Old 10-25-2018, 11:42 AM #46
Originally Posted by WeakSauz View Post
I think the 4.88's would come close to correcting the speedometer as well
Nope. The speedo is run off the ABS system (on any 3rd gen that has ABS). Wheel rotation speed is all that matters. No matter the gears, the speedo will read the same.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-25-2018, 12:08 PM #47
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Great info- I haven't really researched it yet and need to. So given that the wheel rotation speed is solely ABS-based, it sounds like there really isnt a way to fix the speedo reading. I think it's showing about 9mph slow now, which doesnt bother me too much
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 10-25-2018, 01:47 PM #48
You may still want to re-gear. Since you started with the 15" wheels, you have either 3.73 or 3.9 gears. Most of the 16" wheel trucks had 4.1 gears and some have 4.3 gears (for V6's, the 4 cylinders sometimes were even 4.56's).
You can re-calibrate the speedo pretty easily with a calibrator. I used a Dakota Digital SGI-5E. You wire it in between the ABS computer and the gauge cluster.
Universal Speedometer Signal Interface
I have some more information in my build thread...
Old 10-29-2018, 04:38 PM #49
meeceboy78's Avatar
meeceboy78 meeceboy78 is offline
meeceboy78 is on a distinguished road
meeceboy78's Avatar
loving those steel wheels. they look great!
1998 Limited 4x4 | SS 7.2 | Addicted off-road front bumper/4xInnovations rear | 285 75 16 BFG K02 | SCS Ray10
meeceboy78 is offline   Reply With QuoteReply With Quote
Old 11-14-2018, 04:29 PM #50
I have been very slack with keeping this up to date.
There has been a decent amount of "easy" work done in the past week.
  1. Rear floor stripped out
  2. Cleaned with alcohol
  3. Sound dampening mat installed
  4. re-install carpet
  5. Mount 1st Gen Rollbar with custom backing plates
I am limited on pictures here, but here we go!
Pulled the carpet back:
Alcohol wipedown
sound dampening in progress
going back together:
All tidied up:
Overall, I am absolutley shocked at how much quieter the truck is. The KM2 tires are much less noticeable.
This in itself is motivation to sound-deaden the ENTIRE interior. The material isn't cheap, but the outcome is quite impressive.
Old 11-14-2018, 04:31 PM #51
Roll bar back from Fab and powder coat:
With OEM pad:
In the truck, installed directly to floor with custom backing plates underneath the truck. 2" bolts.
I'm pleased with it! Overall it's not "in the way" and will serve for mounting some gear in the days to come
Old 11-15-2018, 03:48 PM #52
meeceboy78's Avatar
meeceboy78's Avatar
the roll bar looks CLEAN! nice job on getting it powder coated.
unless i missed it do you have the measurements on how much was cut off? i just got one and want to get this done as well.
Old 11-16-2018, 10:09 AM #53
Thanks!
Exactly 2.0" was cut off of the short legs. The passenger side foot plate has to be welded on at a slight angle to fit the curve of the wheel hump.
It's a super simple job for a fabricator. My local fab shop wanted $25 for the work
Old 11-16-2018, 10:13 AM #54
My wiper arms were looking terrible, so sanded them down and resprayed (and installed new silicone blades in the front and a new OEM blade in the rear)
Paint still wet:
done:
Old 11-16-2018, 01:28 PM #55
meeceboy78's Avatar
meeceboy78's Avatar
Thanks!
thanks for the response. is it only the passenger side than needs the angle?
Old 11-16-2018, 02:21 PM #56
My driver's side leg sits flat and needed no angle
Old 11-16-2018, 04:27 PM #57
wettRunner's Avatar
wettRunner wettRunner is offline
Real Name: Wettlin
wettRunner is on a distinguished road
wettRunner's Avatar
Real Name: Wettlin
I just noticed you're in N.C. Check out Jocassee Gorges when you get some time. Fun trails with tons of awesome camp spots. I plan on going back before the end of the year.
wettRunner is offline   Reply With QuoteReply With Quote
Old 11-28-2018, 11:36 AM #58
Holy cow that place looks awesome! I just Googled it. May have to make that my first camping destination with the wife in this truck
Old 11-28-2018, 11:50 AM #59
I had several days off work over Thanksgiving, and I'm a glutton for punishment, so decided to do a full paint correction and ceramic coating job on the truck
I have had good luck with Adam’s products and have done this to approximately 25 cars over the past few years (side work). Here are the steps I took, totaling around 19 hours of labor
1. Wash, 2-bucket method, including wheel wells
2. Clay Bar entire truck and re-wash to remove residue. Dry with microfiber
3. Take it indoors- treat black plastics (bumper plastic) with Adam’s Ceramic trim coating.
4. Detail wheel wells, coat
5. VRT on tires
6. Remove roof rack. Clean and clay roof
7. Stage 1 Severe Correcting polish with FLEX polisher and blue microfiber pad
8. Stage 2 Heavy Correcting polish with FLEX on an Orange foam pad
9. Stage 3 Fine finishing polish on a white foam pad
10. Adam’s Ceramic coating prep wipedown
11. Adam’s Ceramic coating application
12. 18hrs later- Ceramic boost applied
13. Glass sealant (after glass was polished)
I wish I had taken before photos. Many scratches and all swirls in the paint are removed.
Roof rack crossbars removed:
Finished roof:
A couple of In-Progress shots. Note the LED light- used for finding imperfections
Quick shots of the finished product. In person, it's almost like the truck changed hues of silver
I hope to get some better, more "professional" pics this weekend.
This week:
- Install Thule Aeroblade roof bars (when my fit kit arrives in the mail)
- Wire up Dakota digital speedo calibrator
.. Drive up to Virginia to pull off and buy some......
'94 Tacoma manual hubs, front CVs..
Old 11-28-2018, 11:56 AM #60
Also threw on my powdercoated Shrockworks rad and engine skids
My $760 T4R "Build" (2000 SR5 3.4 5 speed Desert Dune) CDNsldr 3rd gen T4Rs 59 07-25-2017 10:29 PM
02' Sport "Small Build" (Build Thread w/ pics) Grey-Thunder 3rd gen T4Rs 20 03-18-2017 09:08 PM
Josh's Build Thread: 2000 T4R Limited "The Queen" joshespdx 3rd gen T4Rs 10 03-05-2016 02:14 PM
Small Build, "College Budget" (Build Thread w/ Pics) Grey-Thunder 3rd gen T4Rs 0 12-10-2015 09:43 PM
cacarbuff's "Build Thread" but really it's a "Run Thread" :D cacarbuff 4th Gen T4Rs 19 03-10-2014 12:47 AM
