06-22-2021, 11:33 AM
#301
Real Name: Mark
Real Name: Mark
Originally Posted by sleepydad
got a couple of hours to do me stuff, yes!
I'm not big on lic plate deco but I did try this and it seems like it will get rid of the lic plate rattle...
I like the way you do your thing always good stuff.
Plate Deco - try sticky back felt from Craft store cut to plate lasts till new plates come out no sub thump rattle
- ditch the deco, ha.
Plate bezel part of roof repaint project since paint gun be out.
06-22-2021, 11:49 PM
#302
@ sleepydad
I just love reading through your build threads. your cheeky wit, pictures of part numbers and super-sicmods make it a nice light afternoon read.
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
06-23-2021, 12:00 PM
#303
Real Name: 3 Bears
Real Name: 3 Bears
I took some pictures and kind of tried to document what I did... however... I can't seem to find any of the in process shots.
my door cards and handles were terrible from the previous owner who let their dog climb all over the back and passenger. luckily they had seat covers so that part is still pretty mint in this truck.
I got some vinyl and 3/16" foam and went to town and stripped down the door cards and re-glued everything with black vinyl.
super happy with how it all turned out and it's a huge improvement over the 1/2 falling off dog urine scented old ones. I like the black, it goes well with the moon mist interior so we are going to keep going down the replace it with black as the need arises. ++the inside of the truck now has that contact cement smell on warm days.
did you seperate the two halves.
reason I ask, is I have 2 door cards for my drivers. One is pretty broken at the bottom, one is bad on the top. was gonna grind off the little plastic "bruned " rivits, just not sure how to then re-attach
guess I could hot glue them
ideas ?
06-23-2021, 03:31 PM
#304
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
ideas ?
my cards are in good condition but I did use an old one to experiment on, good idea to have a whoops door card available to mess up on IMO.
yes I removed the upper and lower sections.
2 paths you can take.
I have tried both paths, both work ok.
path 1 pickup a cheap plastic welder/solder gun thing like this one... I used it... just fine. don't expect it to last a long time but for that price, meh.
Massca Plastic Welding Kit with Rods, Reinforcing Mesh, Hot Iron Stand, and Wire Brush, DIY Arts and Crafts or Professional Surface Repair, Portable Use, 80 Watt - - Amazon.com
you just get it hot and melt the plastic "bruned " rivits holding it on but don't melt too much because you need to re-melt those spots with the extra plastic from the welding kit.
when your done it will look like this
path 2
your going to have use your imagination sorry don't have picts, but if you grind down those little plastic "bruned " rivits just enough to get them to release the upper section, you can use a self tapping screw with a washer and it works pretty well. just have to be super careful not to drill thru to the other side and leave a hole in your door card. or hot glue would work it just might not hold all that great. the screw it down approached seemed to work just a tiny bit better.
06-23-2021, 09:56 PM
#305
Real Name: Mark
Real Name: Mark
Fastener tab rightside center is broken on every card I've seen owned when I got them.
06-24-2021, 01:54 AM
#306
Real Name: 3 Bears
Real Name: 3 Bears
path 2
gonna try method 2 as i am in a time crunch, and I do have a woops door to practice on. thnaks for the ideas
06-24-2021, 08:02 AM
#307
Screws with widely spaced, deep threads will bite into that soft plastic much better than a sheet metal screw, BTW.
06-24-2021, 08:10 AM
#308
Real Name: Mark
Real Name: Mark
Helps against splitting if you drill pilot hole correct size for screw your using.
06-25-2021, 03:32 PM
#309
Real Name: 3 Bears
Real Name: 3 Bears
after cutting door panels apart...and picking up small screws....well.not gonna work well... they could work on the outer ones,,,not the inner near door handle and arm rest.I ordered the glue gun thing you referenced
thanks
06-27-2021, 07:08 PM
#310
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
thanks
bummer well... update us when you get the plastic melting thingy. it works ok for the price.
interior upholstery is harder than it looks. at first I was expecting it to be easy and it turned out I had to really pay attention to the details otherwise it does not work out.
one other thing I just went thru - I had to re-apply some extra contact cement and fix a sag. I initially did the work in the winter time and once it got super summer roasting hot one spot needed more glue. not surprised because the vinyl with fabric backing seems to suck up some glue so make sure you apply plenty.
06-27-2021, 11:09 PM
#311
Real Name: 3 Bears
Real Name: 3 Bears
thanks...im not doing anything new...like new vinyl....just taking one door pannel that is busted on the bottom half and attaching to one door panel that is busted on the top half. So one good bottom panel attached to one good top panel... Up here ...could not find any door panels that were good
07-02-2021, 04:59 PM
#312
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
rcv axles are the best, ah yea not
have been working on a full floating rear for this truck, it's slow going.
when inserting the axles into the differential one axle slides into place perfectly. The other axle stops short and will not slide in to full engagement. once the trouble axle has been slid into place it is extremely difficult to remove.
the axles need to fully seat for everything to work correctly on the locking hub side.
I have a spare differential assembly so after removing both axles from the truck, I tried both axles on either side of my spare differential. Yes one axle regardless of side will not slide to full engagement.
left side will not slide in
remove and swap sides
right side will not slide in now
Not sure why it seems so common to get crap from so many automotive aftermarket suppliers. it would be so easy to just test fit those axles before you ship them? ah yea why would test fit something? lets ship it all over the world and cause everybody the most amount of pain possible. The profit margins on these things must be amazing if 1/2 of what you produce is bad from the start. I will have to see if I can get these made elsewhere, since it sounds like RCV is +6 months behind on orders. not only do they make crap but they can't make crap fast enough to keep up. #sad
07-02-2021, 08:32 PM
#313
Put a little Prussian blue on there and see where it’s hanging up. Maybe a bit of filing on the splines will do the trick.
07-02-2021, 08:42 PM
#314
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
I had another spare spider I kept just in case so I took that apart and we ran the splines thru a side gear a couple of times. This helped and I was able then to dead blow it into it's home. I'm sure as soon as we run a bit it will make it's witness mark and should slide in and out just fine.
I found it ironic they say this is a floating axle setup where can just remove the axle... I was like yea if you have to pound the axle in with a hammer? "floating" is not the word I would use. sigh.
so now I just need to fab up some break lines and of course swap out assemblies. I'm getting a closer to being able to flat tow.
07-02-2021, 08:56 PM
#315
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
Something Old, New, Borrowed and marked in Blue paint pen.
finally at long last... just need to do brake lines now. that should be easy right.
the something new part, yes that is what you think it is
in all it's glory, just like factory fresh, even with link bar correction bracket.
