Okay
So I am almost a pro at this fuse stuff since my whole fuse box + wires were almost destroyed.
So under the dash you should see a #30 fuse (BODY). It is pink and block shaped. The only place I found them locally was Advanced Auto (Harbor Freight does NOT carry these type of fuses). Before you change that one, open your hood and make sure the the MAIN fuse 50 is ok and the 120.
Mine the 50 main fuse was blown and so was the 30 under the dash (some bozo put a 09 under there and it kept popping the stop fuse, turn signal and everything else)
Start there. If all fails, download the shop manual.
Good luck
Originally Posted by churley15
I have a 97 toyota 4runner limited. The gauge, ac, and tail light fuse was blowing out consistently about a week ago. This has since seemed to be fixed by someway or another. Now the STOP fuse has been blowing out which is taking out my brake lights and the ability to shift out of park. Luckily the override switch allows me to get around still.
The obvious solution is something in the cigarette lighter but ive checked the wiring their and it all seems ok to my eyes.
I do have an aftermarket radio, and just upgraded the gauge lights, the ac lights and the rear license plate lights to LEDs. I also have some dragging wires from the trailer wiring that I will be sorting to next to see if this is the solution to my blown fuses problem.
If anyone has any advice or anything they may know better than I please feel free to post on this thread or redirect me to a previous thread about this problem.
