Well here are a few updates:
-installed method 312’s on 315/75/17 cooper stt pros and started cutting the firewall
-installed JBA UCA’s
-did a DIY alignment (move LCA cam tabs so I gain maximum positive caster and then adjusted the toe within 1/64” with the steering wheel straight)
-removed cruise control
-figured out my hesitation that I get out of a rolling stop (shift solenoids)
-tinted the clear part of my tail lights (unsure about it, might remove the film..)
-both front durobumps cracked at the base going to have to shoot him an email.
-installed laminate floor in my house
-got insulation blown in the walls/attic/garage ceiling
-got vaccinated
PSA if your lifted and not running a sway bar up front your limiting factor is probably your upper ball joints.. these were brand new oem with less than 2k miles, hard to see from the picture but they are pretty ovaled out.
