Old 10-05-2018, 03:51 PM #1
Lindenwood's Avatar
Lindenwood Lindenwood is offline
Lindenwood is on a distinguished road
Lindenwood's Avatar
Extra-long crank after leaving ignition to "on" for an extended period with hot engJu
As the title states. A few times I have driven somewhere, turned the vehicle off, then shortly thereafter turned the ignition to "on." Usually this is just to run the dash blower for a bit if I am just chilling out in the woods, but last night I was just testing tail lights and signals since I noticed one was burnt out.
In any case, sometimes it will just crank for several seconds, and never turn over unless I flutter the throttle like my old Samurai. Sometimes I smell gas after this happens.
Any ideas?
Mine: 2002 SR5, Lifted, Armored, and Accessorized on 33s. Build Thread
Hers: 2016 Quicksand TRDP, Lifted 2" on ~32s.
Lindenwood is offline   Reply With QuoteReply With Quote
Old 10-05-2018, 04:09 PM #2
Lindenwood's Avatar
Lindenwood's Avatar
I found much better search parameters. It seems the general thought is that fuel is leaking into the engine / intake manifold when hot, and this taking more air to reach a combustable mixture.
Other folks say it is possibly a leaking FPR or Fuel Pump check valve that is allowing fuel to drain back into the tank when warm. However, the fuel smell that I get when this happens points to an FPR issue, though I don't know why having the ignition on would affect this?
Old 10-05-2018, 04:57 PM #3
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Then pull the vacuum line off the FPR and check for fuel present.
Sounds like the pump is on its way out possibly.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 10-05-2018, 08:32 PM #4
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough DaMonkey will become famous soon enough
DaMonkey's Avatar
in my best old fart voice: "when I was a kid...."
bad idea to leave key set to 'on' because the points in the distributor had some kind of chance (maybe 1 in 3?) that the points were closed on their cycle when motor stopped. that could draw current and burn the points.
then came electronic ignition.
unless you did some serious prepper modding... transistors have saved us from that issue.
no problem leaving key in the 'on' position, unless your battery is bent over and wheezing.
DaMonkey is offline   Reply With QuoteReply With Quote
Is it true that leaving your headlight setting on "Auto" will damge your HID? Ixz72 5th gen T4Rs 17 12-15-2017 03:04 PM
GA-BNIB 2" Total Chaos "Race" Long Travel -Cam/Bucket/Spindle Gussets -Axles/HD Boots av8ter For Sale: Suspension/Wheels/Tires 24 02-26-2017 05:07 PM
"Extra" connector and "VSC, etc lights" on phoo 4th Gen T4Rs 5 05-05-2014 01:16 PM
Okay, so I just noticed, my "B&M" trans cooler has "Long" stamped on it! Nachtjager 3rd gen T4Rs 0 06-26-2013 12:21 PM
