Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 11-07-2018, 02:48 PM #16
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
So steady vacuum is 20 to 22hg then? Didn’t know that. What port/line are you using to test such?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 11-07-2018, 02:55 PM #17
128keaton's Avatar
128keaton 128keaton is offline
Real Name: Keaton
128keaton is on a distinguished road
128keaton's Avatar
Real Name: Keaton
Originally Posted by sleepydad View Post
it might be known as the S1000? maybe.
yes I did a little digging I think this looks like the instructions
1997 Sketchy SleepyDad build
Holy. SH*T thank you. Love this stuff. I'm adding it to my page if you don't mind. Solid info!
[DD]2003 Lexus LX470 - Black Onyx - Stock
[SOLD]2000 Toyota 4Runner - SR5 - White - 5-Speed - Toyota E-Locker (4.10s )- 620LB Eibach/OME 890 - 33" Falken Wildpeak ATs - 4x4 - 164k and climbing
[RIP] 1993 Toyota 4Runner - SR5 Sport - Black Onyx - 5 Speed - 31" Bridgestone Dueler ATs - 4x4 - Cracked Block at 254976 RIP
128keaton is offline   Reply With QuoteReply With Quote
Old 11-07-2018, 03:49 PM #18
Friday88's Avatar
Friday88 Friday88 is offline
Friday88 is on a distinguished road
Friday88's Avatar
I would love to know where you got the weather seals for that kind of money...
thanks
Friday88 is offline   Reply With QuoteReply With Quote
Old 11-07-2018, 04:17 PM #19
128keaton's Avatar
Real Name: Keaton
128keaton's Avatar
Real Name: Keaton
thanks
The junkyard by me gave me mine.
Old 11-07-2018, 04:20 PM #20
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
thanks
the guy I got the transmission from, every once in a while you run into somebody who is a bro. just happy to get something rather than nothing.
I have done a lot of craigs list stuff over the years and you will run into 2 kinds of people IMO. #1 think they have a gold mine and want way to much, these people I just walk away. #2 they are happy that somebody drove to their house with cash and offered to buy something they were thinking was worthless and will negotiate on price.
I know I have another pair someplace in a box but I can't find them. if your in need I can PM you when I find them. and to be clear these are the rain seals not the full door seals.
Old 11-07-2018, 04:45 PM #21
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
manifold vacuum zone, vac gauge
once warmed up it should stick @ 20 IMO
I rechecked and FSM does say 17 so mabe I'm good, since no supercharger on this one, yet.
Old 11-07-2018, 06:11 PM #22
I will have to check that out.
That garage is sorely missing a lift in it.
Old 11-07-2018, 06:46 PM #23
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
if only I would have put in 4 more feet of headroom clearance when I built it? and not run that in floor heating, would love to drill some holes and go thru a tube, not.
I have an evil plan for next summer, I'm going to go grab another hoist so I can pull the frame and body apart. I think with 2x hoists, one on each side and using the center of the body with some sort of sketchy support it should work ok.
so.... I just did the evap delete. it works just fine and no codes. will run it for a while and see.
also via ODBII the PID for VAC says now I have 22 hg. I will have to dig out that gauge and test again.
Old 11-07-2018, 11:56 PM #24
SDsurfx SDsurfx is offline
SDsurfx is on a distinguished road
No idea why but somebody decided to rip the drivers seat out at some point. probably because the bolt was rusted or maybe zombies? anyways, having a wobbly drivers seat is kind of annoying so I grabbed a M10 I think that was long enough to go all the way thru and secured it. Now I have a solid drivers seat. this truck has so much sketch in it.
I'm 100% sure somebody did the same thing before but... bolt must have rusted off?
Nice work! I need this mod for my drivers seat...
SDsurfx is offline   Reply With QuoteReply With Quote
Old 01-13-2019, 12:19 PM #25
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
frame replacement
OK!
seems like back when T4R was subject to the terror attacks or something I lost some post in this thread.
I need a new frame for this truck, got pretty lucky and found a CA truck that had moved to MN for just a year or so before it was salvaged so not much rust on it.
I can't really work on this part until spring of 2019 so... this is on hold but I can hopefully take care of the other parts I will need to get this frame swapped in.
Old 01-13-2019, 12:31 PM #26
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
rear axle restore
Everything I will be doing on this frame up restore on 1997 pinky will be coated with KBS DTM epoxy primer and then their top coat.
Why would I use that KBS coatings stuff.
#1 I don't have spray stuff and I don't have access to anyplace I could spray, unless I pony up the $ to have somebody else do it.
- conclusion -> brushing it on
#2 I wanted a direct to metal epoxy (DTM) because they claim better corrosion protection, so I drank this koolaid.
so far... I have done the axles, bearing cups, rear axle assembly and it's a biach to work with because painting these intricate little spaces takes a lot of time. impossible to not get runs but this the underside so I'm not really super freaked about brush marks and runs. what I want is solid corrosion protection and hopefully this will help. time will tell.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
using this flow chart to apply
RustSeal Flow Chart - Basic Guidelines - Stop Rust
sandblast->rust seal->rust seal->black top
super sexy PCK from
buy a PCK – jkeithwalters.com
Old 01-13-2019, 05:17 PM #27
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
@sleepydad don’t you have a compressor? The harbor freight spray guns are actually perfect for this kind of work. I’ve used them to spray frame coatings and such. They don’t have as much air consumption either unlike my devilbiss guns. Looks good regardless! And I wouldn’t really care if there were runs on anything on my undercarriage.
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 01-13-2019, 05:47 PM #28
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I think I have about 10 CFM @ 90 psi with my ganged up harbor freight 30 gal's. my blasting setup.
I don't have anyplace to spray that is heated. My wife might get angry if I setup a spray booth in the living room?
I'm going to need to do some kind of internal frame coating thing after I'm outside because there are still some places you just can't get with a brush or spray gun. the spring perch/sway bar bracket mount area and panhard bar mount have sealed areas.
I wish I could get it looking factory but that is just not going to happen. e-coat is not in the budget. I'm thinking I need to setup a frame rotisserie out of a couple harbor freight engine stands. being able to spin things around makes life so much easier.
something like this... not sure yet but after I'm done with rear axles here I'm going to start collecting the pieces.
Old 01-13-2019, 05:51 PM #29
Greenmachine86 Greenmachine86 is offline
Greenmachine86 is on a distinguished road
My mat on the driverside has the exact same hole in it as yours!!! And the tire, i would say they or you got the goodie outta that one
Greenmachine86 is offline   Reply With QuoteReply With Quote
Old 01-13-2019, 06:02 PM #30
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
@TonyB66 is using some product from Eastwood to get on the inside of his frame, it has a 3’ hose attachment or something.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
2000 limited SleepyDad build sleepydad 3rd gen T4Rs 279 09-13-2023 05:36 PM
sketchy dealer? T4r22re 3rd gen T4Rs 68 03-12-2015 08:52 PM
Is 239K Miles Sketchy? sparkslord 3rd gen T4Rs 13 05-05-2014 06:18 PM
Sketchy drilling 2001TR4runner 3rd gen T4Rs 5 10-24-2013 12:06 AM
Are bolt on sliders bad or sketchy? Wild Snapper Off-Roading 20 05-14-2013 09:05 PM
