Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 12-07-2020, 08:27 PM #286
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by JZiggy View Post
Ok so now we need a link to your Etsy shop please.
yea well my wife might have something to say about re-arranging my priorities, just maybe?
I love the look of the tumbled leather.... soft but rugged in that how the west was won 1950's nostalgic dream sequence we all have; but in reality know the western expansion was bloody and cruel. wow that escalated quickly... shake it off ok ok...
It's really not that hard to do it. I have a couple of spare door pulls laying around so I can do a couple more and perfect my inner Etsy. is that a thing? hmm if not it should be.
BTW: just order a couple of door kits from Russia. that was a good lead those things drive me nutters once they wear out.
Old 12-19-2020, 06:35 PM #287
poleclimber63's Avatar
poleclimber63 poleclimber63 is offline
Real Name: Doug
poleclimber63 will become famous soon enough
Real Name: Doug
wow..
Originally Posted by sleepydad View Post
pickup body, roll frame out, roll new frame in, lower and adjust only takes 30 mins. I did a ton of prep work. I like things to go as planned when the time comes.
radiator, heater core lines, rear heater lines, ebrake cable, fuel lines. AC can stay with the body. I ended up pulling the starter wire harness out from the fuse box and doing that with the frame.
I have been working on that frame since this last spring. a couple of hours after dinner whenever I could sneak out into Santa's workshop.
it's a boat load of work, but that depends on your end game. I like the "looks like it came from the factory" appearance once I'm done. I take my time, no rush I want things to turn out looking nice and be serviceable.
if you have access to a lift and some help you could totally do it in a weekend.
Would be a couple of 10-12 hour days. just really depends on how far you want to go and what condition the donors are in. other than the engine, trans, steering rack, and 3rd member nothing else was usable. rust belt 21 years of winter rusts things into solid non serviceable globs.
Jeez, the things you have to do to keep our ole' 3rd Gens on the road in the rust belt... I've seen a few members do frame swaps and I'm super glad I don't live East of the Rockies!!! I'll say, the Taco guys have it worse, even Toyota acknowledged the frame rust--- even my local Toyota dealer, here in town, has a couple of frames out back--- AND I live in an area where rust isn't really an issue!! I'm really lucky, my 98 had rust coating applied when it was brand new-- in Vancouver, so the frame and body are almost perfect (aside from a few scratches and badges of use! I check everything in the Spring and clean the smallest spots (usually the rear end and peripheral body parts) and hit them with rust paint. When I did my engine replacement, I cleaned everything well, and hit the exposed inside fender wells and frame with POR15. As far as I'm concerned, as long as I can keep the rust at bay, everything else can be repaired-- I'm planning on keeping it till I can't buy gasoline anymore (thanks Elon Musk), or I can't get up and in it anymore!!
1998 SR5 3.4L V6 Auto... Pretty much bone stock...aside from the Tundra brakes, OME880 and OME906's in back all with Rancho 9000XL adjustable shocks ... "Livin' the dream in the Canadian Okanagan!"
Electronics/Telecommunications Engineering Technologist
poleclimber63 is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 10:16 PM #288
2chains 2chains is offline
2chains will become famous soon enough
the key kept getting stuck and just looked terrible... like a metal eating rat had been chewing on it....
it was time for a new CYLINDER & KEY SET, IGNITION SWITCH LOCK. I had been looking for the complete set but it's out of production and I was not able to find a complete set.
for $75 with 2 new keys and a brand new ignition cylinder done deal.
6905735070 Toyota CYLINDER & KEY SET, IGNITION SWITCH LOCK, Price: 54.93$, Weight: 0.435kg - PartSouq Auto Parts Around the World
1997 Sketchy SleepyDad build
However now my key will no longer match the door so I headed down cheap knockoff keyless entry. In particular this one seems to be decent with 11 billion reviews.
Amazon.com: Docooler Car Remote Central Lock Locking Keyless Entry System with Remote Controllers
so lets tear it all apart and see what we can do here
starting with the lock/unlock triggers from the riveting document 1998 4Runner Electrical Wiring Diagram EWD319U we see the red/white and red/yellow on the IF1 blue connector plugs so I spliced into them on the drivers door side. this was pretty easy actually.
IRL
this next part you will have to use your imagination because I was wayyyy to angry to slow down and take a picture of it.
you can ground out the Red/White wire coming from the stalk to the tail relay. to do this I ended up having to use another relay to swap the + signal out of the black box to - signal. not hard at all since I already all the wires I needed.
once that is done you can lock and unlock all the doors, and the front marker light and rear running lights flash a couple of times. The interior lights also flash since this circuit sends power to the interior illumination circuit.
all in all it works just like factory except no bleep bleep sound... and that is ok for me.
Thanks for posting so much detail! How is it working out? I'm in a similar situation rs3000 removed by last owner and no fob. Can you tie this component to the two wires on driver side and get all doors to work?
Looking to do easiest keyless entry install and wondering about the relay you mentioned...
"you can ground out the Red/White wire coming from the stalk to the tail relay"
Is this to ground the unit itself or is it something else?
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
2chains is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 06:14 PM #289
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
it's working out great and I love it, still... using it daily since I posted this.
yes to the question can you get them all to lock/unlock the drivers door has the global lock/unlock switch on it so... that is why I use the drivers door. if your drivers door does not lock/unlock all the door now... then something is wrong with your lock actuators.
my only complaint and it's a minor one... is because I did the send power to the tail light relay it blinks all the lights and if the drivers door is open it will buzz the "your lights are on" warning for just a second and yes that happens because I wired it that way... oh well. but it's super minor compared to having new keyless entry and it only happens if you keyfob bleep bleep with the door open so...
it's really not a hard job but it will make you want to drink a shot of whiskey at some point during the process.
Old 02-03-2021, 06:30 PM #290
^^Thanks for the reply. It's always great to hear about real world impressions! I've got all my mechanical straightened out with my new ride and now dealing with the "nice to have options list". Keyless is the next item now that my ignition cylinder is moving.
All my doors lock with interior button so I think I'm off to a good start. I'll have to check out that product as it is a great price for such a functional mod!
Old 03-07-2021, 06:45 PM #291
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
got to do a little work with the truck
Old 03-07-2021, 07:37 PM #292
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Nice.
Sounds like that wood is reading to burn too...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 09:19 PM #293
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I tried
I took some pictures and kind of tried to document what I did... however... I can't seem to find any of the in process shots.
my door cards and handles were terrible from the previous owner who let their dog climb all over the back and passenger. luckily they had seat covers so that part is still pretty mint in this truck.
I got some vinyl and 3/16" foam and went to town and stripped down the door cards and re-glued everything with black vinyl.
super happy with how it all turned out and it's a huge improvement over the 1/2 falling off dog urine scented old ones. I like the black, it goes well with the moon mist interior so we are going to keep going down the replace it with black as the need arises. ++the inside of the truck now has that contact cement smell on warm days.
Old 03-25-2021, 03:49 AM #294
dork0900 dork0900 is offline
dork0900 is on a distinguished road
Great job on those doors!
dork0900 is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 11:43 AM #295
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
That looks sharp, nice job!
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 10:49 AM #296
pmw42069 pmw42069 is offline
pmw42069 is on a distinguished road
This looks awesome. If you ever find the in process photos I would love to see them as I was just considering spraying my vinyl and plastic with duplicolor or something.
pmw42069 is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 10:46 AM #297
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
7680135160 garnish, back door, outside
the back door garnish was starting to look pretty bad and the weather stripping was gone.... this part is no longer available as far I know? would love to find a source for a new one from 3rd party?
used a different junk yard garnish repaired all the holes and scraps scrapes and repainted it in black with shiny stuff...
waffered up a matching key cylinder so that will be fresh again
got the plate light and new handle + my bag of clips
this should be a quick job( yea right )
Old 05-29-2021, 03:56 PM #298
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
wrapped it up
got a couple of hours to do me stuff, yes!
installed all the new goodies, and some new weather stripping.
it's a little out of place but it will grow on me
I'm not big on lic plate deco but I did try this and it seems like it will get rid of the lic plate rattle.
Amazon.com: License Plate Frame,2PCS Silicone License Plate Frame with Drainage Holes ,Rust-Proof, Weather-Proof and Rattle-Proof License Plate Frame for Car - Black: Automotive
Old 06-15-2021, 09:47 PM #299
Real Name: Doug
Real Name: Doug
had a look...
Wow, that looks great! love the look... Every time I receive notification from Pic N' Pull of a 3rd gen landing in my local yard, someone gets to the rear hatch first. The last 3 4R's I approached, had the entire rear hatch missing...
Old 06-22-2021, 10:27 AM #300
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
been working hard on new rear axle assembly for this truck
I have been shooting potato video for this one but not quite done with the entire edit.
blasted rear assembly meet DTM epoxy with spray gun!
spraying with decent equipment so much fun
one side is finally all done
first time using these trail gear locking nuts... very slick and way better than bending locking washers and 2x nuts, maybe as long as it all works. time will tell
4130 Chromoly Spindle Wheel Bearing Nut Kit, Trail-Gear (300519-KIT)
2000 limited SleepyDad build sleepydad 3rd gen T4Rs 279 09-13-2023 05:36 PM
sketchy dealer? T4r22re 3rd gen T4Rs 68 03-12-2015 08:52 PM
Is 239K Miles Sketchy? sparkslord 3rd gen T4Rs 13 05-05-2014 06:18 PM
Sketchy drilling 2001TR4runner 3rd gen T4Rs 5 10-24-2013 12:06 AM
Are bolt on sliders bad or sketchy? Wild Snapper Off-Roading 20 05-14-2013 09:05 PM
