10-15-2018, 09:38 AM
#31
Monday pre-lift sneak peek:
Yes, 255/85/16 fits stock suspension (barely)
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
10-15-2018, 09:45 AM
#32
Real Name: Alex
Real Name: Alex
Mmm!
Is the offset different from stock with those wheels?
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
10-15-2018, 10:01 AM
#33
Originally Posted by raKnizek
Mmm!
I do believe it is the same
10-15-2018, 10:04 AM
#34
Real Name: Wettlin
Real Name: Wettlin
Right on
10-15-2018, 10:15 AM
#35
Real Name: Ryan
Real Name: Ryan
I love the look of the steel wheels... where did you find them? Not sure I saw that in the thread.
#36
did the hubcap flanges clear in back but not front?
10-15-2018, 10:19 AM
#37
Does the suspension and steering fully cycle without a lift? I think it looks great at that ride height. I'd want the lift, but nice to know that would be an option like that.
10-15-2018, 10:20 AM
#38
Real Name: Kyle
Real Name: Kyle
Admiring the attention to detail here.
10-15-2018, 10:30 AM
#39
Thank you- I am also a huge fan of steel wheels. Something about them when paired with the right tire just looks "all business". I got lucky and found these on craigslist (from a Toyota Tundra base model).
That is correct- they fit just fine on the rear axle. There isnt enough tolerance on the front hubs to accomodate them. In fact, the Tundra steelies almost have a bit of a "compression" fit on the front hubs, and you can audibly hear the wheels "snap" onto the hub interface when tightening lugs.
I am going to get this lift on, get some maintenance taken care of, and then have a look at modifying the center caps to eventually run them on all 4 corners.
Ok, so it technically "fits" with 255/85/16.
I should have clarified that there is light rubbing on the front inner plastic fenders at full lock. You cold trim in 3 seconds and be OK.
But, with a lift there would absolutely be no issue
Thanks!
10-15-2018, 10:38 AM
#40
On the menu for the next 5 days:
New front wheel bearings
New front/rear ARP wheel studs
Trim dust shields
Install Brembo Tundra rotors, calipers and Brembo ceramic pads
New OEM front Lower Ball Joints
UCA bushing and rebuild kit
Steering rack bushings
Front Swaybar bushings
Eibach pro-lift kit front/rear
Rear swaybar bushings
Grind, detail and paint front suspension OEM parts (Control arms, etc)
Overall De-grease and check for leak re-formation and address as needed
10-15-2018, 12:09 PM
#41
The suspension goes through the same arc whether you are lifted or not... If they truly fit a lifted truck (through all travel/flex) they will fit a stock height truck. Those are larger diameter than most people will say fit, but maybe the narrower width helps with clearance.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-23-2018, 02:18 PM
#42
Just a quick post- Will be posting more detailed pics later on:
- Installed Eibach Pro-Lift Kit stage 1 from Wheelers
- Installed front/rear swaybar bushings, end link bushings
- Steering rack bushings
- OEM front LBJs
- Camburg UCA rebuild kit (bushings)
- Alignment
- Tundra brake upgrade with Brembo rotors and pads
Here is how the Wheeler's Eibach Pro-Lift Stage 1 kit sits:
I will be installing the FJ60 center caps, cleaning it up a bit, and will post some more
10-25-2018, 09:23 AM
#43
Busy times at work, therefore the 4Runner project has really sat still for the last 3-4 days since completing the lift.
Couple of updates:
-- As with lifting any vehicle, it seems to expose or exacerbate issues, such as slinging grease from the 18 year old CV boots. Trying to think this through... replace the boot, or just go with whole new CVs. Probably whichever of these options my wife will kill me less painfully on. The stock boots do not look torn. I may just try to tighten them down some and run it as is
-- Ordered up a set of ShrockWorks skids! Black powdercoated
-- I am cutting down the rollbar this weekend and fabbing it up.
Here's the whole "roll bar plan": - Cut and fab up new foot plates and underside backing plates
- Send Rollbar to powdercoater
- Pull up all rear cargo carpet and lay down Dynamat Xtreme on floor and wheel wells
- Bolt rollbar through the carpet- not on top of it (requires making a slit in the carpet)
Looking forward to seeing if the DynaMat will cut down some of the whirring from these KM2s
-- Again, for those who are wondering: The Eibach Pro-Lift Stage 1 kit that Wheeler's sells is actually quite nice! It's cheaper than many, and sits 100% level. Plus, the ride quality feels close to stock. It is just a really well-engineered kit it seems like. One of the better driving 4x4's I've been in.
10-25-2018, 11:02 AM
#44
Real Name: Keaton
Real Name: Keaton
What load class of tires did you end up getting? I love the stance on your truck! Have you noticed any major hit in MPG? Looks awesome man!
[DD]2003 Lexus LX470 - Black Onyx - Stock
[SOLD]2000 Toyota 4Runner - SR5 - White - 5-Speed - Toyota E-Locker (4.10s )- 620LB Eibach/OME 890 - 33" Falken Wildpeak ATs - 4x4 - 164k and climbing
[RIP] 1993 Toyota 4Runner - SR5 Sport - Black Onyx - 5 Speed - 31" Bridgestone Dueler ATs - 4x4 - Cracked Block at 254976 RIP
10-25-2018, 11:31 AM
#45
Load Range E.
No noticeable hit in MPG yet, but I know it probably took a significant hit, even with the 255's. I'll measure it next fill up
Now, speaking of MPG- this thing could use some 4.88's now front and back! These wheels and tires are not light
I think the 4.88's would come close to correcting the speedometer as well
