Old 10-08-2018, 08:54 PM #1
blairvt blairvt is offline
blairvt is on a distinguished road
Denso O2 sensor
Anyone have the part number for a 1997? Seems like everywhere I look it lists several different numbers.
blairvt is offline   Reply With QuoteReply With Quote
Old 10-08-2018, 08:58 PM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
That's because there are.
Front or rear? 2wd or 4 wd? auto or manual? 4 cyl or 6 cyl?
My Backyard Frame Swap
Old 10-08-2018, 08:58 PM #3
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
I have a non-California emissions, 2000 T4R. Always buy my 02's from Amazon. The Denso part number I have (for the 2000) is for both FORE and AFT sensors. Denso 234-4162 (Both sensors the same) Also, my rig is an automatic with 4WD (Limited) with the 3.4L (5VZFE)
Hope this helps....
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 10-08-2018, 09:07 PM #4
sorry, left out details
1997 4x4 automatic. Looking for the one before the cat. Should I replace both?
Old 10-08-2018, 09:14 PM #5
TheDurk's Avatar
TheDurk's Avatar
Engine? V6 is 234-4162 in front and 234-4154 in back.
What's your mileage? Is rear sensor original? If not, how long has it been in there?
Old 10-08-2018, 09:19 PM #6
I ALWAYS REPLACE BOTH just as a precaution. Also, Amazon usually has very good prices on these. You can get two denso from them for the cost of one from the dealer.....
Old 10-08-2018, 09:25 PM #7
V6. 167.000 miles. No idea how long they have been on there
Old 10-08-2018, 09:31 PM #8
When I used Amazon's "part matching" feature, it gave me two different part numbers for FORE and AFT. I did lots of research and found they were both the same on mine. Perhaps for your year, make and model, they may have two different part numbers.....been running two of the same part number for 12+ years and no issues at all.....you might want to check DENSO USA's website to double check....DENSO Auto Parts
Old 10-08-2018, 09:36 PM #9
TheDurk's Avatar
TheDurk's Avatar
Probably not original. Wait for a code from the rear. That's all they do is throw codes.
Old 10-08-2018, 09:39 PM #10
TheDurk's Avatar
TheDurk's Avatar
They are all the same O2 sensor and same plug on one-cat Federal systems; the only difference is wire length. So a lot of "wrong" sensors will work just fine as long as the wire is long enough.
Old 10-08-2018, 09:56 PM #11
O2
Just ordered them. Anything special I need to know to install? Looks pretty straight forward.
Old 10-08-2018, 10:10 PM #12
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Old 10-08-2018, 10:10 PM #13
TheDurk's Avatar
TheDurk's Avatar
You may need new nuts, depending on salt exposure. M8-1.25 stainless.
Old 10-08-2018, 11:58 PM #14
Totally agree with TheDurk on the nut issue. I had to replace the four nuts (two per sensor) on my rig as they were rusted beyond further use. I actually went to the effort (and expense) to get mine from the dealer (EXPENSIVE!) but you can get the same nuts (in stainless steel) from your local Fastenal dealer).....don't ask me how I know this.....let's just call it a "lesson learned".....LOL
Old 10-09-2018, 01:01 AM #15
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
This^^^
Measure the length of the wire on the old one before you order the new one.
I once had wire length matching issues when trying to get a new Denso for a previous Toyota vehicle.
pluton is offline   Reply With QuoteReply With Quote
Denso o2 Sensor centxrunner 3rd gen T4Rs 112 10-17-2018 05:26 PM
I have a 4wd '99, can someone tell me which Denso O2 sensor I need? DeadbeatYota 3rd gen T4Rs 11 03-14-2015 03:46 PM
Denso o2 sensor sigley0527 3rd gen T4Rs 3 06-17-2013 09:48 AM
O2 sensor Denso vs NGK neilr 3rd gen T4Rs 1 05-26-2013 11:24 AM
F/S: Denso O2 Sensor Rescue84 Classifieds - buy & sell (no commercial ads please) 0 06-28-2007 10:00 PM
