G_Raw
Got my oem CVs rebooted and cleaned up. For some reason my driverside napa CV keeps popping out a little and leaks gear oil. New seals and rebuilt axles going in tonight.
Whiteline panhard bar bushings installed last night, super easy.. used a 30mm socket, a 19mm socket and my vise and the bushings came right out. Pretty much have completely replaced all bushings and suspension items now.
New to me rear windshield pump, for some reason after the scarab install the pump stopped working.. Seems like it was getting power cause it would get hot when I tried to use it, hopefully the new pump fixes it..
New throttle cable, going to make a video for this install.
Old 09-27-2021, 10:27 PM #312
G_Raw's Avatar
G_Raw's Avatar
gotta let bearings be bearings ya know? Enjoy that longevity of your custom driveline while I drool over your dual cases still...glad I could help
Old 11-07-2021, 10:36 PM #313
T4topher's Avatar
T4topher's Avatar
Rear storage/sleeping platform coming along nicely, got some 400lb locking slides for the drawer. Didn’t want to buy a spool gun so I borrowed a tig welder, first time using one lol. The welds are not great but they will hold.
Progress photo almost done with the aluminum frame, also you’ll notice I got the rear bumper all finished up and mounted the plastic trim piece.
One of the better welds..
Old 12-01-2021, 12:27 AM #314
T4topher's Avatar
T4topher's Avatar
Almost wrapped up with the storage/sleeping/fridge platform. Just have to wire in the dc-dc charger and seal the plywood with laquer. Overall so far I’m extremely happy with how it came out, not perfect but it’s functional.
Here it is with the back seats folded up
36” 400lb locking drawer slides worked out mint
Got the blue sea usb/voltmeter/cigarette charger all wired up. Also the legs for the sleeping extensions fit perfectly behind the seat.
I used 1/2” galvanized pipe and threaded it into the plywood. Then I have a 4 bolt flange for the base of each leg. It actually worked much better than I thought it would, the best part is I can do fine adjustments by threading each side in/out. The main reason I did this is I wanted the plywood extension to be completely flat.
Made a removable panel for the aux 100AH lifepo battery/dc-dc charger. This worked out really well, all the wiring is within this box which made it super easy. (Side panels are removable too but you can still open the oem side cubby without removing them)
Exped Megamat duo LW+ fits perfect (platform is 77” long) this thing is ridiculously comfy, maybe even more comfy than my bed lol.
Old 03-20-2022, 10:28 PM #315
T4topher's Avatar
T4topher's Avatar
Long time since I’ve done an update so here goes.
Took a break from the 4runner and did a ton of work on the garage, way more shelving/storage and so much less clutter.. still need to really get things organized but pretty happy with how it came out.
Built a rolling table that fits perfectly into the shelves for my miter saw, much better than using it on the ground.
These extension cord and compressor hose reels I got are priceless, they save me so much time and effort.
Got a swag band saw table, been wanting this for a long time..
Got some more wall control stuff, now I can put my FSM’s on display haha..
Got a couple Milwaukee lights recently but wanted to mention this one, the usb charger saved me in a blackout the other day. My phone was about to die and I was able to charge it with this light.
Got the 2 ton pro eagle jack for Xmas, so much better than my 10yr old auto zone one. Only bummer is it doesn’t really fit under my daily driver that well.
Went camping a couple weeks back and realized I needed one of these mini propane tanks, I always run out of the green ones everytime..
Here is said camping trip, had a blast
Last but not least I’m trimming the rear for 35’s on factory bump stops (plus 1” body lift). I guess I wasn’t thorough enough when I checked last time.
I’m pretty sure it’s dead Jim. Rear drivers lower link mount broke off frame. 19963.4lsr5 3rd gen T4Rs 16 09-12-2020 11:41 AM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
Woman in stolen SUV eludes police after running over Dallas officer’s foot CoolMax General Discussions 4 02-10-2016 01:27 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
Snow White build 2006 v8 adventure overland apocalypse build Dubs Chops 4th Gen T4Rs 24 04-25-2014 09:25 AM
