Originally Posted by fourfive
Good job on the carpet. Did you use padding or just the carpet by itself?
I ordered it from stock interiors + mass backing. I think it's worth the little bit extra for mass backing because it helps with sound quite a bit.
You have a 4x front bumper? What's your center hub/fender measurement on those settings? What was your previous front set up?
I had this setup from before... looks like they changed the rear shocks a bit but this was the same kit. sucked rode like a lumber wagon.
TTHA-9602 - Toytec/Eibach 3" lift kit - 96-02 4Runner
I did not measure it with the old setup but you can see from the pics in this threat is was sky high.
new setup is
drive droop 23 1/2
drive ride 21 1/4
2 1/4 difference
pass droop 23 1/2
pass ride 20 3/4
2 3/4 difference
This was the old setup, no bumpers
old setup bumpers
This is the new setup
This is why I need to lean how to 3d print. What is the bushing made out of?
I have wanted a 3d printer for years but... I never really wanted to put in the "build it myself" effort. They have comes miles in the last couple of years. I was able to take this one "Artillery Sidewinder X1 3D Printer - V4" out of the box and be printing in maybe 30 mins.
I have a strong background in CAD from my woodworking world. The software now is super easy as well. if you have been on the fence because building on seemed like a pain. your out of excuses.
I used PLA 1.75mm filament. I just ordered some ABS filament so I can make them again if the PLA does not hold up. ABS just gives some offgassing like any nasty finish. needs to be vented. PLA is easy and safe but not as resistant. I'm thinking of trying an air intake that is the same size as stock but remove the resonator parts.
