02-12-2019, 02:41 AM
#166
Well I found a 194 bulb (3rd brake light) w/ canbus built in so I think I’ll get that if I get the abs light problem.. Try to return the bulbs I got..
https://www.amazon.com/dp/B07B9XT4QX..._mMMyCb2F2XRD2
02-16-2019, 04:01 PM
#167
02-16-2019, 08:22 PM
#168
Real Name: Tony (no surprise)
Congrats on the purchase. Understood on the 4-banger. Chose the four cyl option on our family car too, for the same reason. I think the insurance was also less...
On that steering wheel, I never heard of anyone painting that before. I wonder if they used some solvent or a cleaner they shouldn't have... Or, too much sun? If paint, I'd try things that remove paint, but as always recommended, do so first in a place that is not very noticeable, just in case it somehow makes things worse.
If this will be your first child, life changes quite a bit afterwards. Started quite late and I absolutely love being a Dad. Sleepless nights are just around the corner!
2000 Limited, E-locker
Maintenance/Build Thread
02-18-2019, 04:35 AM
#169
Thanks man.
It’s for sure paint cause I can scratch it off with my finger nail, it’s also on the bottom plastic trim pieces on the front seats. Looked like the PO had the leather on the seats and steering wheel repaired previously and I bet that’s why those things are painted so it blended the repair better.
Yep first one! Definitely going to be some sleepless nights, I’m super excited lol.
Started on the timing belt/radiator/cooler.. probably save the trans filter for my next trans flush. Pretty dirty back there! Going to get some simple green or something on there tomorrow before I reassemble everything.
02-18-2019, 11:52 AM
#170
Originally Posted by T4topher
Thanks man.
These build threads can take-on new meaning when our children, years from now read them. My oldest, now 9, saw mine and began reading it in interest, then asked if I have other ones, like for my MINI, and other older rides. Wow. Makes me want to re-read those first before I share with her, lol.
If your feverish build pace slows down a little, we'll understand.
02-18-2019, 08:22 PM
#171
Wow that’s kind of surprising, will have to reread my build on Tacoma world before I share that one with any kids haha.. Eventually this thread will be a build & adventure thread once I actually bring the 4runner out! The purchases will definitely slow down a bit but I’m still going to get a weekly allowance for t4r stuff!! Hehe..
I hate cleaning engine parts.. Not done but it looks a lot better already. I found a wire with the sleeve cut sort of in the middle so I ended up using some Tessa tape and wire loom to make the repair..
02-20-2019, 10:47 PM
#172
Now I’m pretty much just waiting on parts.. when I bought my trans cooler off eBay I didn’t see the box that said (hardware not included) and of course didn’t check the box until I was installing it lol. Here’s a few things that got delivered today
03-04-2019, 12:20 AM
#173
Finished up the timing belt and transmission cooler last week, turned out really nice. Ended up doing the transmission filter this weekend as well, fluid was sort of dark but I was pleased to see it was only very very fine metal shavings was like a paste. Not much of it either. Truck definitely feels better under acceleration, I think I was low on fluid before. Took 6qts and I ordered a 7th Incase I need to add a tiny bit.. thanks for all the help
@ infamousRNR
04-07-2019, 11:21 PM
#174
05-03-2019, 09:10 PM
#175
Haven’t been doing much in the sicmods department lately, mostly preparing for the baby. Just ordered an odyssey AGM battery as the interstate battery I had wasn’t really holding a charge very well. Also updated the workbench a bit.
05-22-2019, 02:15 PM
#176
Since it was my bday not to long ago I ended up treating myself to a couple of things.
Full size spare with matching rim! Even mounted the tire on the rim myself. (Thanks for the rim
@ infamousRNR
Here’s my new battery installed, if you end up buying on of these batteries you will need to get a spacer as well to use the stock battery hold down.
06-03-2019, 06:26 PM
#177
Finally made time to go on a small trip over the weekend! Was a lot of fun, wish I took more pictures. I believe we went up hwy 31 kind of near hwy 89. Got to a point where the road was completely snowed over and we didn’t want to risk getting stuck as I had already gotten stuck in a small patch of snow earlier lol.
06-04-2019, 12:50 AM
#178
Real Name: keith and jenny
The truck looks great, as always! The new garage looks sweet! It seems wider, and longer, the perfect place to get some sicmods done. Does it have the larger outlet for the welder?
06-04-2019, 01:44 AM
#179
Thanks man! Yea pretty happy with the new space. It has a 220 outlet for an electric dryer that I’m using for the welder, works great!
07-08-2019, 07:57 PM
#180
Been a while since I’ve updated. Did a couple things over the weekend: power washed/vacuumed, chased all the threads on my oem skid plate bolt holes, cut my LCA skids a bit more for clearance issues (hopefully I don’t have to cut more), tightened some of the leds on my SRQ blinker filler panels. Also just received my ruffstuff diff skid, this thing is a work of art I can’t wait to install it. Was looking at the bud built skid and I think Marlin but I just really liked the simplicity of the ruffstuff one and the price was right.
