I have known I needed to do plug's,Wires,coils and injectors on this truck for a long time now... codes were popping up but not very often so I let it go.
I started getting lean codes/miss fires, I was like who is the Ms. Fires?
did not take any pictures but I picked up new wires/coils/plugs because people have seen that jazz.
3 @ 9091902212 COIL ASSY, IGNITION
1 @ 1903762050 CORD SET SPARK PLUG
2 @ 1717662040 GASKET, AIR SURGE TANK TO INTAKE MANIFOLD
6 @ 9091901192 PLUG, SPARK
3 @ 91511G0622 BOLT,FLANGE - these are the coil to valve cover bolts
I also grabbed
5VZ 3.4 LITER V6 EQUALIZED FUEL INJECTOR SET 1995-1998 from LCE
5VZ (V6) Equalized Fuel Injector Set (95-98)
after getting the plugs,coils,wires, injectors done this truck runs tighter than an otters a-hole.
I also finally got around to working on the rear links
DaMonkey
dreamed up.
decided I would try this stuff out for smaller projects
all hanging around ready for blasting
ah there is nothing like the smell of napalm in the morning and fresh sandblasted links.
and everybody all dressed up and ready to rock, well almost everybody.
of course on #4 I ran into trouble and for some reason the insert just decided to go sideways on me and I rekt it. ordered a replacement from ballistic so I will have to wait on that until I have 2 complete sets of upper links.
I can start working on the lower links this weekend so I should have 2x sets of rear Ballistic joint based links.
