Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-28-2019, 10:17 PM #46
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough DaMonkey will become famous soon enough
DaMonkey's Avatar
What stops it from rotating all the way?
DaMonkey is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 02:42 PM #47
Originally Posted by sleepydad View Post
1997 Sketchy SleepyDad build
If the nut doesn't rotate freely, it is probably supposed to be 'loose' in there. It allows for some misalignment during assembly. Lots of the captive suspension nuts are this way on Toyotas (and maybe other makes).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-29-2019, 03:24 PM #48
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I used my harbor freight birthday bucks to grab another engine stand. who does not need yet another engine stand?
Lol, would of been nice to have two engine stands when I had rear axle torn down to housing for cleanup and paint. You have 90 days to take it back, hurry up!
Old 04-29-2019, 04:08 PM #49
m0ist m0ist is offline
m0ist is on a distinguished road
Originally Posted by Reinout View Post
I had the EXACT SAME damage on my 97. I made a "plate" with a captive nut that I installed from the inside of the seat-support-rail (if that's what it's called) when I had the carpet out.
FUN
That's wild. Same thing happened to me when I put passenger seat cushions on my driver side rails. I ended up drilling through the floor and using an 1-1/2" long bolt.
Check out my website https://69thstreetgarage.com/
m0ist is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 06:57 PM #50
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
the rear of the frame hits the stand support. I picked up some 2"x 2" tube 11 gauge today from garlic steel and will extend the back connection so it will spin around. great horny toads I have not laid down $$ for bulk steel for 10+ years and that stuff is spendy.
after it spins freely I need to add disco lights and it's a party!
Old 04-29-2019, 07:01 PM #51
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
no it rotates
you can see where the welds were broken. there would be no way to get the nut into that spot post weld. you would not be able to replace that big stud bolt otherwise.
it's a pain because that is not a spot any normal human could weld. needs to be cut open and then re-tacked into place and then welded back shut. or I could turn the dial way up and burn it out.
Old 05-01-2019, 10:06 PM #52
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
spinny thing works better now
I used the hitch mounts to extend some tubes so the frame clears the engine stand now I can flip her all the way over.
I can't say enough good things so far about the cheap-o welder. for not having welded for years and years to pick this thing up and run welds like this is really pretty amazing. welding has come a long ways in the last 15 years.
Old 05-01-2019, 11:53 PM #53
DaMonkey's Avatar
DaMonkey's Avatar
Do you need the spare tire hoist gear cable thing for that frame? I'm about to cut that section out of mine, you can have it. Nice shape.
Old 05-02-2019, 01:46 AM #54
DiracSea's Avatar
DiracSea DiracSea is offline
Real Name: Mohi
DiracSea is on a distinguished road
DiracSea's Avatar
Real Name: Mohi
what you're doing with this build is a dying art.
Especially among my generation, but I'm pretty confident there will be a strong push back to the trades in a few years to reverse that a bit.
I'm shopping for a 3rd gen at the moment and hoping it can be smooth introduction to working on vehicles.
DiracSea is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 08:11 PM #55
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
it's takes a while to get the hang of it. I just did brakes and fluids for many many years but not really until 3-4 years ago was ready to jump this far into it.
as long as you have the place, time and $ it's very satisfying.
Old 05-03-2019, 08:16 PM #56
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
steering rack mount fix-a-rooooo
there are 2 captive nuts inside this little tower thingy, sure it has a name. but one of the nuts came lose so I had to cut it open and re-tack the nuts down.
was able to re-locate the nuts based on the tac welds that held them in place. it's a bit scare how skimpy the toyota welds are on these nuts. time to bring some big old american welds to those babies!
tac it back into it's spot
kind of goopy but... got good penetration and no clearance issues for now.
Old 05-14-2019, 01:58 PM #57
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
frame repair done I think
this was the last piece of the frame that needed attention before blasting
cut it out
used some M12 1.25 bolts as transfer punches so I could get the layout exactly the same as factory.
welded on some flange M12 1.25 so it's the same as factory
turned out pretty decent for a hack like me
I also added some backing and plug welded that backing so it has some reinforcement.
Old 05-14-2019, 06:51 PM #58
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Pretty damn creative sd! Kudos to you. Enjoying the build.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 07:32 PM #59
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I hope you will ask for another vise for Father’s Day, despite the ingenuity there. Looking good.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 08:19 PM #60
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
eastwood dreams
shot up 6 cans into the frame and x-members. I think really you would need 8 cans 4 per side to really get a solid good internal coat. also being able to roll the frame around helps get it all covered.
stuff runs like crazy town. also wears gloves and pants and maybe even shoes because it gets all over the dam place.
2000 limited SleepyDad build sleepydad 3rd gen T4Rs 279 09-13-2023 05:36 PM
sketchy dealer? T4r22re 3rd gen T4Rs 68 03-12-2015 08:52 PM
Is 239K Miles Sketchy? sparkslord 3rd gen T4Rs 13 05-05-2014 06:18 PM
Sketchy drilling 2001TR4runner 3rd gen T4Rs 5 10-24-2013 12:06 AM
Are bolt on sliders bad or sketchy? Wild Snapper Off-Roading 20 05-14-2013 09:05 PM
