I brought home our 'new' 99 Limited over the weekend, which came with a massive amp/sub in the back and a Kenwood deck with a missing faceplate
I removed the amp/sub combo and am getting ready to install a Pioneer AVH-2330NEX in the dash, but need some help identifying the mass (mess?) of connectors and wires.
I'm guessing #1 is the harness that went to the factory radio/amp. I've got a Metra harness on the way and will splice those in.
Do #2, #3, and #4 need to connect to anything?
Is #5 the set of wires run by the previous owner to the amp and sub in the back? I took a photo of the wires going back to the amp along each side of the truck and behind the rear seat. Assuming these are the same wires, I can remove them completely.
Lastly, I've got an orphaned connector under the driver's seat. Coincidentally, the button along the upper side of the seat doesn't work - I'm going to poke under and see if I can figure out where the other end is.
