Sooo something happened.. I accidentally forgot I had the front drive shaft zip tied only and went for a test drive and shifted into AWD… Was pretty heart breaking after putting in so much work. Check out the carnage.
Front section of tcase housing cracked, transmission bell housing Swiss cheesed, power steering lines chewed up. Good thing I don’t need the sway bar mounts anymore, even made a small dent in the frame.
Went to the salvage yard and picked up a 99 limited transfercase. Was super crusty/rusty so I decided to just use the front section of the case only. Took it all apart and resealed the housing back up with all my original tcase guts.
Took transmission out to replace bellhousing, decided to start the transgo/solenoid replacement. Realized I got the incorrect solenoids. If you want to do the solenoids I highly recommend dropping the pan before ordering as the ones I got were recommended by mcgeorge (didn’t order them from there though).. Was pretty hard finding the correct part numbers, had to look at the pictures on partsouq to figure it out..
Here’s what the solenoids look like
Also can’t figure out why my elocker isn’t working after doing the ECGS 3rd. Seems like the actuator/motor works (tested with the battery). Also seems like the ecu is fine, going to have to do some more testing..
