01-21-2019, 08:18 AM
#16
Real Name: Chris
Real Name: Chris
Originally Posted by atcpup
Great catch but unfortunately still no joy. I have Torque Pro on an older Android and the Trans Temp reads perfectly.
I have a 2000 and it’s been working for me. go through all your settings and make sure everything is correct. and JIC, only works when the engine is running. *
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
01-22-2019, 01:29 PM
#17
Originally Posted by AZBub
This is the reader I use. No problems been working like a charm ever since.
Car WIFI OBD 2 OBD2 OBDII Scan Tool Foseal Scanner Adapter Check Engine Light Diagnostic Tool for iOS & Android https://www.amazon.com/dp/B00W0SDLRY..._1xBrCb9ZA4R17
I was looking at that one. Ive also found this one : https://www.amazon.com/Vgate-Elm327-...=1VUDKH32WCQOT
Seems to be a slightly smaller profile which is nice.
Wonder if they work the same
01-24-2019, 08:27 PM
#18
Did you by chance get it working ?
I'm getting the same error on my 2000 SR5 v6.
And Im using the this reader : https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
@ AZBub
what OBDII reader are you using ?
01-24-2019, 09:01 PM
#19
@ AZBub
one more thing , what iPhone are you using ? Which iOS firmware version ?
For reference , I’m using an iPhone 7plus on iOS 12.1.2
01-25-2019, 12:05 AM
#20
Real Name: Chris
Real Name: Chris
Originally Posted by dreyday
@ AZBub
iphone 8 worked on 12.1.2 and it still works on 12.1.3
01-25-2019, 02:38 AM
#21
Just upgraded to 12.1.3 and still no luck.
Wonder if it's because I ordered the "improved" version of the Foseal unit you have.
01-25-2019, 08:29 AM
#22
I'm using an iphone X with 12.1.3 with the original Foseal (not the updated version) Funny thing for me is the Foseal would work with an older Samsung Tablet (Android) but then it quit working altogether. I was positive the adapter was bad but after reading your comments I'm not so sure. I'm waiting on a replacement from Amazon, I'll keep the post updated.
01-25-2019, 02:51 PM
#23
Please let me know if the replacement unit works for you.
I really want to get this working, as I would much rather use this than spend a ton of money on a scan gauge .
01-26-2019, 09:28 PM
#24
Real Name: Chris
Real Name: Chris
Are you absolutely sure you did a user defined PID and filled out ALL the info correctly?
01-27-2019, 01:05 PM
#25
100% sure
So the replacement connected fine but I still could not get the Trans Temp working on an iphone or ipad. I'm starting to think it's a Foseal issue
01-27-2019, 02:23 PM
#26
Shame. This seemed like a decent and much cheaper alternative to an SG2.
2000 Millenium Silver Limited T4R - Stock... for now.
2018 Blizzard Pearl Limited T4R - Wife's Ride
2008 Blizzard Pearl Limited Rav4 - Daily Driver
01-28-2019, 02:09 AM
#27
Yes, I'm 100% sure I filled it out correctly. Did it about 2-3 times now from start to finish without luck. The regular gauges for speed, fuel eco, rpm's all works, but not the user defined PID.
I'm gonna try it again once more tomorrow for good measure. If no luck, I'm returning the Forseal unit.
Yes, this does seem like a much cheaper alternative to the Scan Gauge, hence I'm attempting it first before going any further. I would still much prefer this than the SG2 as I can pull it out and plug it in when ever I need it, otherwise I just have it in my glove box.
01-28-2019, 12:09 PM
#28
I also get the "No data was received" error message. I have a BAFX wifi unit with OBD Fusion on iOS 12.1.3. Other displays appear to be fine.
Sunburnt 1999 SR5 4x4 E-Locker Bilstein 5100s OME906 FJ80 16x8 Falken 265/75r16
01-28-2019, 04:30 PM
#29
Real Name: Chris
Real Name: Chris
IPhone Users: OBD2 app with Transmission temps.
weird that some people get this to work and some do not. I can not think of anything else I did to get it to work other than changing the formula for accuracy. Make sure enable commands is on. There might be an issue cause it’s an unsupported PID. that’s all I can think of.
01-28-2019, 09:58 PM
#30
Tried it again today for good measure with no luck.
Enable commands is turned on as well.
Going to return my unit and order the same one from the link shared by the OP and see if that works.
If not , then SG2 seems to be the next option.
